How do I turn off the puddle lamps on my 2014 ford explorer
I don't know how I turned them on and I don't know how to turn them off.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 37 Answers
Take it to dealer use the warranty, and make your sales person work for the big bucks you paid...
Posted on Apr 15, 2014
2007 Ford Explorer flasher relay
There is no flasher relay , all done electronically by the smart junction box (computer )
The smart junction box (SJB) monitors the multifunction switch position by sending multiple voltage reference signals to the multifunction switch. When the multifunction switch is in the LH or RH TURN positions, or the hazard lamp switch is engaged, that input signal is routed to ground.
When the SJB receives an input from the multifunction switch indicating a request for a turn signal or hazard lamps, the SJB then supplies voltage to the appropriate turn lamps.
Your best bet would be to take it to a qualified repair shop or dealer .
Do you know what DTC'S are ?
Smart Junction Box (SJB) Diagnostic Trouble Code (DTC) Chart DTC Description Action B1499 Lamp Turn Signal Left Circuit Failure Go To Pinpoint Test M . B1502 Lamp Turn Signal Left Circuit Short to Ground Go To Pinpoint Test M . B1503 Lamp Turn Signal Right Circuit Failure Go To Pinpoint Test M . B1506 Lamp Turn Signal Right Circuit Short to Ground Go To Pinpoint Test M . B2048 Left Rear Turn Lamp Circuit Short to Ground For Mountaineer, Go To Pinpoint Test M .
For Explorer or Explorer Sport Trac, REFER to Stoplamps in this section. B2049 Left Rear Turn Lamp Circuit Open For Mountaineer, Go To Pinpoint Test M .
For Explorer or Explorer Sport Trac, REFER to Stoplamps in this section. B2050 Right Rear Turn Lamp Circuit Short to Ground For Mountaineer, Go To Pinpoint Test M .
For Explorer or Explorer Sport Trac, REFER to Stoplamps in this section. B2051 Right Rear Turn Lamp Circuit Open For Mountaineer, Go To Pinpoint Test M .
For Explorer or Explorer Sport Trac, REFER to Stoplamps in this section. B2071 Hazard Switch Signal Short to Ground If the hazard lamps are inoperative, Go To Pinpoint Test N .
If the hazard lamps are always on, Go To Pinpoint Test O . B2281 Right Turn Switch Short to Ground Go To Pinpoint Test L . B2282 Left Turn Switch Short to Ground Go To Pinpoint Test L . All other DTCs - REFER to Section 419-10 .
Apr 22, 2017 | Ford Cars & Trucks
Why can I touch my headlights on my ford explorer and they turn on and off?
You have to touch headlamp assembly, to turn on the lamps? Check headlamp wiring and connector.
Oct 28, 2016 | 2003 Ford Explorer
2008 ford explorer light control module
Hi Rich , what lights are you talking about ? Exterior Lighting , Interior Lighting ? It doesn't matter All lights are controlled by SJB smart junction box ! An you can't just stick in a used one , It will need to be programmed ! Interior Lighting The interior lighting system consists of the following components:
  • Smart junction box (SJB)
  • Dimmer control switch
  • Interior/map lamps
  • Cargo lamp
  • Glove compartment lamp
  • Vanity mirror lamps
  • Door ajar switches
  • Puddle lamps
The interior lighting system consists of 2 subsystems:
  • Courtesy lamps
  • Demand lamps
The courtesy lamps are controlled by the SJB. The courtesy lamp subsystem consists of the interior dome lamps, the puddle lamps and the overhead console lamps (if equipped). The SJB supplies voltage to the courtesy lamps when the SJB receives the required input.
The demand lamps are controlled by the SJB. The demand lamps subsystem consists of the glove compartment lamp, all map/reading lamps, and the left and right vanity mirror lamps.
The SJB supplies power to the interior lighting system. The SJB will set DTCs if certain circuit failures exist with the interior lighting system.
Exterior Lighting Headlamps
The headlamp system is a dual-beam pattern system. It consists of a low and high beam, with a replaceable bulb. The headlamp assembly has the park/turn indicator lamp integrated into the headlamp assembly. The smart junction box (SJB) supplies voltage to the headlamps when demanded.
Principles of Operation
The SJB receives inputs and delivers outputs to a majority of the electronically-controlled features of the vehicle. The SJB constantly monitors the systems under its control and reports a concern in the form of a DTC. The DTC can be retrieved with a scan tool through the medium speed controller area network (CAN) communication network.
NOTE: Prior to the removal of the SJB, it is necessary to upload the module configuration information to the diagnostic tool. This information must be downloaded to the new SJB after installation. For additional information, refer to Section 418-01 .
Feb 25, 2015 | 2008 Ford Explorer
Just put serpentine belt on 1999 ford explorer, now it wont turn
I know this is an obvious answer, but I would guess its not on correctly.
If you don't have a diagram on the hood or the radiator support, let me know. It can be easy to switch pulleys when you change the belt.
Jul 24, 2012 | 1999 Ford Explorer
How to change Ford Explorer fog light
p, li { white-space: pre-wrap; }
Open the hood and remove the electrical plug from the back of the fog light ballast below the headlight assembly.
Turn the fog lamp counterclockwise to unlock it from the fog light housing.
Insert the new fog lamp. Align the notches on the fog lamp housing with the tabs on the new bulb and turn the bulb clockwise to lock it into the housing.
Reconnect the fog lamp electrical plug.
Sep 13, 2010 | 1999 Ford Explorer
1999 ford explorer the 2 lower brake lights won't work but the 3rd upper brake light works fine ...... whats wrong ???
check the rear lower bulbs, if good nore than likely brake lamp switrch on brake pedal, 3rd lamp rns of separate circuit
Aug 13, 2010 | 1999 Ford Explorer
Change puddle light , need to know how to take the lens off to change the light bulb in the mirrior of a 2003 ford expedition .
Per the '03 Owners manual...
Approach lamp bulb removal (if equipped)
To change the bulbs:
1. Make sure that all the doors are
closed and the interior lights have
automatically turned off or the
opposite mirror approach lamp has
turned off.
2. With a small flat tipped
screwdriver, insert the tip into the
approach light module slot located
on the outboard corner of the lens
to release the clip.
3. While holding the clip in the release position, pull the approach light
module down.
4. Remove the two wires from the module and replace the module with a
new one.
5. Reverse the order to reassemble the approach light module.
Jul 04, 2009 | 2003 Ford Expedition
Replace front turn signal lamp
if u cant get to it from under the hood, u might have to remove the housing.
Mar 29, 2009 | 2008 Ford Explorer 2WD
Low beam headlights stopped working simutaneously
Check and replace the fuses where needed.
Nov 15, 2008 | 2003 Ford Explorer
 Grubhead
Grubhead
