Question about Montel Williams Living Well Healthmaster Elite
Motor leaking dark liquid
Motor is sounding very loud and there is a black oily liquid leaking out and the center where top is attached to motor is loose
Hi, my wife and I purchased the Health master blender about 6yrs ago. I recently noticed that the liquid was leaking from the bottom of the container. The blade is totally loose. How can I tighten it if at al?
Posted on Jun 01, 2016
How it is done so that the axes of a blender or mixer, and especially the ones of the propeller of a submarine, under great pressure, not leak the liquid?
Good question.
Axles are generally left with cars and trucks.
That's because an axle transfers energy to more than one place by means of gears and cogs, like to a pair of driving wheels at right angles to the power direction..
What you refer to are spindles, prop shafts and other things.
For the sake of simplicity, the seals you speak of are made of rubber rings held by metal bands around the spindle squeezed very tight with oil trapped around the joint. That keeps the water out most of the time.
In bigger machines, the oil seal is often made from a tough kind of leather (true !) ...leather is a really good water proof material under heavy pressure and heat providing it's kept "wet" by oils or waters.
Blenders spindles tend to use rubber "O" rings around the shaft because there's not much pressure, it's enough to keep your milkshake from leaking into the blender.
Oct 17, 2016 | Blenders
Why does my blender leak?
hi,
sounds like the bearing assembly went, right where the motor connects to the blade, you can get a replacement base from them, have to find the model number and go to their website. doubt you burnt it up. cuisinarts supposedly are commercial quality.
jm
Jul 20, 2017 | Cuisinart SPB-7CH SmartPower 40-Ounce...
Have had my Vita-mix 5000 for several years with no problems. Now, it leaks oily, black liquid around the base, and jerks erratically when the blender is set on the lowest setting (#1 of 10)/variable.
Is it getting hot when you operate it? If you run a mixer for a long
time, the motor will get very warm. On the older units, when the
motor overheats, the various parts of the motor and its container
may start to melt. Mixer motors are not designed to last forever and
a replacement motor may be available from the manufacturer.
Another way is to purchase another similar mixer as you can on
eBay and swap parts.
Aug 21, 2011 | Vitamix 5000 Work Top Blender
There is liquid leaking through the bearing on the base that adapts to the motor. Is there a service repair center in my area, my zip code is 60415?
Oster.com shows one Oster service center in Illinois:
(http://www.oster.com/ServiceCenters.aspx?state=Illinois)
Household Appliance Sales and Service 7034 North Milwaukee Avenue
Niles, Illinois
60714-3707
Phone: 847-647-8250
Fax: 847-647-2214
It's a roughly 45-minute drive from your zip code, according to Google Maps. You may want to call them with a description of your problem and see if they can service. There are also several locations in PA that will service Oster blenders.
Apr 30, 2011 | Oster 4093-8 Osterizer Classic Blender...
Hand blender bottom shaft (blade attachment) leaks oily stuff
In the old days, there was a packing in certain places of certain applications.
Often it looked like a piece of string, usually a grayish color, as it often was impregnated with grease.
I would start with an automotive parts house, but it must be old and have old folks to help you, as young ones have no such experience.
You could also try a plumber, they used some packing string.
As a matter of fact, I have some in my plumbing repair parts, though I've no used it in 30 years.
You might have to use this each time you use the machine.
It should be not expensive.
God bless your efforts.
Mar 26, 2017 | Kenmore Blenders
Seems like motor has lost power
This sounds like the black rubber coupler has broken. The teeth often get knocked off. Have a look at the part shown in hte pictures here:
http://kitchenaidblenders.co.uk/Home/tabid/36/p/Two-%282%29-KitchenAid-Blender-Coupler-%2b-WS-Fitting-Tool-9704230_2plusWS/ProductID/175/Default.aspx
Jan 22, 2010 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Broken Part
Hi, i read your are having trouble with the tap on your blender. We pulled our blender out of the box and used it for the first time and it leaked through the base, through the motor all over the bench top.
At first i thought the tap was leaking too, then I investigated a little bit and found it was leaking through the white tension clips on the inside of the black base.
Then i discovered that there is a recess for an "O" ring, which seals the glass jug to the black base thus solving the leak.
However there was no "O" ring in the recess and now I am trying to find a replacement one.
Hope this helps.
May 22, 2009 | Russell Hobbs 3902US Work Top Blender
Black plastic "ring" that fits over the spindle on the motor base snapped
I just bought a replacement part on ebay. It cost about $11, which included shipping. buy-it-now-store.com
Jan 16, 2008 | Cuisinart SPB-7 SmartPower Work Top...
Base leaks heavily when any liquid goes in!
make sure the seal gasket is between the base and the blade base- 99% it will solve your problem!
Aug 27, 2007 | Tefal MagiClean Work Top Blender
Montel Williams Living Well Healthmaster Elite Logo
328 people viewed this question
Top Montel Williams Blenders Experts
eyecam
Ross Keen
Are you a Montel Williams Blender Expert? Answer questions, earn points and help others
