Question about Watts Premier WATTS FV-4-1/4 Valve,vent,automatic 4A821
How to install automatic vent valve 4a821
How to install
Where is my vent valve solenoid on my 2006 Chevy Colbalt?
It's located under the vehicle back behind the fuel tank , Installed in the canister ! Remove the EVAP canister vent solenoid valve from the canister !
Rotate the EVAP canister vent solenoid valve counterclockwise in order to release it from the locked position.
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle . Disconnect the evaporative emission (EVAP) canister harness electrical connector (2) from the EVAP vent solenoid valve. Clean away any debris that may be present around the EVAP canister vent solenoid valve.
Remove the EVAP canister bolt. Lower the EVAP canister.
Feb 25, 2015 | Chevrolet Chevy Cars & Trucks
How install vent valv solenoid
This vent valve is easy to install, it would help me if you listed the year,make ,model and engine size of this car.
I will try to help you here with the info i have, the vent valve located at the rear of the car , under the car. the vent valve will have a electrical connector, remove the connector, next it will have a hose the lets fumes out, remove that hose, and last would be th remove the valve from evap canister, the valve will be held in by a bolt or two, now not know the year or engine size sometimes the vent valve is bolted to canister or is bolt to body of car with another hose connecting it to canister, it is all the same you will remove the other hose and unbolt valve from bodyand replace. take note of hose locations and install new valve the same way.
The canister is located under the rear of the car, here is a picture of a vent valve to help you locate it, good day5_18_2012_6_35_38_pm.jpg
May 17, 2012 | Emission System for Pontiac Grand Am GT
Feul will burp mout of the filler cap no mater how slow I fill the car and the service engine soon light is on, how do I change the feul tank filler vent check valve?
Hi, your EVAP vent valve is likely stuck closed. The valve is under the car near the fuel tank. Remove the valve and check to see if it's stuck. You may be able to restore operation by cleaning the valve with carb cleaner. The valve should be open when no voltage is applied. I have pasted instructions below from autozone.com. Please let me know if you have any questions, and thanks for using FixYa.
jturcotte_1546.gif Vent Solenoid Valve
2.2L & 2.4L Engines
  1. Raise the vehicle
  2. Loosen the EVAP canister vent valve hose clamp and slide the clamp down the hose away from the EVAP vent valve hose connection.
  3. Remove the hose from the EVAP canister vent valve.
  4. Remove the EVAP canister vent valve by placing a pry bar between the valve and mounting surface, and moving the valve forward.
  5. Remove the clip from the EVAP canister vent valve harness connector
  6. Disconnect the EVAP canister vent valve harness connector.
To install:
  1. Connect the EVAP canister vent valve harness connector
  2. Install the clip into the EVAP canister vent valve harness connector.
  3. Install the EVAP canister vent valve by pushing the mounts into the original holes.
  4. Lubricate the hose end with lubricant.
  5. Install the hose to the EVAP canister vent valve.
  6. Slide the EVAP canister vent valve hose clamp down on to the hose connection at the EVAP canister vent valve.
  7. Lower the vehicle.
Apr 18, 2011 | 2004 Chevrolet Cavalier
I need to know where the thermostat is located for the Audi A8 V8 4.2 Quattro Automatic 2006
The thermostat is located in front of the engine, between V cylinder banks, for Audi A8 V8 4.2 Quattro Automatic. See pictures below:
Remove the thermostat housing (2 bolts) and the old thermostat. Note the orientation of the old thermostat (vent valve facing UP). Clean both thermostat housing and block surfaces and remove all traces of old gasket material. Install the new thermostat vent valve facing UP.
Please do rate my response. Thanks!
Dec 26, 2010 | 2000 Audi TT
OBD code P0746. Where is the Pressure Control
P0746 Pressure Control Solenoid Performance or Stuck Off
A transmission solenoid is an electro-hydraulic valve that controls fluid flow into and throughout an automatic transmission. Solenoids can be normally open or normally closed. They operate via a voltage or current supplied via the transmission computer or controller. Transmission solenoids are usually installed in a Transmission Valve body, Transmission Control Unit, Transmission Control Module or inside the Transmission and it helps regulate the pressure from the trans fluid pump.
P0446 Evaporative Emmission Control System Vent Control Circuit Malfunction
What does that mean?
Evap vent valve has only one purpose. It closes in order to seal the vent so the EVAP system can pressurize and ensure there are no leaks. Evap vent valve is usually supplied Batt. voltage with key on. The ECM's driver controls the ground, and when grounded, activates the valve (closing it). If the ECM detects a short to ground, and open,or a short to battery voltage on the control circuit, P0446 will set. Code also may refer to ECM detecting that EVAP system is unable to achieve or maintain vacuum during test.
Symptoms
There will be no obvious symptoms to driver, other than MIL illumination.
Causes
A code P0446 could mean one or more of the following has happened:
* Faulty vent valve
* Open, short or excessive resistance on Vent valve control circuit
* Blockage of vent valve
* Bad PCM
Possible Solutions
With a P0446 OBD-II trouble code, here are some things to try:
* Replace Vent valve
* Repair open, short, or resistance problem in control circuit
* Repair open, or short, or resistance problem in power circuit
* Replace PCM
Hope this help (remember rated this post).
May 12, 2010 | 2003 Lexus Gs 300
Po446 evap vent code where is the evap vent located
Some might have an ses p0446, evap emissions vent circuit low. If you take it to the dealer they want 300-400.00 to fix the problem. GM has a service bulletin on this condition and have the updated part for 180.00, thats suppose to eliminate this issue.
Basically the problem is, the evap purge vent valve gets clogged with dirt, especially if the truck is used in dirty conditions. Well I figured there had to be a cheaper way to cure this problem.
Here it is:
1) find the location of the vent valve; its under the truck, locate the charcoal canister on the front of the gas tank and trace the vent line to the vent valve.
2) Take the bracket loose with a 5/8 wrench.
3) Spin the valve around so the side with the hole is facing you.
4) Take an air compressor and blow the vent valve out.
5) reinstall and clear the code and it's fixed.
Now I know the updated part from gm is supposed to keep the valve from clogging ever again, but why spend the money when all you have to do is blow out the vent valve every 50k-100kmi and save your $$$!
Subject: DTC P0446 (Restricted/Blocked EVAP Vent Path) Set, Service Engine Soon (SES) Lamp Illuminated (Replace Hose/Evaporative Emission (EVAP) Canister Vent Asm) #02-06-04-037A - (02/02/2005)
Models:
- 1999-2003 Chevrolet Silverado Models
- 1999-2003 GMC Sierra Models
This bulletin is being revised to add model years. Please discard Corporate Bulletin Number 02-06-04-037 (Section 06 -- Engine/Propulsion System).
Condition
Some customers whose vehicles are operated in dusty type environments, such as farming or mining off-road type applications, may comment about the illumination of the instrument panel SES light, with a DTC of P0446 (Restricted/Blocked EVAP Vent Path) being set.
Cause
Dirt and dust intrusion into the EVAP canister vent hose assembly, resulting in restricted air flow, may cause this condition.
Part Number 15086429 Hose Asm-Evap Emis Cnstr Vent
Removal & Installation
Purge Solenoid Valve-2.2L (L61) Engine
  1. Disconnect the evaporative emission (EVAP) canister purge valve harness connector.
  2. Disconnect the vacuum pipe from the EVAP canister purge valve.
  3. Disconnect the purge pipe from the EVAP canister purge valve.
  4. Remove the EVAP canister purge valve and bracket.
  5. Remove the EVAP canister purge valve from the purge bracket.
  6. Inspect for carbon release in the EVAP canister purge valve ports.
To install:
  1. Install the EVAP canister purge valve on to the purge bracket.
  2. Install the EVAP canister purge valve and bracket. Tighten the purge bracket nut to 71 inch lbs. (8 Nm).
  3. Connect the purge pipe to the EVAP canister purge valve.
  4. Connect the vacuum pipe to the EVAP canister purge valve.
  5. Connect the EVAP canister purge valve harness connector.
  6. Remove the air cleaner outlet resonator.
  7. Disconnect the EVAP canister purge valve harness connector.
  8. Disconnect the engine purge pipe from the EVAP canister purge valve.
  9. Disconnect the engine vacuum pipe from the EVAP canister purge valve.
  10. Remove the EVAP canister purge valve mounting bracket attaching bolt.
  11. Remove the EVAP canister purge valve along with the mounting bracket.
  12. Installation is the reverse of the removal procedure. Tighten the bracket bolts to 71 inch lbs. (8 Nm).
Purge Solenoid Valve-2.4L Engines
  1. Remove the front purge pipe from the evaporative emission (EVAP) canister purge valve.
  2. Remove the rear purge pipe from the EVAP canister purge valve.
    NOTE The EVAP canister may have released carbon particles, which caused this part to fail, and may cause damage to other components. Check the EVAP canister for loose carbon before returning the vehicle to service.
  3. Disconnect the EVAP canister purge valve electrical connector.
  4. Insert a screwdriver between the EVAP canister purge valve and the mounting bracket in order to release the lock tab.
  5. Remove the EVAP canister purge valve mounting bracket attaching nut, if replacing the bracket.
  6. Remove the bracket.
To install:
  1. Install the mounting bracket and the attaching nut for the EVAP canister purge valve. Tighten the nut to 71 inch lbs. (8 Nm).
  2. Slide the EVAP canister purge valve onto the mounting bracket. Make sure the lock tab locks the valve in place.
  3. Connect the EVAP canister purge valve electrical connector.
  4. Connect the rear purge pipe to the EVAP canister purge valve.
  5. Connect the front purge pipe to the EVAP canister purge valve.
Vent Solenoid Valve-2.2L & 2.4L Engines
To install:
Hope this help (remember commetn and rated this).
Apr 21, 2010 | 2000 GMC Jimmy
What does code 446 mean on the 1996 Chevy Blazer?
P0446 = Evaporative Emission Control / System Vent Control Circuit Malfunction.
Check it, and before you replace the Evap Canister read this:
Models: 1999-2003 Chevrolet Silverado Models
Condition
Cause
Correction
After following the Service Manual diagnostic P0446 and determining that the EVAP canister vent valve is the cause of the SES light, replace the existing EVAP canister vent hose assembly with a new assembly, P/N 15086429. This new assembly has an enhanced filtering capability and a filter element that can be easily removed and cleaned. To ensure correct installation, follow the procedure below.
Raise the vehicle. Suitably support the vehicle.
Disconnect the EVAP canister vent valve electrical connector.
Disconnect the vent valve pipe at the EVAP canister.
Remove and retain the EVAP canister vent valve bracket mounting bolt.
Disengage, from the underbody, the two vent valve pipe clips securing the pipe to the underbody.
Remove and discard the complete EVAP canister vent hose assembly.
Position and secure the new assembly to the underbody using the existing hole and mounting bolt.
Tighten
Tighten the bracket mounting bolt to 12 N·m (106 lb in).
Install the two vent valve pipe clips into the existing underbody holes.
Connect the vent valve pipe to the EVAP canister.
Connect the EVAP canister vent valve electrical connector.
Lower the vehicle.
When properly installed, the new EVAP canister vent hose assembly will be positioned outboard of the original installation location. This new location provides clearance for accessing the filter element for cleaning purposes. To access the filter element, disengage the filter cover to valve locking finger by gently lifting the finger upward while simultaneously rotating the filter body clockwise. After approximately 45 degrees of rotation, the filter can be disengaged from the valve by gently pulling outward. The filter cover can then be removed and the filter element and body can be washed with soap and water. Prior to reinstalling, ensure that the body and filter element are dry.
Parts Information
Hope help with this.
Mar 18, 2010 | 1996 Chevrolet Blazer
Vent-Free Gas Fireplace Turns Off
check pilot light to make sure properly in place with thermocouple check gas feed for proper pressure and new doesnt mean free from defects -bad valve,thermocouple,temp sensor
Mar 04, 2010 | Heating & Cooling
Open vent central heating
yes it is possible toupgrade the system to a sealed one using a system boiler as you mentioned. the thing to bear in mind is to upgrade the radiator valves to pressure rated ones 10bar.
The probable cause of the over heating is down to the system being sludged up/cold feed blocked, or possible pump circulating problem?
I would recommend the installation of a magna clean filter to help keep the new boiler clear from system debris.I would definately power flush the system, if the system is a twin two port valve system then a automatic bypass should be fitted, all of this done by a corgi registered gas engineer
Kindly
Richie
Dec 18, 2008 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Watts Premier WATTS FV-4-1/4 Valve,vent,automatic 4A821 Logo
41 people viewed this question
Top Watts Premier Plumbing Experts
Donni Steen
Tom Chichester
Are you a Watts Premier Plumbing Expert? Answer questions, earn points and help others
