Question about Hannspree HW191D LCD Monitor
NEED TO RESET POWER ON HF237 HOW DO U DO THIS
How do I reset to factory settings?
here is the user manual http://www.manualslib.com/manual/64813/Hannspree-Hf237.html hope it really helps hoping to hearing from you
Ialso recommend registering to the best site for earning money online http://www.clixsense.com/?8516905 I recently found and please do that I you find me helpful hahah
GOOD LUCK
Mar 24, 2015 | Hannspree HANNS Computers & Internet
When I boot my computer My HF237 monitor will briefly show the page then go dark. How can I diagnos the problem?
This is usually an issue with a failing capacitor. I replace them in mine often. In the monitor, on the power supply will be several capacitors (caps). Look for the tops to be domed these are bad. Try a site called badcaps if you are game to replace these.
A soldering station after shipping can be as low as $32 or so.
Oct 09, 2014 | Hannspree HF237HPB 23 inch LCD Monitor
How to fix HF237 Hannspree Monitor?
I did a quick Google search, since I experienced the same *2 seconds to black* problem months ago, and found this Hannspree HF237 2 seconds to black Badcaps Forums
Sep 01, 2014 | Hannspree HF237HPB 23 inch LCD Monitor
MY HANNSPREE MONITOR HF237 SUDDENLY WILL NOT STAY CONNECTED TO MY LAPTOP I JUST HAVE A BLACK BLANK SCREEN. I AM USING WINDOWS 7 ULTIMATE
On laptops there is a key sequence that you can switch between monitor states, it's possible you have it in Laptop screen only. Look for the "Fn" key and then hit the Monitor button (it has a picture of a monitor) usually this is somewhere around F5 or F8.
May 19, 2011 | Office Equipment & Supplies
NEED DRIVERS FOR VISTA 32 BIT FOR MY NEW HF237
find your driver from these site
1)www.nvidia.com/object/winvista_x86_100.64.html
2) www.rage3d.com/board/showthread.php?t=33863938
3)
Oct 03, 2009 | Hannspree HW191D LCD Monitor
Hannspree HF237 23" Monitor
The driver files allow for windoze to set the monitor up as a plug-n-play device. However, you do not need drivers to set this up manually. If you will right-click the desktop and open the display properties, click the display adaptor tab, and uncheck the box that indicates to hide incompatible settings (I don't have windoze myself, but it's worded something like that) save that change and click on the monitor tab, then find a compatible setting for your monitor as indicated in the instruction manual, you can set it up to work as well as if it had the drivers.
If you have any questions, please ask.
Aug 06, 2009 | Hannspree HW191D LCD Monitor
Error on monitor: Input signal out of range. using VGA cable and laptop is right next to monitor Hannspree 23" HF237 LCD monitor
Hello mcarsten,
Your monitor may not be configured to the correct resolution for the second monitor. If you right click on an empty space on the desktop and then select properties, the display properties will appear. Click on the last tab on the top right. It should be settings or something like that. You should see two boxes with the numbers 1 and 2 in them. Next click on box number 2 and try using the slider below and changing it to different resolutions for your monitor.
Hopefully one of these should work for you.
Jul 10, 2009 | Hannspree Computers & Internet
We recently installed a 23'/HF237 monitor. Everything looks great except the picture on the screen is stretch horizonally, causing distortion. I publish a sports magazine and I need the screen to show an...
You need to set your PC display adaptor to correct resolution maybe 1440 >< 900.You need to select resolution which is correct for this widescreen monitor (16: 10) Aspect ratio as opposed to 4 :3 CRT monitor you must have been using previously.
Samir
Jul 09, 2009 | Computers & Internet
How do you make the sound work ? Hannspree Monitor HF237
When you have a monitor that has built-in speakers, you must hook that monitor to your computer with a cable--the type of sound cable any other speakers have. It has a male jack on each end. One end goes into the little sound in hole in the back of the monitor. The other goes into the green hole on your sound card (either the built-in card or an add-on card).
Another thing to check is to see that the sound drivers are working. You know they are if the computer had sound that played through other speakers. If you hook it all up and there is no sound, then you most likely have a sound driver problem (or your sound is muted!)
If this explanation helps, be sure to rate the answer, please.
Mar 30, 2009 | Computers & Internet
Hannspree HW191D LCD Monitor Logo
Top Hannspree Computers & Internet Experts
richie46
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
