Question about Apple Mac Mini Desktop
YM52828GTYW won't load up. Battery?
    Top Expert:
  • Apple Master
  • 14,162 Answers
Posted on Feb 22, 2016
My 2001 Acura CL Type S won't start. It has been
You said that you replaced the battery so in either case of new or another battery have a load test done as what you describe indicates a failing cell in the battery or loose t/dirty terminals.
Sep 22, 2013 | Cars & Trucks
Bmw starting problem
Have a load test done on the battery as it may be failing under load. Remove battery terminals and clean both posts and terminals with sandpaper until you see shiny
metal. The black coating is lead sulphate which has a high resistance to current flow both into and out of the battery.
Jul 21, 2013 | Cars & Trucks
V star 950 won't start
Hi, Joe you may have fried the ECM while trying to jump it from the Jeep otherwise the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
VStar 650 won start
Frustrated Yamaha Star Won x27 Start
2009 2012 Yamaha XVS950 Star Service Repair Manual DOWNLOAD Download...
OEM parts for Yamaha
YAMAHA XVS950A Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 31, 2013 | 2011 Yamaha V Star 950
Power comes on the bar bottom but won't come on the top and won't move and just stopped all itself while loading it
You need to allow the Battery to charge. If the Battery is not taking a charge, you need to replace the Battery
Apr 07, 2013 | Health & Beauty
Battery
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 19, 2012 | Samsung R540 Laptop
Batteries drain very quickly
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Apr 06, 2012 | Fuji FinePix S9500 Zoom Digital Camera
Truck will not keep and charge over night
The battery won't keep a charge or it won't when it is in the truck? Will the battery keep a charge if you put it on the charger and then unplug it overnight, all of this out of the truck. Then in the morning will it start the truck. If not your battery is bad. If it keeps a charge and will start the truck and then it goes dead after several hours, your truck is drawing a load on the battery. You will have to find what has been left on or shorted out.
Feb 05, 2012 | 2000 Dodge Ram 1500 Truck
I put a new battery in my hyundai sonata and now the lights inside the car wont even come on. it won't do anything. If you jump it it will start but thats it it won't start back up after you turn...
Did this occur straight after changing out the battery, or after sitting with the new battery installed?
Have you checked the new batteries voltage and voltage under load, eg. (Voltage when headlights are on) could be a flat new battery.
Or could be load on the battery after key is turned off, something draining the battery overnight like a boot or interior light, radio left on ect.
Unlikely a short, or you would be in a world of burnt wires from the battery cables.
Feb 26, 2018 | Hyundai Motor 2003 Sonata
Honda Pilot 2003 won't start. batter is good. seems to be an electrical issue because starter won't turn at all and there are strange clicking noises when key is turned
I would be re-checking the battery. Make sure that when you have it tested they do a "load test". Sometimes a battery can seem good, but be bad when there is a large load placed on it. This test will reveal if that is the case. It could also be a starter problem, and it is possible (but unlikely) that it is a wiring problem.
Sep 19, 2011 | 2003 Honda Pilot
Hello. At first, the indicator light that shows whether the battery is loading/getting empty etc. failed. As I thought it wasn`t important I continued using the laptop. Then the battery loading adapter...
Most probably this is caused by the battery charging circuit inside your laptop. It looks like it is not charging the battery. If this is the case you won't be able to fix it yourself. You and should send it for repair.
Feb 28, 2011 | Computers & Internet
Apple Mac Mini Desktop Logo
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
