Question about APC Symmetra RM 6kVA UPS System
Symmetra LX with error code E0 - APC Symmetra RM 6kVA UPS System
    Scholar:
    New Friend:
  • 129 Answers
Below are recommended steps that will help narrow down the E0 fault. First we will diagnose the XR Frame, the Anderson Connector, and the Communication Card. Then you will reseat the XR Communication Card. Then we will slowly introduce the batteries into the XR Frame to see if anyone of the batteries is causing the issue.
Step 1: Remove all of the batteries from the XR Frame.
Step 2: Disconnect the XR Frame from the UPS by removing both the Anderson connector and the RJ14 Communications Cable.
Step 3: Reseat the Communications Card from the rear of the XR Frame.
--> You may need a flat head screwdriver to remove the 2 thumb screws located on the far left and right of the card.
--> You will also want to make sure that the Black Frame # selector (small black rectangle with a small white arrow)is switched to the correct number -- in your case 2. This switch is located on the card you just reseated.
Step 4: Allow the UPS to see that the XR Frame was removed.
--> You can verify this by using the Powerview display: Menu > Diags > Batteries > *here you will have the option to select 'FRAME 1 OF 1' or '1 OF 2' ... You want it to say 1 of 1.
Step 5: Reconnect the RJ14 Cable.
Step 6: Reconnect XR Frame, with no batteries installed.
--> You will want to make sure that the XR Frame comes online by itself. You should see the frame number in red letters/numbers and you will see a green light on the Communications Card. If the XR Frame does not come on then you may have a problem with the Anderson Connector, the RJ14 Cable, or the Communications Card itself -- contact me for help here.
Step 7: If the XR Frame is on, reintroduce the batteries into the XR Frame one at a time making sure that you can see the number of batteries increase in the Powerview Display.
--> If the E0 error appears again after introducing a battery, then remove the battery, set it aside, and continue inserting the remaining batteries. Repeat this step if the E0 error appears with another battery. If the problem is fixed and you had to set aside batteries -- then all you will need to obtain replacement batteries -- contact me for a quote.
After you follow these steps very carefully, you should know what is causing the error or have it fixed altogether.
Let me know if this helped :-)
If you need Datacenter, UPS, Surge, or Power Related help contact:
Daniel@psihq.com with Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
•• If this helped - click the green 'HELPED' :-) ••
Posted on Nov 07, 2016
2 Suggested Answers
  • 14 Answers
SOURCE: I have a symmetra RM
The first thing is to make sure the interconnection between the main module and the extended run is properly making contact
Next is to verify the XR battery cabinet voltage is according the battery charging voltage (normally 137 Vdc). Power View will confirm this voltage.
My favorite is to load test the batteries module individually and make sure the batteries are good.
If there is a +/- 3 volts difference between the UPS and the extended run module E0 alarm would be indcated.
Posted on Apr 02, 2011
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
KitchenAid KHMS155LSS when press "bake potato" button,start flashing error F3
Question: Error Code - Oven - F3 Error Code - F3 E0 Answer Product Symptom:
Error Code/Message - Oven - F3 Error Code - F3 E0
Control displaying F3 E0:
There may be a problem with the Oven Temperature Sensor, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Jul 31, 2014 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Apc sy lx
Ereadlu,
What's the problem? And is the UPS a Smart-UPS or Symmetra? Jotting down the exact model number will help.
Daniel • Power & Systems Innovations • 800.260.2259 • www.psihq.com
** If this helped - Give it a Thumbs Up :) **
Dec 17, 2013 | APC Smart-UPS 1000VA UPS System
Kindly recommend ups for 15kw load
I would get a APC Symmetra LX for single phase of Symmetra PX for 3 phase
Sep 21, 2013 | Computers & Internet
I have a kelvinator kwh35hra room a/c I habe fault code e0
Code E0 Error detail Remotecontrol transmission error (signal receiving error)
Inspected unit Remote control
Dec 08, 2010 | Heating & Cooling
I have a Symmetra LX 16000 , and ups sen me the message ...Critical - UPS A main intelligence module fault exists.. code 0x0203.
Hi Scabcmx,
Without knowing the full model number of your UPS I cannot go into specific details fully for you.. but a good test with any 'intelligence module fault' is to re-seat the module and run a self test. If the fault remains then your intelligence module is bad and you will need to acquire a new one to replace the faulty one. This can all be done 'on-line' and you should not have any downtime... assuming there is a redundant intelligence module in the unit which is normally the case. This will clear the fault.
If you would like more information give me a call: 407.380.9200.
Oct 12, 2010 | APC - UPS - Matix/Symmetra Enterprise UPS...
APC Symmetra RM 6kVA UPS System Logo
387 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
