Question about Roku HD 2000C
Roku 2000C will not connect to local network
Modem/router is a Cisco DPQ3925C DOCSIS 3.0 2-PORT Voice Gateway. Worked fine with previous router.
3 Suggested Answers
  • 36 Answers
SOURCE: ROKU can't connect to local area network.
Have you got past the point where the Roku updates itself? If not, connect the Roku to the router via ethernet to get to that point. Make sure you can watch something on the Roku. Then try connecting wirelessly.
2. If you are still having trouble, connect the Roku directly to the modem. (this is temporary). If you can get the Roku to work, the problem is with your router and not the Roku.
3. Restore all the connections - it would be a good idea to reboot everything: Let the modem come back up, then the router, then the Roku.
4. Check for firmware updates for your router.
5. If you are still having trouble, post the make and model number of your router.
Posted on Oct 29, 2011
tgvern
  • 281 Answers
SOURCE: Can't get Roku N1100 to
Make sure you select the correct input for your device. If you are using RCA cables then select the RGB option on your inputs, or it may RCA as a connection. If you are using HDMI then make sure that is selected.
Posted on Dec 10, 2011
Www arrisi com
If this is the same model:
http://www.cisco.com/c/dam/en/us/products/collateral/video/model-dpc2505-channel-bonded-cable-modem-americas/product_data_sheet0900aecd8072a168.pdf
It does not have wifi built into the unit.
May I suggest purchasing a wireless router that supports Gigabit speeds on its network ports and perhaps up to 300 Mb on wireless? That way you can have the best of both worlds!
Regards,
David
Aug 09, 2014 | Cisco DOCSIS 3.0 DPC3000 Cable Modem...
Roku streaming stick cannot connect to my local network
Please contact ROKU support for this problem.
Jun 16, 2017 | Roku Televison & Video
How do I connect cable modem to cisco 3560 switch and configure it?
The cable modem will need to go through a router because it needs a NAT and PAT translation table, connecting the cable modem direct would lose the ability to get to the internet.
Jun 05, 2012 | Cisco Catalyst Compact 3560-C PD PSE -...
Does the motorola sb6121 have a router built in?
Well, I'm not sure exactly what you mean by router, but I can tell you that it only has one physical ethernet port, not 3 or 4. It does have a built-in DHCP server, which means that if you have more than one computer connecting through it (using a wireless access point, for instance), it can assign each of them a separate IP address. The setup guide is here:http://www.motorola.com/staticfiles/Video-Solutions/Products/Voice-and-Data-CPE/DOCSIS-Modems-Gateways-and-eMTAs/Cable-Modems/SB6121/_Documents/_StaticFiles/577212-001-a.pdf
Jan 28, 2012 | Motorola SURFboard Computers & Internet
How do I access my Comcast Cisco DPC3000 to enable port forwarding? I am using a net gear router that is set up for port-forwarding but my modem seems to be stopping it from working
Go here. That site will direct you how to do port forwarding specifically for your router in pictures, or it will allow you to download a program to do it automatically for you.
Jun 23, 2011 | Cisco DOCSIS 3.0 DPC3000 Cable Modem...
How to set up the wireless internet connect on my laptop to this new SBG901 modem?
Short answer: YOU DO NOT.
The cable-modem just converts from the cable-company's signals to/from Ethernet signals.
You use an Ethernet cable to connect the output from the cable-modem to the 'WAN' (or 'Internet') port on a router with wireless capabilities. Then, you configure the router to create your own wireless network, with:
* an SSID ("network name")
* encryption level (use: WPA)
* a password for your network
Then, your wireless device can cite the SSID/password to authenticate to the router.
Feb 24, 2011 | Arris SURFboard Gateway SBG901 DOCSIS 20...
Feb 05, 2011 | Roku HD Player (N1100)
I have a Belkin N-Router and I was wondering how to connect it to my modem because the cable it has connects only to where the modem's ethernet cable is located when i just run my modem, and there is only...
plug the one ethernet cable from the modem into the router wan port . The modem will have an ip address note this and then change the ip address to one higher than the modem for the router's ip address and change the ip address in the router to make the gateway ip address the modem ip address.
Disable the DHCP server in the Router iIf the modem has an active DHCP server in the router.
Plug the rest of your network into the other router ethernet ports.
Feb 24, 2018 | Toshiba DOCSIS Cable PCX2500...
E1 or T1 to pabx to router to softphone
Yes, configure second Cisco E1 port to simulate you telcom (network side) and connect it to PB, and first Cisco E1 to your telecom provider.
On Cisco router configure voice ports, and number manupilation, so you can catch any call and redirect it anywhere (Voip, Telco, PBX).
I tryed that with Ericcson, and it didn't work until connections where like these
telco <-> Cisco VoIP gateway (E1x2) <-> PBX
PBX's are not very flexible, Cisco is.
Jan 27, 2009 | Smart Modular 128MB SDRAM Module for Cisco...
Cisco 1721 router serial port not showing any loop.
the problem is with your modem....did you tested the local loop from router to modem....are u getting local loop from one modem till router or not...try first checking local loop from modem to router...
Nov 15, 2008 | Cisco 2610XM Router
Roku HD 2000C Logo
32 people viewed this question
Top Roku Televison & Video Experts
David Payne
David Payne
Thomas Stauber
Thomas Stauber
ray gallant
Are you a Roku Televison and Video Expert? Answer questions, earn points and help others
