Question about Sony KDF-E50A10 50 in. LCD HDTV
Sony tv with yellow patches - Sony KDF-E50A10 50 in. LCD HDTV
Sony 72 inch 1080 HD TV - yellowing in the center of the screen. Recently replaced the lamp and adjusted the picture settings but the yellow patch remains. Please advise what is the best thing to do to...
I hate to say it, but your Optical Block aka Light Engine is going out on you. Sony has been extending Warranty on these since they have been so problematic, but this has been on a case by case basis. Your best bet is to call Sony and keep at them. If this gets you nowhere, it will not be cost effective to fix.
Apr 19, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a 42 in Sony HDTV model # KDF-42WE6555. I notice a few months ago a blue line down the left side. TV still wking good. Today I notice a yellow patch on the right side. TV is still wking good except...
i have the same problem but mine has a blue line surrounding the screen the tech took out the fly wheel part from inside this part has the 3 main colors with strips the blue side strip if you look at the glass it has the problem you see on your screen you have to replace that one section
Mar 10, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a Sony kv-27fs100. It has a greenish tint/patch along the left side and a bluish patch along the right side. Any ideas?
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 24, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Blue patch on right side of screen. strange dark pattern also.also has lots of yellow on the otherside of screen tv is about 5 years old.
If it looks like a cloud of colour, the optical block needs replacing. It is the heart of the LCD. We had ours replaced twice, under warranty.
May 09, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a slight yellowing in the center of my screen. We recently replaced the map, and have tried adjusting all picture settings but the yellow patch remains. It's a Sony Grand Wega, by the way.
Don't know if the DLP tvs have a Deguassing coil,inside it bazel frame.Take ur tv aparts check,see if u have big coil rapping with ectrical tapes fit inside ur bazel frame of ur tv.If yes,the componnents parts that make the coil work it dead.This coil demagnictize for the tv tube first turn.All regular small CRT tube tvs '30 inches and down have this dequassing coil inside it bazel frame.
Apr 11, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Picture had yellow tint and now there is no picture and red light is blinking next to lamp
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jan 15, 2010 | Sony KDS-R60XBR2 Television
I have a rear projection LCD TV which has developed a yellow patch on the screen. any Ideas?
http://www.sonysxrdtvclassaction.com/main/home.sfx
Read about it at the link I posted. The optical block is defective and it is at least $1000.00 repair.
I have a 60" Sony LCOS rear projection set and so far mine is great.
Good luck with it.
Bob
Nov 07, 2009 | Sony Televison & Video
Hi, Just bought a 26" sony bravia tv. I don't use cable or satillite. I just need to find out what kind of cable I need to connect my panasonic DVD player to the TV and which port do I plug it into?
The best quality would be a HDMI cable, if your DVD player has a HDMI port on the back.
Any of the HDMI ports on the TV can be configured to take the audio over HDMI (digital audio) or over a separate rca stereo patch cable (menu option in the TV for analog audio).
So if your DVD has HDMI, just buy a HDMI cable and you're done. If you cannot figure out how to switch the audio input, there is no big harm in just installing a separate RCA patch cable between the two for the sound.
The next-best would be a component-video cable (Red/Yellow/Green) RCA cable, with a separate red/white RCA audio cable.
Alternately, if your DVD has a S-video port, that is comparable to component video. Then you would need a separate audio cable as well.
Last but not least, if your DVD player is ancient, it may only have a yellow video out connection, then red/white for audio. You then just need a standard yellow/red/white RCA component cable.
Oct 23, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
TV shadows
Check the proximity of magnetic fields. Large Speakers near the TV for example will cause colour distortion.
Dec 24, 2007 | Televison & Video
Canopus ADVC-110
Hi! You must use a firewire in order to receive power - if you're going to use composite cables (red, white, yellow) you will have to purchase an AC adapter.
Oct 09, 2007 | Canopus ADVC-110 A/D Converter...
Sony KDF-E50A10 50 in. LCD HDTV Logo
13 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
