there might be a problem with your cord/cable (a cord/cable that will enable you to connect your cam to PC).pls try to connect the cable firmly if still does not work pls try to get your memory card from your cam and put it in a card reader. That way you may be able to download pics from your cam to your PC.
NOTE: some card readers may need an adapter to be fitted in an SD size card for example i have an micro SD memory card i will need an adapter to fit the micro SD to SD.like this picture
youll be needing this to insert it in a card reader
this is an example of an ordinary card reader
this is an example of a universal card reader
use these following devices and you will be able to download pics from your cam to PC.
i hope i was able to help you! good luck!
