Question about Westinghouse LTV-27w6 27 in. LCD HDTV
EU24H1G1 tv always says auto scan.
I try to run an air scan but, always says please run auto scan
How to run channel auto scan?
You need to go into the TV setup menu
Aug 19, 2017 | Televison & Video
How can i get the channel auto scan on my Hisense 55h6sg tv to find any channels.
If it is asking for zip code you have not told it to scan for over the air or antenna channels when it asks air or cable
Dec 12, 2016 | Hisense Televison & Video
What does "please run auto channel scan " mean?
Auto channel scan finds the local channels available over the air so that when pressing up/down channel it only goes to those channels
Mar 17, 2015 | Konka K2098U TV
How do I run channel auto scan on Calypso TV
try going to settings ,menu then hit present or auto scan
Oct 26, 2014 | Calypso 26"" LCD Hd TV
Antenna set up, channel scan
Asker resolved own issue.
Mar 17, 2014 | Televison & Video
Display says please run auto channel scan
It sounds like it is not seeing any signal. Do you have the input set for the proper type? Air or Cable
Check your RF connection to ensure you have a signal coming into your television.
Nov 16, 2013 | AOC L22W898 22 in. LCD TV
Can't get rid of "Please Run Channel Auto Scan" stays on tv screen
for some reason it is not seeing you cable signal. you will need to make sure you have it set up for cable and not air. check your input options, like tv/av/hdmi/ ect hope this helps
Aug 05, 2012 | Dynex DX-LCD32-09 LCD TV
When setting up a new TV, it keeps telling me to "Please run channel auto scan." But it also states that if I sellect Cable/satellite, that the tv does not need to run the auto scan. When you...
you need to select cable from off your remote and run the auto scan.even if it says you does not need to run auto scan still run the auto scan.good luck.
Sep 25, 2011 | Dynex Televison & Video
Westinghouse LTV-27w6 27 in. LCD HDTV Logo
70 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
