Question about Logitech Squeezebox Radio
Squeezebox speaker stopped working
No sound
Replace squeezebox boom battery
The battery for the Remote Control? That's the only battery a Squeezebox Boom has.
  1. Remove the back cover
  2. Replace batteries.
  3. Put back cover back on.
Download Logitech Squeezebox Boom Manual
Jan 24, 2014 | Logitech Squeezebox Boom Radio
Hi, red light flashing on my squeezebox... how can I make it work?
Hi, Did you try connecting the Player by ethernet ? If it turns blue or white then you might have to review your wireless encryption, if still red, make sure DHCP is enabled on your router. Have a great day !
J -
Sep 27, 2010 | Logitech Squeezebox Duet
Can i use a memory stick to playback music through a hi-fi music centre,or portable radio please.
Only if your hi-fi supports such devices or if there is a port to plug it in. Check also the Hi-FI user manual.
May 30, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Compatibity with Logitech Squeezebox touch
Hi, The squeezebox is fully compatible with your system, you can connected them together thru: RCA, Minijack, COAX/TOSLINK Thanks and have a nice day ! J -
May 14, 2010 | Bose Companion 5 Multimedia Speaker System...
Mar 25, 2010 | Bose Companion 5 Multimedia Speaker System...
Squeezebox duet drops out
Hi, Did you try by Ethernet connection ? Does the problem reproduce ? If not the you might be too far away from the access point, Do you have any bandwith consuming application running on your network ? Does the problem happen with webradio and your tunes ? Thanks and have a great day J -
Dec 30, 2009 | Logitech Squeezebox Duet
Trying to hook up logitech squeezebox
Hi. Slimserver is not supported anymore by Squeezebox systems, now you must download and install Squeezebox server 7.5.0 http://downloads.slimdevices.com/ This way it will install and works without problem. Thanks and have a nice day J-
Oct 17, 2009 | Logitech Squeezebox Duet
I need to connnect a logitech squeezebox to an amplifier. Not sure which inputs to plug into?
Hi, You can use Optical/Coax or RCA or JACK to connect your squeezebox to an amplifier. Thanks and have a nice day J-
Sep 26, 2009 | Logitech Squeezebox Duet
Squeezebox boom stuck in demo mode
Hi !
reset it !
Unplug the power cord , push and maintain the " + " button and replug the power cord, release " + " when you see " Factory reset ", then Fixed !
Have a gret day !
J -
Apr 17, 2009 | Logitech Squeezebox Duet
Logitech Squeezebox Radio Logo
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
