Question about Jenn-Air 30 in. CCE3401 Electric Cooktop
Jen air jed 8430 hot indicator light is on but burner wont come on
5 Suggested Answers
Eddie Rentas
  • 59 Answers
SOURCE: jenn air jed 8430 electric cooktop control switch for rear burner
The cook top is attached to the wood frame by brackets, just remove the screws and the electric connection, make sure the power is off from the main box, it's a 220 volt wiring and then just lift the top off. to remove the glass, look around the edges and you should see some small screws, just remove them and the glass should lift off.
Eddie Rentas
Tupper Lake NY
Posted on Jul 23, 2008
SOURCE: Draft
Someone suggested the flapper needs replacing.
Thanks for your help.
Posted on Jan 20, 2009
  • 222 Answers
SOURCE: One burner control stays on high even at full low.
hi...the unit is have an waranty call the service center to check & replace the part.
tnx gerbee
Posted on Sep 13, 2009
SOURCE: JED 8320 fan and burner switch
http://www.whirlpoolparts.ca/index.php?PHPSESSID=f2330dc59be8bdd5f5463d5e0d1362f9
Posted on Oct 06, 2009
I have a Jen Air gas cook top that wont stop sparking when i turn burner on
make sure there is not a build up of oil or grease
under ignighter
Dec 20, 2013 | Cooktops
My jenn-air 8430 cooktop left front burner cycles off-on in the HIGH position. What could be wrong?
I am assuming your cooktop is electric and your have a glass top, if so the burners sensor is bad and you might need to replace the burner. Again before buying anything and for me to help you, I would need a full model number. Some model have plate sensors and with no plate/pot burner cycles. Most of the time I find the sensor in the burner cant detect the heat and this ends up being a safety issue to protect the unit. All this information is based on the premise you have an electric cooktop and a glass surface.
I hope this helps.
Oct 16, 2013 | Jenn-Air Cooktops
I just replaced and old '80s Jenn Air downdraft cooktop with a new JED 8430 and the fan blows rather than sucks. How do solve this problem? Its wired the same as the old one with the whitel and ground...
Best off to call a reliable service company such as Sears. If you just purchased it, the repairs will be covered under the manufactures one year warranty.
Feb 01, 2010 | Jenn-Air JED8430 Electric Cooktop
Oct 05, 2009 | Jenn-Air JED8430 Electric Cooktop
What's best tu glue my cooktop on my granite countertop?
I don't think I'd glue it down permenantly. I just had to replace the ceramic glass on mine (a JED 8430 ABD) after it cracked. Thankfully, it wasn't glued down so I could replace it pretty easily (ordered part directly from Jenn Air). But some sort of seal to keep food out from under the cooktop would be nice. I just wouldn't go permenant. The fact that you have to tape the down draft to the external vent should keep the cooktop in one place (plus its own weight).
Feb 28, 2009 | Jenn-Air JED8430 Electric Cooktop
Draft
Jan 18, 2009 | Jenn-Air JED8430 Electric Cooktop
Keeps clicking after lit
your ignition button is sticking down after you press it to light the burners, give it a few taps and clean underneath the button.
Aug 23, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Jenn air jed 8430 electric cooktop control switch for rear burner
Eddie Rentas
Tupper Lake NY
Jul 07, 2008 | Jenn-Air JED8430 Electric Cooktop
Jen Air left front small burner does not heat up.
these are cartridge elements corrrect? try reversing the cartidges, now the front small will become the rear small . does it not work in this position? and the newly placed front burner work?? this will determine if the proble lies within the cartridge or the switches
Feb 22, 2008 | Jenn-Air JED8230 Electric Cooktop
Jenn-Air 30 in. CCE3401 Electric Cooktop Logo
74 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
