Question about Linksys Computers & Internet
Does router wrt160n have both 2.5GHz and 5GHz
I have set up my router on a Vista laptop. Works fine.
I am trying to get a desktop with XP to access the router
but get a red x. The program says the wireless PCI card is working.
The card is a Linksys WMP11 2.4GHz 802.11b.
The cd is Setup Wizard ver.1.2.
The desktop has basic Windows XP with no sps.
Would like to get it on the internet to update the os and other
software. Thanks. Bill
  • 1,684 Answers
Hello Bill,
The problem sounds like you have the router set to WPA security. The WMP11 cards do not support this security standard, they only use WEP 64 bit and 128bit. If you attach to the router with your vista machine and go into the configuration settings and change the security level to WEP you should be able to get online.
Buddy
Posted on Jun 18, 2009
Router's wireless function not working
please visit my profile bro. coz i posted there some tips about routers configuration and internet connection errors. here's the URL: http://fixya.com/users/chael890
May 31, 2010 | Computers & Internet
My laptop running window 7 64 bit connects to linksys wrt160N but internet connection is not available? Connecting via wire to the same router works fine. While the internet works fine on the other...
Check the IP address on the Vista wireless network connection. Make sure that there is not static IP address on the wireless connection. That could be one of the reason.
Apr 14, 2010 | Linksys WRT160N Wireless Router
I have a desktop and a laptop (new for xmas) and I want to set up the laptop to the wireless-N Router Model WRT160N. I am set up with internet through a bundle system through our television. Do I plug the...
first a couple of things.
if your router has wireless support your laptop (if new) should have a wireless adapter built in, so basically your destop computer can be wirely plugged into the router and your laptop shoud "connect wirelessly" to your adapter
so this is how your set up should look like
desktop
--cable-- = - cablemodem - = linksys router = ----- wire----- desktop
laptop
--cable-- = - cablemodem - = linksys router = ))wireless))) laptop
you need read up a bit, here are some links that will have info you need
manual for wireless configuration (select the proper revision for your router and check user manual)
configure wireless network for vista
read up and if you have any questions post back.
hope that helps.
Dec 26, 2009 | Computers & Internet
Linksys wrt160n will not broadcast the internet wireless or ethernet it will however broadcast a connection to the router not the internet. I have tried to re-set it, power down, nothing works. I have not...
Your Linksys WRT160N is a router that can be accessed via CAT-5 cables and wirelessly. You must configure the router though, for wireless use. If this is not configured or not configured correctly, then you may have problems using it wirelessly. Laptop computers usually use the 802.11g mode, not the 802.11n, at 54MB or with the right NIC in a desktop you can get 108MB. If it was working then quit without your doing anything, you may have to replace the router, but I doubt it.
Nov 08, 2009 | Linksys WRT160N Wireless Router
Desktop will not connect uless wireless is active.
your laptop is most likely set as main pc,you will have to changeI your settings make sure both pcs are set to home and to share networks.you may have to play with the wifi settings to.
Oct 21, 2009 | Linksys WRT160N Wireless Router
Getting Local Access Only on Vista wireless Machine. XP and vista wired working fine
Look at how your access is set up --- if you set it up as Public this happens, and is fixed byv setting it as Private.
Oct 20, 2009 | Linksys WRT160N Wireless Router
Lose Internet connection on wireless network
Go to the router configuration and change the options so you could use both of them, there is an option says only one type of connection or both of them, change it to both, and everything will be fine.
Regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Aug 02, 2009 | Zyxel Prestige 660HW Wireless Router...
Wireless connectivity
You probably set an access list on your router
connect to Router using a LAN cable and check if you can browse.
Then
Check your access list on router.
Disable it if you cannot add your PC wireless adapter MAC address
Jan 04, 2009 | Computers & Internet
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
Desktop works (direct to router), laptops cannot connect
first of all make sure that the wireless settings of the router match the settings of your wireless computer.
make sure also that there are no friewall or security programs running in your computer because they can interfere with the wireless connection as well.
Aug 17, 2008 | NetGear RangeMax WPN824 Wireless Router...
Computers & Internet Logo
695 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
