Question about Williams Heating & Cooling
Arlec wall heater smells - Williams Heating & Cooling
I need an Arlec wall heater instruction on how to program it
If you type in the make and model online, the instructions should come up. YouTube may be your best option for this. Good luck
May 03, 2018 | Heating & Cooling
Hi I have just moved into a new house and there is a musty smell coming from the electric Dimplex heaters fixed to the walls. is there any way of getting rid of this smell? thanks# Mary
Are the heaters hydronic? (Heated water flowing thru tubes) If so, the musty smell is because the water has been leaking which is obviously a problem. I know you mentioned that they are electric heaters, but "musty smell" goes hand in hand with moisture.
Aug 03, 2011 | Heating & Cooling
Hello. When our Rinnai direct vent wall heater lights on it smells of gas. I do not recall smelling this before. It is a sweet smell not a sulfur smell. The filter is clean.
If it's a sweet smell. it's not gas. Gas smells like rotten eggs. There may be something inside the heater that's causing this odor. Remove the cover of the heater and look for some foreign that shouldn't be there. Perhaps, a dead mouse.
Feb 16, 2011 | Rinnai Heating & Cooling
Just installed this DV210SG Wall mounted panel heater, works great but smells like burning rubber, there is nothing burning, but sure smells bad! HELP!
There are manufacturing oils remaining on the metal. Allow it to stay on for about 1/2 hour. Open windows and door to ventilate. Smell will dissipate with use.
Nov 20, 2010 | Empire DV-215-SG Wall Mounted Panel Heater
There is a smell that is like a CO2 leak. It is not a natural gas smell.
it if smells or is burning yellow turn it off and have it serviced asap
Nov 01, 2010 | Empire GWT-25 Wall Mounted Panel Heater
We polyurethaned a floor now our propane gas heaters, when on smells terrible
hI it sound like the smell ha sgot in to the fire open the windos and try and burn the smell off but keep a eye on it when you do this , just for safety
Feb 06, 2010 | Desa International GWP20T GLOWARM Wall...
There was an electrical smell when the heat was on
Could be ,to be certain take it out the wall and check
Mar 07, 2018 | Cadet Manufacturing 67508 Coil / Ribbon...
Laser 72
Check the tank open/ if you fume detector you may detect it sometime some leak within distrbution hose clamp expanded hoses can be cause of leak.
Jan 08, 2008 | Rinnai Toyostove Direct Vent Heater:...
Heating & Cooling Logo
Top Williams Heating & Cooling Experts
Paul Carew
vance jones
Superior Maintenance
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
