Question about Sony PSP (Piano Black)
Power button is on, battery is good but there is nothing on the screen. What could be the problem??
  • 157 Answers
Ur software is crasss
Posted on Jun 18, 2009
Even when i press the power button it still doesn't switch on. what now?
You have to touch all there buttons at the same time, then slide the screen up. If your screen is already up slide it down then slide it up. If doing all that doesn't work, make sure you have the right batteries!
Jun 18, 2012 | Mattel My Meebas Interactive Pet
My toshiba l500-02h is only showing blank page with booting.
Hello, Does it sit there and do nothing? Sometimes all that is needed is the battery pulled (disconnect power cord as well) Press and hold the power button down for about 5 seconds. Put battery back in and connect power cord. Now try booting. If nothing shows on the screen, the next step would be to connect an external monitor or TV (if you have one) to the VGA or HDMI port. If a picture shows on the monitor / TV but still not on the laptop, you may have a burnt out display... which is expensive to fix. You may find some good prices for screens on dbay.
Chris
May 11, 2011 | Computers & Internet
When I press the switch button the power led comes up but nothing shows on the screen, the cpu fan rolls for few few seconds and stops
try to do a power drain.... unplug the power chord... then remove the battery.... while the battery is out... press and hold the power button for 30 seconds.... then put the battery back in and then the power chord.... then try booting it up.... if it works well and good.... if it does not and u see all the lights but not anything on the screen, try with an external monitor just to check if its an issue with the lcd screen.... if its working on a different monitor, u know what to do... take it to a service center....
again if nothing works... dont wait.. take it to a service center
Mar 18, 2011 | HP Compaq nc6000 Notebook
Black screen on Inspiron 1525
This is a common problem. The problem is probably a bad charger. Take charger to a repair shop and ask them to check it. If it is good then problem is inside the laptop and probably the power connector.
Please rate this answer as a rating is all we get for answers. Thanks
Apr 11, 2010 | Dell Inspiron 1525 Laptop
My laptop fell down and now my screen does not display anything
try to press and hold Fn and F8 - this is to toggle screen setting to ext and back to LCD on laptop. if nothing happens turn off computer by pressing power button, unplug the ac adapter, remove the battery. remvoe residual electricity from computer by pressing power button 10 times. just plug again the ac and leave the battery out. Pres and hold the letter D and while holding that press the power button once and release both of them. it will perform the built in self test on the lcd. if nothing happens, turn off computer. press anf hold Fn and while holding it press power button. it will perform diagnosis on computer. if still nothing happens need to repalce motherboard and LCD.
Mar 03, 2010 | Dell Inspiron 6000 Notebook
Cannot turn on my LG Notebook anymore
Will the laptop boot with the power adapter connected and battery removed? If so, boot it up and install the battery once it's booted up. If okay now, the battery was just really really drained. If okay with no battery but no good with battery, the battery may be bad, or something in the charging circuit may be defective - keep the battery out or replace mainboard ($$$$ - get a new laptop)
If no good with ac adapter and no battery, test the adapter with an electrical meter. It should be putting out 18-19 volts. If not, try a replacement adapter. If adapter tests good but laptop won't boot with no battery, likely the mainboard.
Also - remove hard drive and try to power up. If good, replace hard drive. If no good, reinstall hard drive and remove ram and try to power up. If it powers up, clean the ram and slot contacts gently with a pink pencil eraser and try testing each ram chip in each slot, 1 chip at a time. If still no good, start shopping for a new laptop.
Let me know if this helps or not...
Aug 08, 2009 | Computers & Internet
I am so confused because i can´t turn on my iPhone the screen is still black This is what i tried... 1. Pressing the Power Button (Result: Nothing happens.) 2. Pressing the Power Button and the Home...
we need more info on the phone itself, has it recently been subjected to abuse water or physical? if so maybe the battery itself is damages also try to bull the battery and leave it out for a full minute! if you can get power and just not on the screen then maybe the lcd digitizer is damaged and needs replaced! (please write back with any result or questions)
Jun 12, 2009 | Apple iPhone Smartphone
My computer dont have a display
if its a desktop, run monitor self test, unplug cable of monitor from back of pc, turn on both monitor and computer, if nothing on screen. monitor needs to be replaced., if its laptop, tkae out battery and unplug ac , press and hld power button for 5 seconds to drain power, put battery back and power on system then immidiately press f2, if it brings to you a different screen, good. but if not. display is not working , the hardware part.
Jan 14, 2009 | Computers & Internet
Sony PSP (Piano Black) Logo
61 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
