Question about Honeywell HE360A1027 Whole House Humidifier Humidifier
Install honeywell thermastate ct41a1002 - Honeywell HE360A1027 Whole House Humidifier Humidifier
Can honeywell 360 humidifier be installed on return plenum
Yes. Make sure to connect to HOT water line for better performance.
Nov 21, 2013 | Honeywell HE360A1027 Whole House...
Honeywell HE365A Humidifier
Here is a link to your humidifier manual http://dar.proflo.com/darmanager/Query?PRODUCT_ID=3520047&USE_TYPE=INSTALLATION
Jan 12, 2013 | Honeywell Humidifiers
How to connect the wires from the H8908A Humidistat and HE225 Humidifier to a carier model 58 STA090-14 furnace please? Thank you.
Not sure how much this will help you, but here is a link in pdf format to the Installation Manual, if you don't have one http://www.honeywellcentral.com/ssi/pdf/honeywell-commercial/HE220-Installation.pdf
If all else fails here is a number for Honeywell. Ask for Technical Support. (877) 841-2840
Feb 09, 2011 | Honeywell HE220A1019 Whole House...
Can the humidifier's housing for a Honeywell model HE265 By-Pass Humidifier be installed on the return air duct, or must the housing for this model always be installed on the hot-air supply duct just above...
Hello Which came first the chicken or the egg?The unit will operate perfectly in the supply OR return as I have installed in both.If there is more room & easy service access put it in there.
Sep 14, 2010 | Honeywell Humidifiers
A/C won't come on, replaced batteries, display reads -AC Honeywell chronotherm III Thanks for any advice !!!
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Aug 07, 2010 | Honeywell Power Humidifier: Furnace...
Honeywell HE260 leaks somewhere
Neither, even if the solenoid or humidistat stick, it should always drain properly. Is the unit mounted on the cold air return duct or the supply plenum? If it's mounted on the supply plenum, the water panel might be getting blown forward and spilling the water. High efficient furnaces also can leak water on the floor if its drain is restricted. If hum. is mounted on return duct make sure drain is clear by blowing through it. On Honeywell hum's I've seen the rubber hose from the solenoid valve to the distributor tray leak too, check the rubber 1/4" hose.
Dec 28, 2009 | Honeywell HE260A1010 Whole House...
Thermostat does not read current settings or respond to commands.
HONEYWELL WEBSITE:
Go to honeywell.com
Oct 08, 2009 | Honeywell Power Humidifier: Furnace...
Honeywell HE360A1027 Whole House Humidifier Humidifier Logo
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
