Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Printer says paper is wrong size but it isn't
Trying to print on 11.5x8 printer paper with designs already on it (bought it with decoration, i'm trying to add text) but says paper is wrong size. paper is not name brand, but measures out the same as regular printer paper. feels like same weight as regular printer paper too. when i try it on regular printer paper, text prints out fine. please help.
  • j0llyc
    j0llyc May 11, 2010
    What country are you based in?
    The reason I ask is that the size you specify is Letterhead which is a US standard, whereas in Australia we use A4.
    It might be a driver issue, but get back to me and we can go from there.
    Cheers,
    Chris
5 Suggested Answers
IB4G2008
  • 3587 Answers
SOURCE: Hi Wizard
where to put the paper? There's a manual that comes with this printer, that clearly shows how to open this up, and add paper. I'd recommend you review that first. You may be thrilled when you find it
Posted on Feb 06, 2008
  • 19 Answers
SOURCE: Won't print on regular paper
My quess would be that printhead is becoming clogged, photos don't use as much ink as plain paper printouts that is why they look faded! You need to call Kodak tech support!
Posted on Jan 14, 2009
  • 60 Answers
SOURCE: Kodak 5300 printer 4x6 printer tray
it could be a problem with printer and least with the print head.......i would advice to contact Kodak tech support...........
Posted on Jul 16, 2009
SOURCE: trouble printing envelopes on kodak esp3 printer
Put a few small pieces of tape on the back on the envelope and tape it to the paper, print a test run of the adress and tape the envelope over the adress in the correct spot.
Posted on Feb 22, 2010
Xerox 7760 Wrong paper size error when trying to print to A4
First your computer selects the printer to output to, so make sure your default printer is selected.
Next, within your printer you may have selected a different page size for output as a default.
The printer it self should allow you to load and auto detect paper size. If this feature is not enabled see if it is a choice.
Also whatever you are trying to print check page setup in the program you are using make sure to ensure they match.
Sep 16, 2016 | Xerox Phaser 7760DN Laser Printer
My Xerox Phaser 6128MFP printer flashes a red light with a "Load paper in Tray" message, when the specific paper size and type are already same in the tray.
If the paper size is correct in the printer and the printer and it's possible to print off a test print in both the printer control screen or directly from the print driver utilities if that works then the only thing I can suggest is the item you want to print is defaulted to a different size. i.e. Check that the word processor your using is set to the size you have in the printer. Imperial size pages will look very similar on screen as does the A4. Printers don't automatically fix paper print sizes you just have to check and recheck for differences. Removing the tray only reafirms to the printer that the size might be incorrect and your going to fit the correct size.
As for the red light all printers behave differently in certain error conditions. Have you also tried to print out something you printed at a time the printer was working correctly. In other words try printing out a different file. Maybe, trying to print off a test print of one line of the alphabet, and then go from there.
Good luck,
Apr 02, 2015 | Xerox Phaser 6125 Laser Printer
HpC309g printer keeps gaming -reason Wrong size paper but it is not
The document you are trying to print is set to a different paper size than the printer has. It is looking for paper of the correct size to be installed so it can print the document.
Aug 28, 2014 | HP Photosmart C309g Premium All-in-one...
Error 024-965
Place the designated paper in the relevant tray.
  1. Verify the paper size from the printing application matches the designated printer tray.
    1. Open the application being used to print the document (Example: Microsoft PowerPoint)
    2. Click File and then click Print.
    3. Verify the paper size.
      NOTE: For Microsoft Word and Excel, ensure that the paper size in Page Setup is the same as in the printer driver and the printer.
  2. Make sure the Paper Type is set to AUTO on the Printer.
  3. Cycle power on the Printer.
    1. Turn the printer off.
    2. Wait 10 seconds.
    3. Turn the printer on.
    4. Determine if the issue still occurs.
  4. Verify that the Actuator No Paper moves smoothly and is not damaged (Figure 1).
    Figure 1: Actuator Location
    • If there is damage or the Actuator does not move smoothly, replace the Feeder Assembly.
    • If there is no damage and the Actuator moves smoothly, replace the Feeder Assembly.
      • If the Feeder Assembly has already been replaced, replace the relevant Tray.
      • If the Tray has already been replaced, replace the Printer.
Abhilash
Sep 20, 2010 | Dell 3100cn Laser Printer
HP C7280 does not print straight, ie the print is angled on page
There is no way that a printer prints out of alignment unless the paper slips enroute. Meaning that the rollers are not holding the paper tight and the guides not pressing the paper snugly, as you put it. So, it could either be the rollers not aligned to each other properly or the guides not pressing the paper equally. The print head moves on a steel rod which is straight. So that can not be the culprit as the print head has to move in a straight line, irrespective of the paper being straight or slipped. So, that leaves us with the slipping paper for which there are the rollers and the guides. If you feel that the tension in the guides is not equal, then change the guides, else the rollers need a closer look. Or at least clean them with a damp soft cloth and allow them to dry up before using them.
Nov 04, 2009 | HP Photosmart C6180 All-In-One InkJet...
What would you reccomend for a photo printer to use with my Apple
hi! its better to select and make your photo on album menu,on your album photo,you can select paper type,if your using pro glossy click on that to have better quality,on size if 4x16 or 5x7 there is a check sign click it and select photo size also the page orientation check if vertical or horizontal layout.if tou to decorate your photo click decorate your frame will have a decoration just select.there are several option but just to try on one page first because you can print w/several image as you want.regards and have a nice day
Apr 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Dell 3100 CN printer...message on printer reads load tray
Cycle Power on the Printer
  2. Wait 10 seconds.
Verify There is Paper in the Tray
Verify the Paper Size
Look at the chart below to verify that the paper size meets the 3000cn / 3010cn / 3100cn-series specifications.
Verify the paper size in the tray matches the size set in the 3000cn / 3010cn / 3100cn-series printer´s operator panel.
To verify the paper size in the tray matches the size set in the printer's operator panel, perform the following steps:
  1. Press the MENU button.
  2. Press the down arrow until Tray Settings appears and press the return%20arrow%203100cn.jpg button.
  3. Press the down arrow until Paper Size appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or MPF) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper size, as shown in Figure 1, and press the return%20arrow%203100cn.jpg button.
  6. Press the MENU button.
*1 Denotes country-specific factory default values.
*2 Available for the optional 250-sheet cassette only.
Figure 1 - Paper Size Chart
Verify the Paper Type Matches the Type Set in the Printer´s Operator Panel
To verify the paper type matches the type set in the printer's operator panel, perform the following steps:
  3. Press the down arrow until Paper Type appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or Multipurpose Feeder) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper type, as shown in Table 1, and press the return%20arrow%203100cn.jpg button.
Table 1: Paper Type Chart
All media types that are not Plain 1 should be printed from the MPF only.
Verify the printing preferences on the Dell™ 3000cn / 3010cn / 3100cn / 5100cn-series printer.
To verify the printing preferences is set to print from the correct tray with the correct paper size, perform the following steps:
  1. Click the Start button, go to Settings, and click Printers and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser Printer 3000cn / 3010cn / 3100cn / 5100cn-series and click Printing Preferences.
    The Printing Preferences window appears.
  3. Verify the Paper Size drop-down is set to the correct paper size loaded in the specific tray to be printed from..
  4. Click the Paper Tray tab.
  5. Click the Paper Source drop-down menu and select the specific tray to be printed from.
    This sets the size and tray defaults.
Verify the Paper Size From the Printing Application Matches the Designated Printer Tray
To verify the paper size from the printing application matches the designated printer tray, perform the following steps:
  1. Open the application being used to print the document. (Example: Microsoft Word)
  2. Click File and click Print.
Verify the Paper Source From the Printing Application Matches the Designated Printer Tray
  3. Verify the paper source.
Do not replace any printer hardware as this is not a printer hardware issue.
Nov 12, 2008 | Dell 3100cn Laser Printer
Lexmark 1200 All in One
I've never heard of that size paper the printer don't have that option the only possible sol. is to go to an A4 size ( European size) other than that try printing from Word and change the size of the Fonts.
Sep 17, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
312 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
