Question about Fujitsu Tablets & eReaders
Won t come out sleep mode - Fujitsu Tablets & eReaders
Why does my tablet keep turning off
Does it turn off, or simply enter sleep mode? If so, you can change when it sleeps by choosing Settings -> Auto-Lock -> and select a time. Hope this helps.
Feb 02, 2016 | Tablets & eReaders
Tablet keeps turning off while in use. Fully charged
Go into your settings and take it out of sleep or auto shut down mode.press the helpful button
Android Tablets Power Off and Sleep Options
Jan 26, 2016 | Visual Land Connect 9" Android Tablet...
My nextbook 10.1 windows 8.1 wont turn on its been charging now for more then 4 hours
Go to support.nextbookusa.com,
/support
Also go to www.ownersmanualdownload.net/factoryreset/nextbook
I couldnt find anything but These links will help surely.
Dec 23, 2014 | Tablets & eReaders
How to fix fujitsu t732 when it won't power on after sleep mode?
take the battery out and unplug it. Wait a minute and put it back, then try
Jul 04, 2014 | Fujitsu LifeBook T732 XBUY-T732-W7D-002...
My lenovo s820 keeps on restarting
The first thing to do is boot it in safe mode and let it go to sleep, then wake it up and see if the problem goes away, If it does then the problem is related to something in the startup programs.
Feb 03, 2014 | Lenovo S820 Android 4.2 MTK6589 Quad-core...
My Micro Cruz keeps turning itself on. Won't stay off for longer than five minutes then the screen powers up and stays on. I have resorted to powering it off after use which sucks as it looses time, my...
So it's your screen that is coming back on after you press the power button to put it into sleep mode (not all the way off)? Flashing to the new firmware made this issue even worse. I would try a full reset. Back up apps and follow the procedure for resetting the device (press the hole at the top with a paper clip don't use a mechanical pencil...).
Other than this I would reflash or flash to a new rom it seems like you have a defect not a software issue. Flashing to the the updated rom should've fixed any problem that was software based not made it worse. It seems like there is a connection loose and it's triggering the device to wake up from sleep mode. If you feel like you have it in you, you can pull the device apart and try securing all connections but this is not recommended.
Oct 31, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
Kindle light is orange when I charge but even after of hours of charging continuous efforts to turn on Kindle, it won't turn on.
Try to slide and hold the on switch until after the power light blinks three times (should happen after a little more than 5 seconds). Release the switch after the blinks and the Kindle should start up.
This is only necessary if the Kindle was switched off by the same method before, or if the battery was completely drained. A short nudge of the power switch merely puts it in and out of a power-saving sleep mode, the prolonged hold really cuts / reinstates power.
Jul 16, 2011 | Amazon Kindle Wireless Reading Device
On sleep mode, would not wake even if i slide the switch and hold it for 20 seconds.
The hard reset takes 45 seconds sliding the button, It also might have run out of battery which puts it into a mode that looks like sleep mode
Mar 11, 2011 | Amazon Kindle Wireless Reading Device
Tablets & eReaders Logo
26 people viewed this question
Top Fujitsu Tablets & eReaders Experts
k24674
Michael Vincent Cruz
Tony
Are you a Fujitsu Tablet and eReader Expert? Answer questions, earn points and help others
