Question about Black & Decker 3 x 21 In. Dragster Belt Sander
Black and decker 3x21 dragster belt sander sand paper stuck in roll
There is sandpaper stuck in behind the back roller I need to get it out but can't and it is preventing the sander from working.
2 Suggested Answers
  • 302 Answers
SOURCE: Black & Decker 3X21
I have one of those and I just smack the front roller ahead with a brass or plastic hammer. I hit the movable bracket that the roller is attached to. It takes a pretty stout whack to do it though. hope this helps you
Posted on Jan 14, 2010
Testimonial: "Thanks for the help, I wasn't sure if there was some magic button I was missing. Tks, jw "
The big roller at the back that spins has unscrewed and i cant seem to tighten it back on. is there a trick to this?.
generally you would use a strap wrench to hold the roller and then something to hold the gear to reseat the rear roller.
Sep 13, 2011 | Black & Decker 3 x 21 In. Dragster Belt...
The sandpaper keeps sliding off the sander everytime I turn it on. Even when I turn the dial it to tighten it or move it over it keeps on sliding off.
You need to turn the dial slowly. If the belt starts to come off turn the knob in the other direction,slowly until the belt is centered. Doing it slow is the trick.
Jun 04, 2011 | Black & Decker 3 x 21 In. Dragster Belt...
CHANGE THE SANDPAPER IN THE BELT SANDER
there should be a lever that will loosen the tention on the belt so you can get it off. be sure to put the new belt on with the arrows facing the rotation (some sanding belts do not need to be oriented this way, but check) otherwise the belt will come apart after a few rotations.
Mar 22, 2011 | Black & Decker 3 x 21 In. Dragster Belt...
My belt broke while sanding. part of it is tightly jammmed behind the roller, How do I get to it???
UNPLUG TOOL and then what you will have to do and this will take some time is using a good pair of pliers start pulling the belt out a little at a time and you might have to cut some on occastion but this will work, I have done it many times
Sep 25, 2010 | Black & Decker 3 x 21 In. Dragster Belt...
Black & Decker DS321 - ripped the rubber off the drive roller. Now got it in pieces, all cleaned up, but I dont see how to remove the driver roller from the Drive Shaft and belt guide assembley.
looked at a schematic and the drive roller screws onto the drive shaft, I don't see where is a locknut on the outside but the shaft is threaded, it moght be left hand thread. If there are 2 holes in the gear see if you can find a spanner wrench from a grinder and secure the roller and loosen the gear.
Sep 12, 2010 | Black & Decker 3 x 21 In. Dragster Belt...
Power cord stuck in belt
Common problem, disassemble, get the cord out, get some new power cord, and re-terminate the new cord into the Sander, and reassemble. This usually doesn't do too much harm, looks bad though.
Mar 23, 2010 | Black & Decker 3 x 21 In. Dragster Belt...
Sandpaper does not stay in place
re align the end rollers as one of them will be out
Mar 22, 2010 | Black & Decker 3 x 21 In. Dragster Belt...
Black & Decker 3X21'' belt sander (#7447)- pushed front roller in to put on new belt, can't get it to spring back out. Jim in Flippin
Jan 14, 2010 | Black & Decker 3 x 21 In. Dragster Belt...
My black and Decker dragster has simply stopped turning on. i need to get it dissembled to check the switch
go to Dewaltservicenet.com with your model number and you can download a parts breakdown for the tool for disassembly.
Nov 16, 2009 | Black & Decker 3 x 21 In. Dragster Belt...
Black & Decker 3 x 21 In. Dragster Belt Sander Logo
Top Black & Decker Tools & Hardware - Others Experts
Rabbit Brains
Rabbit Brains
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
