Question about Baby Care
How much water goes into a avent 039 sterliser
Avent Sterilizer leaking water...
You are in the car and trucvk problem section, please repost.
Dec 15, 2013 | Cars & Trucks
I bought my avent sterilizer 4 months ago when I gave birth to use with my bottles. I was given as a gift 2 NUk bottles that I added to my avent formula feeding collection of bottles and sterilized in the...
Sounds like the unit operates at a high temp. The Avent bottles are a bit thicker and withstand the higher heat. Either switch to all Avent bottles or try other methods of sterilization for the thinner bottles.
May 07, 2011 | Toys
Ive brought a avent streliser but threw thin instuctions away i dont know how long to strelise the baby bottles for in the microwave
I googled it, here's what I found from e-how. Hope works for you.
Avent Bottle Sterilizer Instructions
By Christine Lehman, eHow Contributor
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Many parents like to sterilize their baby's bottles before use. Avent makes baby feeding equipment including bottles, nipples and breast pumps. They also make steam sterilizers that can be used to sterilize these items before use.
The Sterilizer
1. It is important to be familiar with the components of the Avent sterilizer before operating it. The base of the unit has a stem on which the racks holding the bottles (or other things to be sterilized) are placed. The bottom rack slides on the stem and lies near the bottom of the unit. It is made of mesh and will allow steam to rise through it while keeping the contents on the rack. Three other racks are available: two flat mesh racks (which look just like the bottom rack) and a rack with rings to hold bottles in place. Spacers are placed on the stem to separate the racks. If you wish to have more room between the racks, simply use more spacers. A lid fits over the entire unit.
Sterilizer Use
2. To use the sterilizer, the reservoir first needs to be filled with 90 milliliters of water. Using exactly this amount is important because if you use less your sterilizer may not work properly, and if you use more the cycle will take much longer than normal. There is a line in the reservoir marked "max" that should remain at or below the water line. You can use the milliliter marks on one of your Avent bottles to measure this volume exactly. Once the water is in the reservoir, assemble the baskets in whichever configuration suits your needs (for example, use only the mesh separators if you are sterilizing your breast pump and use the bottle rings to stand any bottles up that you are sterilizing) and load them into the unit. If you have small items to sterilize, also sterilize the pair of tongs that comes with the unit. Place the lid on the sterilizer. Plug the cord into the sterilizing unit, then into the wall. Turn the Avent sterilizer on and wait for it to cycle. Although the duration of the cycle will vary from load to load (small loads take longer to sterilize), this should take approximately 8 minutes.
After Sterilization
3. Wait 3 minutes once the cycle is over before opening the Avent sterilizer. Before then, the unit is extremely hot and the steam could burn your skin. In the meantime, unplug the unit and wash your hands. Remove the lid carefully and begin removing the items from the sterilizer, using the sterilized tongs if necessary. If you do not remove the lid immediately, the items in the sterilizer will remain sterile for up to 3 hours after the cycle is complete. Once the sterilizer is empty, pour the remaining water out of the reservoir.
Dec 18, 2010 | Microwave Ovens
Hi. I bought a Philips Avent Digital Steam Steriliser about 3 monts ago but it's not working now. No light on it, no function. Is there any tecnical service of Philips ın Cyprus for Philips...
first of all have you check the fuse in the plug
otherwise here is the contact details not sure if i have the country correct I put in greece/english but you can change at the top of page
http://www.support.philips.com/support/contact/contact_page.jsp;jsessionid=DB484F327F9A8A166463A0ED12878AC0.app107-drp1?userCountry=gr&userLanguage=en
Nov 01, 2010 | Avent Express 6 Bottle Steam Sterilizer
Welli just bought an avent bottle warmer online and instructions didnt come so i turned it on an put it on bottle and the amount of oz and it dint warn any so could u tell me how to use it or how it works?
turn on,select where bottle came from,room temp/fridge/freezer by pressing power button.
Press size button to amount of water/milk in bottle,when at right level hold button in,unit will bleep
May 21, 2010 | Toys
HOW TO DE SCALE THE Philips AVENT Digital Bottle
Mix one sachet of citric acid* (10g) with 200ml/7oz of water. Pour solution into the
empty warmer. DO NOT place a bottle, jar or cup into the warmer when de-scaling.
Close the lid of the warmer and programme the warmer to run with 310ml/11oz of
milk from frozen. After the warming cycle has ended, leave the solution to cool for
30 minutes before emptying the warmer and rinsing with tap water. Wipe the inside
and outside of the warmer with a damp cloth only.
OR:
Pour 100ml/3.5oz of vinegar mixed with 200ml/7oz of cold water into the warmer.
Allow liquid to stand in the unit until any limescale has dissolved. DO NOT place a
bottle, jar or cup into the warmer when de-scaling. DO NOT start the warming cycle.
Empty the unit and rinse thoroughly. Wipe the inside and outside of the warmer with
a damp cloth only.
Jan 30, 2010 | Avent Philips iQ Bottle Warmer without...
Philips Avent, fusible broken
The same temperature. Otherwise you lose upper limit protection.
Aug 17, 2017 | Avent Philips iQ Bottle Warmer without...
What do i need to do for a convair classic portable cooler, to care for/service it? (as it is smelling at the moment!) Convair Classic M800CAUS; Product no. 007410
we always used 1 baby bottle steralising tablet to sterlise them , best to do this outside to avoid the chlorine /swimming pool smell in the house
then flush all the solution away and replace with fresh water ( the solution is quite corrosive and cause rust ) , also check your pads for dust/limescale , you may well need to replace these
Nov 13, 2009 | Heating & Cooling
Baby Care Logo
94 people viewed this question
Top Baby Care Experts
masud
masud
Tom Chichester
Are you a Baby Care Expert? Answer questions, earn points and help others
