Question about Boating
Fuse diagram 2004 tundra
My right turn signal flashes as if I was making a right hand turn. Does not go off even when the left signal is engaged
motor1258
  • 6674 Answers
SOURCE: LEFT TRAILER TURN SIGNAL DOES NOT WORK
I'd get a 12vdc test light if you don't have one already & start from plug, and keep probing back from there. It may be as simple as a bad connection under truck where joined into harness.
Posted on Nov 29, 2008
tripletauto
  • 1450 Answers
SOURCE: Left signal light doesn't turn off after I turn left
you need a new switch.there is a cam that drops down when you apply turn signal and it is stuck this is called a multifunction switch. should still be under warranty
Posted on Dec 08, 2008
  • 196 Answers
SOURCE: electrical problem
Find the ground wire on one of the lights and add another ground wire to a good clean metal surface and see if that fixes the problem. It defently sounds like a ground problem at one of the lights.
Posted on Jan 07, 2009
  • 49 Answers
SOURCE: right turn signal stays on will not flash left works.2001 jimmy
its your blinker box.. all major lights run through there
Posted on Aug 04, 2009
pops296
  • 174 Answers
I have seen once before that the fuse box was bad on a 2003 Dodge 3500. I had power in and nothing out. We had to replace the box. Not cheap! Hope it is simple like a loose connection though. I think I had to pull the inner fender on the drivers side to access the bottom of the fuse box. Pain in the ****, but...
Posted on Oct 01, 2009
The fuse for a right turn signal on a 2001 Buick Park Avenue
The left an right turn signals get there power from same fuse ,HZDT/SG fuse 15amp in the left under hood fuse box. through the turn signal hazard flasher module. Here is how they work .
Turn Signal/Cornering Lamps
The HZDT/SIG fuse in the fuse block - underhood - left supplies battery positive voltage to the turn signal/hazard flasher module and have ground at G202. The turn signal lamps may only be activated with the ignition switch in the ON or ACCY position. The T/SIG fuse in the fuse block - underhood - left supplies battery positive voltage to the turn signal switch. When the turn signal switch is placed in either the left or right position, current flow is from the turn signal switch assembly to the turn signal/hazard flasher module. The turn signal/hazard flasher module then sends an on-off voltage signal to either the left or right turn signals and their instrument cluster (IPC) indicator. When the hazard switch is pressed, all the turn signal lamps will flash including both IPC turn signal indicators. The left turn signals have ground at G106, G400 and at G402. The right turn signals have ground at G105 and G400. The turn signal switch supplies battery positive voltage to the cornering lamps, the left cornering lamp has ground at G105 and the right cornering lamp has ground at G106.The turn signal switch or the turn / hazard flasher module is bad or there is a wiring problem. Go to you tube an check out a few videos on basic electrical testing ,then get a DVOM - digital volt ohm meter , an wiring diagram an trouble shoot the circuit . There may even be a video on test turn signal circuit .
Dec 04, 2015 | Buick Cars & Trucks
I trying to locate the turn signal flasher relay module
Makes no diff left or right turn, there's one flasher under the dash next to steering columb. Possibly in the fuse panel, but I don't think so. Turn the switch on and flip the signal, listen for the relay/flasher to be clicking. That's the easy way to find it. Even if all you can do is feel the unit flashing. Pull it down and change it. Just plugs into the accessory block.
Aug 26, 2014 | 2004 Kia Spectra
Turn signal light right flash
flasher/blinker is busted. this is located under your dash board. remove steering column cover, turn on LEFT turn signal (yes, the one that is working), then you will hear a clicking sound. locate the relay that causes the sound. there you can see 2 relays (one for LEFT, other one for RIGHT turn),replace busted one.
Jun 11, 2013 | 2002 Toyota Tundra
Turn signals not working, Toyota Tundra 2000
Hazards work only when lights are off. Left signal light stays lit on the dash and does not blink and is stuck on (lit up) when lights are lit. If I place hazards on while lights are on only right side flashes and whole dash lights flash too... I replaced the flasher relay and it still does not work. Suggestions anyone? Thanks!
Apr 30, 2012 | 2000 Toyota Tundra
Wiring diagram for 2004 gsxr 1000 turn signals
The circuit is this:From your fuse box runs a Light Blue wire to your left handlebar switch.That wire is "live" and transfers power to the turning signal switch.That switch depends on what direction you push it, transfers the power to:1) Light Green wire that powers the right hand turning signal bulbs (front and back)2) Black wire that powers the left hand turning signal bulbs (front and back)Each bulb uses a Black/White wire to ground and close the circuit.
Feb 04, 2012 | 2008 Suzuki GSXR1000
Turn signal makes the dash lights flash
97 chevy blazer left turn signal makes the dash lights flash then when i turn parking lights on left signal stays on constent when engaged
Jan 16, 2010 | 1995 Chevrolet K1500
02 tundra elect problemblowing fuses when in reverse/using left signal
Trailer? Am I to assume that you have a trailer harness? If so, that may be where your problem lies. Disconnect the trailer harness and plug everything else back together.
Oct 06, 2008 | 2002 Toyota Tundra
Boating Logo
75 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
