Question about HP OfficeJet 6110 All-In-One InkJet Printer
HP 6110 only works through Twain
I hookede my 6110 up to an XP 2002 Professional but the normal menu never comes up when I want to scan. It now will only scan through twain
    Guru:
  • 224 Answers
Alright thanks for letting me know the o/s (honestly).
open your browser and type in www.hp.com.
In the window that opens up click on support and drivers.
Then click on download drivers and software (and i know your printer is a 6110) but download the software for the photosmart c7280 (full software and driver download). Save the software on your desktop with and easy name to remember.
Now if you have to software cd for the 6110 insert it into the cd drive and exit out of the autorun screen.
now open up my computer(either from the desktop icon or by clicking on start and then clicking on my computer).
now in the my computer window right click your cd drive and select open.
look for the folder called "util" and double click it. Then go inside the folder called ccc and double click on the file callled l3 uninstallation if u have and hp computer if it is any other brand then click on l4 uninstallation.
(if u dont have the cd go into control panel and in the add/remove programs uninstall all hp printer entries(imaging device functions/hp solution centre/hp photosmart drivers/....etc)
once the uninstallation of the old printer is done.Now double click on the downloaded software or if u have a run button click on that.
the extraction of the downloaded software will begin.
Now follow the onscreen instructions to install it but when the type of installation comes up the select usb installation and dont connect the usb.
There will be a little box on the installation screen saying check this if u want to install ur driver later.check that box and proceed .
the software will install properly. Once that is finished.
now insert your cd for the 6110 once more into the cd drive ,if you get the splash screen and you will get an option saying add a device click on that and again it will ask you how you want to connect your printer select the desired way(usb/network). now insert the usb cable and once the usb is detected then proceed with the on screen instructions and after that is finished you will get an icon on your desktop called hp solution centre double click that file and voila ur answer will or should be resolved.
I f you dont have the cd go back to the hp website and download the basic drivers and run the extraction once the download is complete again click on the option saying add a device choose ur usb or network installation and click on next,insert the usb cable and it should be detected and follow the onscreen instructions and your work should be done.
now you can scan from the solution centre,click on settings point to scan settings and click on scan to setup and move all items from the left hand side to the right hand side and click on ok/update the device and now try to scan and you shall see a huge smile back on your face.
this should work cauz this is what i do when i work with hp us customers,Provide solutions over the phone,except that im a little higher than an agent
Posted on Jun 18, 2009
Epson S-50/XP-Pro/ twain-approved application will fire the scanner to feed the documents, scan the documents, but will not allow the application's captured-preview window to open.
try using free irfanview and acquire the scanning from there and save or edit the output, once installed just select file, then select twain source and your scanner will be there. Much easier option than scanner software
Feb 26, 2012 | Office Equipment & Supplies
I want to upgrade my Epson Perfection 1200 Photo flatbed scanner so I can use it in Windows XP
Are you talking normal XP or something more specialist...If normal just download the twain driver from the epson site. I cannot get the copy utility to work but the twain give you the functionality to scan. Following the other threads here I have been able to get this scanner two work even better on 64bit Vista
Jan 05, 2010 | Epson Perfection 1200 Photo Flatbed...
I have hewlet packard all in one j4680 I can copy,print & fax. I want to know how to scan and put on the computer
You first need to have the HP software that came with the printer installed, and the most up to date drivers will also help make sure there aren't any compatibility issues.
Once you have that set up, on the control panel on the printer itself press the arrow buttons until you have Scan selected. Press OK. Press the RIGHT arrow to choose what you'd like to do with the scan when it's finished and press OK. Then press the START button.
You can also start a scan from within the program provided by HP with the printer, and many graphics editing programs and word processing programs (such as Word) have a Scan button. Sometimes referred to as an Inport from TWAIN Device or Scan from TWAIN Device. Simply clicking on one of those buttons usually starts the needed program to control the scan from on the computer, instead of using the buttons on the printer itself. (NOTE: The TWAIN device options are sometimes inside the Edit menu of some programs, so you may need to look for it a little.)
Sep 19, 2009 | HP Officejet 5610 All-In-One InkJet...
It will not scan, prints, copy, but not scan
hi... have some idea about your problem... maybe u should try this... try to install your twain driver of your printer first then next is the scanner driver... then you'll fing what will happen next... thank you very much...
Jul 21, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I try to scan but I receive a note to check my scanner connection
you need a driver update for this. point you browser to www.hp.com under support there should be some drivers for it- thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Scan save problem
Not sure if this will work however put the printer CD in the carriage (cancel the auto start). Then do your scan etc... as you normally would. My HP 6110 for some reason will not always see/grab all of the scanner files on an install. If the CD is in the carriage your scanner MAY see and grab them off of the CD when it actually needs them. If that works for you it should continue to work.
Hope that helps
Feb 25, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My scanner is not working...The printer is working properly. When I click on the Scan button it asks me for a source but i have no sources as an option.
The all in one solution software you used in XP doesn't work fully with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie HP OfficeJet 6110) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Jan 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp 6110 all in one hp director not working.
try to do the following:
1. Double-click the HP Director icon to load the program into the memory. You will not see HP Director open at this step. Do not click anything else on the screen until Step 2 is completed.
2. Press the Alt key and the Space bar together, and then
select Minimize from the menu that displays in the upper left corner of the window. If necessary, click it again until HP Director minimizes.
The HP Director software now appears as an item on the Task Bar .
3. Click HP Director on the Task Bar . The software opens and displays normally.
4. Repeat Steps 1 through 3 every time the HP Director software is used.
or
  1. Go to the HP Software Download Page .
  2. In the Enter a product number text box, type the printer model, and then press Enter .
  3. Under Product search results , select the printer model.
  4. Select the operating system.
  5. Under Update , click Critical update to resolve an issue with HP Director after installing Internet Explorer 7 .
  6. Follow the instructions that display on the screen to install the update.
Cause:
In October 2006, Microsoft released Internet Explorer 7. The HP Director software that shipped with some HP products introduced between 2002 and 2004 may not be compatible with Internet Explorer 7. The HP Solution Center software, which replaced HP Director software, does not exhibit this issue with Internet Explorer 7.
Sep 02, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scan Problem with HP Officejet 6110 All-in-one
Once try to scan from the scanners and camera wizard to check the two way communication between the computer and the all-in-one.
  1. Verify that the all-in-one product power is turned on and the printer cable is properly connected.
  2. Click Start .
  3. Click Programs .
  4. Click Accessories .
  5. Click Imaging .
  6. From the Imaging application, click File , and then click Select Device .
  7. Select the HP all-in-one device from the TWAIN source list.
  8. Click File , and then Acquire Image . Imaging for Windows will scan from the all-in-one product using TWAIN software instead of the HP software.
If you are able to scan by performing the above steps then search for the file hpqscnvw.exe and try to scan from there.
If you are not able to scan even from the above steps, once refresh the USB cable and then try to scan again.
if you are able to scan from that file then try to scan from HP Director, if the issue persists then create a shortcut icon for that file and then try to scan else uninstall the software and reinstall.
Jun 18, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
557 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
