Question about Garden
Poulan po475N20s lawn mower stalls after start how do I fix it
SUPERMAN_B_1
  • 294 Answers
SOURCE: Need lawn mower manual
here's a link to the poulan lawn mower manual that you asked for http://www.oscar-wilson.com/MANUALS/AYP/HD145H42A.PDF have a good day and please rate this post.
Posted on Mar 19, 2009
ken_howard
  • 10 Answers
SOURCE: starts, runs, and dies...starts, runs and dies...starts, runs, an
Sounds like a common fuel problem you need to remove carb & fuel tank and unless you can get a compressor they need a good blast out you may even take carb apart & check diaghram they have very small jets in fact most lawnmower shops have a sonic bath for this
Posted on Apr 25, 2009
nobby63
  • 10 Answers
SOURCE: lawn mower stalls when engine is hot
first thing is to check that plug is not fowling up when hot due to motor burning to much oil.
Posted on Jul 26, 2009
SOURCE: POULAN 42" 19HP RIDING LAWN MOWER
42 inch poulan belt broke on mower deck diagram to replace new belt
Posted on Aug 10, 2009
  • 430 Answers
SOURCE: how to change oil in poulan 500 lawn mower
First remove the spark plug wire from the spark plug. Then tilt the handles down to the ground. It helps to have something you can slide the handles under or otherwise hold them down. Underneath the mower deck there will be a drain plug. You are in front of the unit facing it the drain plug will be at about 7-o'clock a few inches from the cranckshaft. It will have a square hole in it. Use an extension on a 3/8ths drive ratchet in the square hole and remove the plug. Be careful not to cut yourself on the blade, I usually remove the blade first and sharpen it while the oil is draining. Loosening the dipstick from the tube on top will help it drain faster. When its done draining replace the plug and reinstall the blade if it was removed. Then refill from the dipstick tube. The unit will take approx. 22 ounces of oil. Do not overfill.
Posted on Jan 04, 2010
Popular Pro 625 series. starts and runs but why does it die while cutting?
Poulan PR625Y22SHP Lawn Mower User Manual
homeappliance.manualsonline.com > ... > Poulan Lawn Mower
Poulan PR625Y22SHP Lawn Mower User Manual ... Briggs & Stratton 850Professional-Series Commercial Replacement Push Lawn Mower Engine (190cc, 7/8
Sep 11, 2015 | Garden
Poulan self propelled 22in blade hit a rock broke tip of blade starts then stalls
Did you bend the crankshaft. To check this out remove spark plug wire and tip mower on it's side and turn blade by hand and watch the shaft the blade is fastened on to. There should be no wiggle motion what so ever and if there is it may be bent causing the engine to not operate properly.
Sep 27, 2014 | Garden
Lawn mower running suggish
fuel problem???? ya know carb cleaner works on lawn mowers as well as cars .
Jun 07, 2014 | Poulan "Poulan" Push Mower
Lawn mower starts then stalls out and won't restart. Blades won't turn when the engine starts.
It's not getting enough fuel to the carb. It may have some water in the fuel so unless you are 100%certain it is good gas then I recommend draing all the gas out of the tank and also removing the carb and clean it.
May 18, 2014 | Poulan Pro 22" Self Propelled High Wheel...
Poulan pro honda engine stalls as auto choke lever moves
it sounds to me that there s a jet inside the carb that is still plugged
Jun 24, 2012 | Poulan Pro " Pro" Self Propelled Mower
I prime it; and it starts right up. Then, it stalls out, after a second ot two. Its a new lawn mower; and there is plenty gas in it.
Check your gas can. If you put dirty fuel in it, it will block the jets in the carburetor, preventing the engine from getting enough fuel. If you have a dirty gas can, you now will need to clean the carburetor jet.
Jul 25, 2011 | Poulan "" Push Mower
Locked blade - poulan push mower
Check the oil level in the engine...if the blade is locked up, so is the engine, sorry
Apr 05, 2009 | Poulan "Poulan" Push Mower
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
