Question about Craftsman Drills
CHARGER FOR CS0926 DRILL DONT WORK
LOOKING FOR REPLACEMENT CIRCUIT BOARD
  • 26 Answers
SOURCE: Kawasaki drill charger
no warranty ?
well,as for me,i would rather find any DC charger that suits the voltage output for the battery..
smaller ampere gave longer recharging time but keep your battery cool during charging...
Posted on Aug 05, 2009
  • 3 Answers
SOURCE: fixing a cordless drill battery charger
usually transistors have three legs, diodes have two arms all very confusing isn't it? resistors have two arms as well but not three legs or only two legs and no arms its all about arms and legs isn't it do not attempt this repair if you live at home
Posted on Aug 27, 2009
rowdy45176
  • 2176 Answers
SOURCE: where can I obtain a circuit board for a bosch
most tool manufacturers don't offer the circuit boards as a separate saleable part. I can't find anything at the Bosch website.
Posted on Jan 23, 2010
SOURCE: looking for charger for cordless 19.2v drill
I couldn't find one, looking everywhere. The newer Coleman chargers are a different size. The red charging light would not come on. Using a meter, I figured out it wasn't the charger, but the power adapter. I found one online that fixed my problem and now I can charge my batteries for my Coleman impact drill. From Digikey.com
http://search.digikey.com/scripts/DkSearch/dksus.dll?x=0&y=0&lang=en&site=us&KeyWords=454-1403-nd
Posted on Oct 21, 2011
  • 1212 Answers
SOURCE: c7 36 volt charger not working keeps blowing internal fuse
If the fuse is blowing before the battery is installed to charge, the problem lies on the circuit board. Since it is most likely a switch mode supply, you might try replacing the electrolytic capacitors first. Then check what should be a MOSFET, although some may have a regular bipolar transistor as well.
If the charger blows the fuse when the battery is installed for charging, the battery has some shorted cells that overloading the charger, or the contacts are distorted and being shorted by the battery
Posted on Feb 18, 2012
C7 36 volt charger not working keeps blowing internal fuse
Feb 17, 2012 | Drills
Makita 1850 battery charger FIX. A friend asked me to check his charger unit which had failed after it had been connected to a portable petrol generator that incorrectly generated 317 Volts AC and not the...
I have a BL1830 Lithium Ion LXT battery that will not charge because the charger tells me the battery is broken. I have taken the battery apart to find no problems with the connection from cell to cell. There is a small circuit board that I cant find any visible signs of damage on. The battery will still run a flashlight or a drill but it is almost drained.
May 16, 2010 | Makita Drills
Where can I obtain a circuit board for a bosch cordless drill charger, Charger is AL 2404, part number 2 607 255 185, also has D-70745 Leinfelden printed on charger
Jan 13, 2010 | Bosch Drills
The Makita BL1815 battery will not charge, lights flash red/green, indicating bad battery. I replaced one open cell with known good cell, charger still reads bad battery although I can charge from an...
tried it a few times. got the charge up to around 13.9 and it still wont charge. i dont understand, because the battery isnt that old to begin with. thanks for the suggestion.
Dec 16, 2009 | Makita BL1815-2 18 Volt 1.5 Ah Compact...
Charger not powering up, fuse is good?? what the f---?
Internal board fuse checked? This may/may not help?
Makita 1850 battery charger FIX. A friend asked me to check his charger unit which had failed after it had been connected to a portable petrol generator that incorrectly generated 317 Volts AC and not the usual 240 Volt AC. On the charger circuit board next to the transformer wire connection is a component marked F2; this is a 2.5Amp fuse covered with heat-shrink sleeving. This fuse had ruptured/blown. Also blown was Transistor Q1, a ''P'' Mosfet labelled IRF9Z24N and Schottky Diode D9 labelled SR560. Replacing these 3 items got the charger working again. NB Resistor R31 is only 0.1ohm - don't assume it's gone short circuit! NB. I'd presume that most other Makita chargers will have this heat-shrink sleeving ''camoflaged'' fuse on the input of the circuit board and it would definitely be worth checking if the charger has stopped working. Regards Roy
Oct 24, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
BC430 Charger burns fuse with no batteery pluged in
the charger has a direct short in the board and you would need to either find it e.g. cord, burnt circuit or replace the charger. It would be best to replace it.
Oct 06, 2009 | Bosch Drills
Charger no light and wont charge
Sorry to give you my opinion, but these chargers are very delicate, I have 4 and can barely keep 2 going. My recommendation? Open it up and look for obvious shorts/loose wires, if no luck then buy another one and return the busted one as if it were the new one. You will end up with two working chargers. PS this is probably fraud...ha!
Matt Giantglobes.com
Mar 10, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
MAKITA DC1290A CHARGER PROBLEM
Makita generally does not provide a schematic for the charger wiring. The only parts that are usually replaceable are the cord and housings and possibly a fuse. If this is an older charger I would look for a "cold solder joint" I fixed quite a few for this and one component breaking loose. I dont know if Makitausa website can help or not. What volt is this charger, I have a couple in my garage that I can look at also
Jan 19, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Fixing a cordless drill battery charger
Oct 18, 2008 | Drills
Drills Logo
62 people viewed this question
Top Craftsman Drills Experts
Gareth Cockram
Gareth Cockram
John Trevino
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
