Question about Kenmore 72123 Stainless Steel Countertop Microwave 1.2 Cu Ft, 1100 Watts
How do i change the Kenmore 72123 lightbulb - Kenmore 72123 Stainless Steel Countertop Microwave 1.2 Cu Ft, 1100 Watts
How can I replace lightbulb in my kenmore microwave?
If there is alight you can open the oven cover and move around sideways the cover will open
Sep 13, 2014 | Kenmore 69109 Microwave Oven
How to replace lightbulb
Is this a countertop microwave or an over-the-rang (OTR) microwave? If it's a countertop model, you need to completely remove the outer case to get to the lightbulb. If it's and OTR microwave, there usually is an access cover located behind the grill vent. You can remove that grille vent by removing the 2 to 4 screws above the grill vent. Then either slide the grill vent 1/4" to the left to remove it, or else (depending on the model), just pull out the top of the grill vent, followed by the bottom. Then you should be able to see the lightbulb access cover. Usually there is 1 screw that you have to remove. But unplug the microwave before you to any further! Now remove the screw, lift up and remove the cover, and you should be able to get to the light bulb.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Aug 10, 2014 | Kenmore Microwave Ovens
How do you replace the lightbulb on #5658972790
The light is located on the right side under the air duct attached to the magnetron.
See these files:
http://wwww.microwavedisplay.com/safety.txt
http://wwww.microwavedisplay.com/disassembly.txt
You can find handy exploded views like the one below at the Sears Parts Site.
Sep 15, 2009 | Kenmore Microwave Ovens
How do I change the lightbulb?
4359741 You have to remove the outer case and it will be accessible. Eric
Aug 02, 2009 | Whirlpool GT4185SK Microwave Oven
How do i change the lightbulb in a Kenmore Microwave
a microwave that is that old should be replaced!! period... for your safety... that old ,will leak micro waves into your kitchen..truly! not safe
Mar 15, 2009 | Microwave Ovens
Changed lightbulb
simply changing the lightbulb should not cause a problem like that. It sounds like you accidently shorted out two terminals during the process, which probably blew out the power board on the unit. I wouldn't trust it any further unless you were to take the entire unit apart and find the "blown up" component and replace the board that it's on. Believe it or not, it's not that hard a job if you're up to it.
Apr 22, 2008 | Goldstar MV-1526 Microwave Oven
CHANGING LIGHTBULB ON MICROWAVE
they should be torx # 15 0r # 20 this is not aifficult tool set to get unless the manufacturer put high security type torx and those have a small nipple in the middle of the screw so the tool has a small hole in the middle of the end. Good Luck
May 21, 2006 | Kenmore Brew 'n Wave 63992/63999 Microwave...
Kenmore 72123 Stainless Steel Countertop Microwave 1.2 Cu Ft, 1100 Watts Logo
42 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
