Question about Intuit QUICKEN 2014 DELUXE
Update Summary The Up date summary resujlts does not include the time of the update for each entry. Ccan I correct thiss? jerel Ferguson
Connection to itunes
Hi Yvonne
Several things you can try...
To check for updates, tap Settings > General > Software Update. You can also connect your iPhone, iPad, or iPod touch to iTunes and click Check for Update on your device's Summary page. To check that you're in range of a Wi-Fi router or base station.
  1. That your date, time, and time zone are correct. Tap Settings > General > Date & Time. Time Zone might list another city in your time zone.
  2. That your iOS software is up to date. To check for updates, tap Settings > General > Software Update. You can also connect your iPhone, iPad, or iPod touch to iTunes and click Check for Updateon your device's Summary page.
  3. To check that you're in range of a Wi-Fi router or base station. If you're using cellular service, make sure that cellular data is turned on from Settings > Cellular. If you're connected to cellular data, larger items might not download. You might need to connect to Wi-Fi to download apps, videos, and podcasts.
  4. That you have an active Internet connection. For help with your connection, check your device's user guide.
  5. To see if other devices, like portable computers, can connect to the Wi-Fi network and access the Internet.
  6. To reset your Wi-Fi router by turning it off and then on again.
Jul 07, 2016 | Apple iPhone Cell Phones
Tip
Ipod/ iphone software update
it couldn't be easier to update iTunes, just choose "Check for Updates" under the iTunes menu on a Mac, or from the iTunes Help menu on a PC. This checks both your iTunes software and your iPod software for updates. If both are up to date, you'll be told that iTunes is up to date, if updates for either are available you'll be offered the appropriate update. On a Mac you can even use "Software Update..." under the Apple Menu from your desktop.<br /> To check just for iPod software updates, connect your iPod to your computer, launch iTunes, and choose the iPod in the Source pane. From the iPod Settings Summary tab that appears, if the Update button is available-black, not grey-then new iPod software is available. Just click the Update button and follow the directions.<br />
on Mar 16, 2011 | Cell Phones
Is there a service bulletin for a Pontiac G5 for electrical issues?
their are 7 recalls on the 07 none are for an electrical problem with lighting system
http://www.pontiacproblems.com/recalls/G5/2007 and the following tsb from march 2010 is for flickering lights
  • TSB #PIC-5073B NHTSA ID #10034409
    • Date Announced: MARCH 01 2010
    • Additional Info: How to Fix
    Summary: CHEVROLET/PONTIAC: VARIOUS ELECTRICAL CONCERNS. SIR LIGHT, IP LIGHTS FLICKER/INOPERATIVE, PARKING LAMPS FLICKER/INOPERATIVE, TAIL LAMP DIM/INOPERATIVE, TRUNK OPEN LIGHT, RADIO INOPERATIVE DOOR LOCK INOPERATIVE, NO START, NO CRANK. POSSIB
    More Information »
ELECTRICAL SYSTEM:WIRING
  • TSB #PI-0817 NHTSA ID #10047261
    • Date Announced: SEPTEMBER 01 2012
    Summary: CHEVROLET/PONTIAC/SATURN: ENGINE FAILS TO START AFTER ENGINE CRANKS DUE TO FUEL PUMP WIRE HARNESS CONNECTOR NEEDS REPLACING, WITHOUT REPLACING FUEL PUMP COVER ASSEMBLY (FUEL PUMP FLANGE). MODEL 2007-2010 COBALT, G5, ION. *PE
    More Information »
ELECTRICAL SYSTEM:FUSES AND CIRCUIT BREAKERS
  • TSB #PIC-4578 NHTSA ID #10022806
    • Date Announced: JUNE 01 2011
    Summary: EPS/STR WHEEL CONTROL FUSE (#19) OPEN. *KB UPDATED 10/04/07. *NJ UPDATED 8/7/09. *PE UPDATED 8/1/11. *PE
    More Information »
  • TSB #PIC3385 NHTSA ID #10020916
    • Date Announced: FEBRUARY 01 2008
    Summary: REPEATED PARK LPS FUSE OPEN. *KB (ADDITIONAL INFORMATION) UPDATED 4/1/08. *NJ
2007 Pontiac G5 Recalls CarComplaints com
Sep 21, 2015 | 2007 Pontiac G5 Gt Coupe
Want to download ios 5.0
The current iOS is 8.1. If you want to update your iPad,
  • make sure you have iTunes on your current computer;
  • connect your iPad via the USB cable included with the iPad;
  • select your iPad in the iTunes menus;
  • click the "Check for Update" button in the Summary screen.
iTunes will display a message that will either allow you to update your iPad, or let you know that your current version is updated. For First Gen iPads, the latest iOS is 5.1.1.
Feb 15, 2015 | Apple iPad 9.7" 32 GB Wi-Fi 3G Black...
My iphone wont turn on it only shows the apple sign
.it couldn't be easier to update iTunes, just choose "Check for Updates" under the iTunes menu on a Mac, or from the iTunes Help menu on a PC. This checks both your iTunes software and your iPod software for updates. If both are up to date, you'll be told that iTunes is up to date, if updates for either are available you'll be offered the appropriate update. On a Mac you can even use "Software Update..." under the Apple Menu from your desktop.
Dec 15, 2010 | Apple iPhone Smartphone
IPhone os update was interrupted now the phone will not work and I cannot continue the install
Dec 13, 2010 | Apple iPhone 3G
My phone says;IPhone is disabled connect to itunes, could you please enable it for me please
Dec 12, 2010 | Apple iPhone Smartphone
My iphone won't sink up to itunes on my computer
Nov 28, 2010 | Apple iPhone 3GS Black (16 GB)
My IPhone has an apple sing on the creen and does not turn on
Nov 12, 2010 | ifrogz iphone3gstpb 3g iphone soft...
How do i put the date on. so when i down load the picture the date is there
Your camera may not have the date stamp option most do not anymore. Some kodaks do but very few. The reason is the metadata as it's called imbeds various details including the date and the time the picture was taken. Right click on the image and go to properties. Click on summary and if needed click on the advance tab on the bottom right of the summary window
Nov 10, 2010 | Cameras
Open Questions:
Intuit QUICKEN 2014 DELUXE Logo
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
