Question about Pioneer Audio Players & Recorders
Pioneer vsx-522 no sound intermittantly
4 Suggested Answers
Gurudristi
  • 98 Answers
SOURCE: Pioneer VSX-D209 receiver shuts off when too loud
Dear Tabasco,
Your receiver is basically going into protect mode.
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Take out all the wire and put them back again if necessary..
Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Just check your speaker as well....whether they play all right thru another receiver or amplifier. its posiible they might be shorting inside. A little frayed wire could also trigger the protect circuit in your receiver.
I hope this should solve your problem.
If everything else seems all right and still your receiver shut down when you raise the volume then it possible that there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. If not, then a local service center will change the local labor rate.
Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Best of luck! Thanks for using FixYa!
Posted on Apr 21, 2009
SOURCE: I have pioneer vsx 1000,its turn on but dont have sound
maybe the audio amplifier IC are damaged
Posted on Jul 13, 2009
  • 1054 Answers
SOURCE: i want to connect a ps3 to my new pioneer receiver
Make sure that whatever input you are using is set for hdmi audio. You may have mistakenly changed the input mode.
Posted on Jan 10, 2014
Won't turn on
try holding the 'advanced surround' and power buttons. It should turn on. If it turns right back off, then you have a problem in the amp that needs repair
Aug 08, 2014 | Pioneer Vsx-522-k A/V Receiver
Pioneer receiver no sound
H means it is in hdmi input mode. you should be able to change that, try using the signal select button on the remote
Jul 23, 2014 | Pioneer Vsx-522-k A/V Receiver
I want to connect a ps3 to my new pioneer receiver
Jan 10, 2014 | Pioneer Audio Players & Recorders
Psw111 hook up to vsx-522 subwoofer
Just use one of those jacks. Then turn the frequency select dial all the way up. This will work just as well.
Apr 21, 2013 | Yamaha 5.1-Ch. Surround Sound Home Theater...
My pioneer vsx-522 turns off by itself
Most likely, you have a condition known as DC Offset, meaning a damaged amplifier. For more information, please visit my website at audioserviceclinic.com. You may contact me directly through the website. Thank you.
Feb 19, 2013 | Pioneer VSX522K
Sound cuts out
No, this sounds like a speaker problem to me.
It sounds like the voice coils in your speaker(s) have been fried.
What happens is the part that is burnt does not funtion, but as you increase the volume/voltage the speaker "jumps" foward to a section of voice coil that is not as damaged.
Check your speakers!
Sep 07, 2009 | Pioneer VSX-816-K/S Receiver
Receiver problem
Try this, it may work for you.
1.)Plug the unit into your mains voltage.
2.)Depress the enter and advanced surround buttons (on the front panel of receiver) at the same time for
at least 2 seconds, you should hear the relay tick and front panel should light up.
Mar 07, 2008 | Pioneer VSX-D514 Receiver
10 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
