Question about Sony PlayStation® 3 (80GB) Console
My playstation3 does not allow disc to enter inside
It does not allow disc to enter inside and the former disc that is inside does not eject.
    President:
  • 2,653 Answers
You'll have to open up the PS3 with a T9 hex security screw driver, then you'll have to open the blu-ray drive up.
Check youtube for tutorials on it.
Posted on Jun 19, 2009
Why won't stereo load any disc?
I also have a 2009 Journey with the 6 disc changer. There is a 'LOAD' button to the right of the disc opening. Press 'LOAD' and wait for it to display "insert disc". The 'EJECT' button is on the left side (above the power knob) and the 'LOAD' button is on the right (above the volume knob).
Hope this is helpful.
Nov 21, 2015 | 2009 Dodge Journey
How to remove disk from playstation3 console that will not turn on
1. First shut down the system by flipping the power switch in the back off.
2. Hold down the eject disc button.
3. While still holding down the eject button, flip the power switch to turn back on your PS3.
4. When the green light comes on, wait a few seconds then tap the eject button a couple times. The fan will run on full power and the disc will eject.
Jul 18, 2014 | Sony Playstation 3 (PS3) Console
Movie disc stuck in playstation3
If you hear the drive making noise as if it is trying to push the disc out and just cannot,
try facing the facing the system down with the disc drive towards the floor and press the eject button.
If it doesn't work the first time, try a few more times until the disc comes out.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mike_005777b2fc6bfc30
Mar 24, 2011 | Sony Playstation 3 (PS3) Console
With the power light on my playstation3 ,when you switch it on,the red light goes out and it goes to green for about two seconds then immediately switches off again
Does the lights blink red? If so, You have the infamous YLOD, aka. Yellow Light of Death. This is the number 1 cause of pS3's dying. It is an overheating issue linked to your CPU and GPU (the processor chips) You will need to find a local PS3 repair shop who can repair this. Do not try to attempt repairs seen on the internet yourself. You could make things much worse and render the unit totally unresponsive. The repair process takes about 3 hours.
IT CAN BE FIXED
IS THERE A DISC STUCK INSIDE?
If you have a unit that is not backwards compatible, any non 60g or 80g then you can retrieve your disc.
Power off the unit using the toggle switch on the back. Hold down the 'eject' button and turn the toggle switch back from off to on. This will run a fan test and eject your disc. Remember, this will only work on the 20, 40g models. Not the backwards compatible units with the 4 usb port holes and the memory card slots.
Jan 22, 2011 | Sony Playstation 3 (PS3) Console
We put a bluray disc in the PS3 and the disc is stuck and the console will not eject the disc and will not stay on. We have tried holding down the power button, holding down the eject button and nothing...
switch off power at the back. hold down eject button, keep holding, turn power button at the back to on. console fan will spin very fast ( at this time take your finger off the eject) then goes back to normal. try now to hold eject button for more than 9 sec; it will then eject your disc. if this dont help check this site: http://www.edepot.com/playstation3.html#PS3_Model_Differences
PS: most likely, you already have a problem with your Blu Ray laser (life span expired) or hopefully you will need to just re-allign your CD drive mechanics. dont open your console if you still covered with sony waranty. otherwise; give it a try; many youtube videos will show you how to do that.
Good luck
Oct 10, 2010 | Sony Playstation 3 (PS3) Console
Ejecting a Stuck CD in Mac OSX
  • First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu.
  • If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X.
  • Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared.
  • If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar.
  • Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder
  • Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button.
  • Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism.
  • Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray.
  • Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. )
  • If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
Sep 17, 2010 | Apple iMac G4 Desktop
I have a Sony Optiarc AD-7640S that when sticking a disc in it moves it back and forth 3 times then ejects the disc. It does this on any disc inserted. Got any ideas?
guess there is something inside that's struck and is not allowing the disk drive to close fully....
look for some thing inside the drive or
take it to a tech shop and get it fixed
May 05, 2010 | Computers & Internet
Can't eject disc
could be that it has dust bulid up around the opening, this happens to me quite a lot.Best way is to get another disc, and when you hit eject gently try to insert another disc, this usually takes a coupkle og oges to master, however it should allow the other disc inside the machine to come out
Apr 14, 2010 | Sony Playstation 3 (PS3) Console
My go video is locked. How do i unlock it?
You can unlock by pressing and holding the Power switch. Sometimes it will then allow you to eject the disk after it restarts, but not always.
Mar 08, 2009 | GoVideo VR3845 DVD Recorder/VCR
46w500 hitachi tv-dvd
My Hitachi 46W500's DVD tray will not open. My son about 2 - 3 years ago said he had done something to he tray that may have caused this, is there any way to fix it at home ?
Jan 10, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
Sony PlayStation® 3 (80GB) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
