Question about Microwave Ovens
Lost manual for allen + roth Harpwell 6-Light Oil Rubbed Bronze Hardwired Standard Chandelier
Maytag oven not (micro) dull inside, lost protective enamel, what to do? Paint?
sorry but FIXYA does not know about all products manufactured in the entire world
Dec 07, 2017 | Maytag Microwave Ovens
Settings rubbed off oven
Maybe you can take a good picture of it and contact whirlpool??
Or IKEA?? Maybe they'll have records of the previous owner or the address of the installation ??
Nov 02, 2013 | Whirlpool Microwave Ovens
ReSet clock
consult the owner manual or if lost Google the model number with "manual" to try to locate one. You should also be able to call customer service with the model number for live help--I suspect they are getting a lot of similar calls right now.
Nov 05, 2012 | Sunbeam Microwave, 0.9 Cu.ft - Black
Hi, I have v old Kenwood 701 and also a a701a. Both are dripping grease and also have that "electrical" smell. Both could do with a clean internally and replace grease and any washers...
The grease from the bearings is not grease. It is old, dry oil. The motor bearings are oilite bearings made of phosphor Bronze and soak up the oil like blotting paper. They will need fresh oil. The cogs and screw use grease but most of the bearings are oilite and sewing machine grade oil will renovate them.
All of the above information is from when I renovated my mums Kenwood Mixer back in 1965.
Hope that helps.
Mar 29, 2011 | Microwave Ovens
Everythink works except the microwave will not start. Is there a fuze that can be replaced to fix this ? Model # NN-2551 I found the user manual on-line, but I can't find the product spec sheet breakdown...
I'm not sure what you mean by "everything works". do you mean that all the lights and the timer work. Could it be in the timer or clock mode? Try pushing the timerand cancel buttons together.
Try changing the time using the clock function.
I believe your model has a child lockout. Please check your manual for instructions on unlocking this function.
Is it hardwired or plugged in? If it is plugged in you can try a power reset, by unplugging it, waiting a few minutes and plugging it back in. It is completely unsafe to try to work on a hardwired Microwave.
Please let us know if this solution is helpful to you. Thank you.
Dec 20, 2010 | Panasonic NN-S255 Microwave Oven
I lost the instruction booklet in a move need to replace it I have the 6 cup processor model KP80B
You can download and print the instruction manual in PDF format by clicking this link.
On the page which opens, click on the "Download" button to download and save the manual.
Please note: Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this solves your problem. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Dec 13, 2010 | Microwave Ovens
Lost all light on control panel. Machine functions but I cant see what the settings are. Model 02420 S mfg date 6/02
If yours is a model DMT2420, you can get it repaired for $39.95 in most cases (details here) or order a control / display unit here.
If yours is a model DMO2420, you can get it repaired (details here) or order the control . display unit from the Pros here.
The service manuals and parts lists are here:
http://www.microwavedisplay.com/dmt2420_sm.pdf
http://www.microwavedisplay.com/dmt2420_parts_list.pdf
http://www.microwavedisplay.com/dmo2420_sm.pdf
http://www.microwavedisplay.com/dmo2420_parts_list.pdf
Apr 13, 2010 | Dacor DMT2420SS Microwave Oven
Clock changing
No, the owner's manual does not mention daylight savings time.
If you lost yours, you can download it here:
http://www.geappliances.com/service_and_support/literature/
Nov 04, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
24 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
