Question about Frigidaire Refrigerators
Hole in coils
Have a frigidaire gallery fridge,looks like the coil has a hole can it be fix or will need replacement
22yooper
  • 828 Answers
SOURCE: Frigidaire Gallery Side by Side - Fridge not cooling
Locate the defrost timer and rotate the dial a small amount clockwise. If the compressor starts the timer should be replaced. If the compressor does not start check the temperature control. It may be bad, if it is bad try jumpering the thermostat wires. If it starts and runs the thermostat is bad. Replace the thermostat.
Posted on May 26, 2008
sandy_s
  • 111 Answers
SOURCE: Frigidaire Gallery Series M# GLHS36EESB5
check to make sure there is nothing blocking the water lines and no kinks in the water lines, you did not say if it had an ice maker, and if it is affected.
The frigidaires also has a plastic tube coiled under the back to dispense cold water make sure this tube is not kinked.
Hope this helps
Posted on Jul 02, 2008
SOURCE: Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Posted on Sep 26, 2008
aasc
  • 1606 Answers
SOURCE: need freon recharge. punctures freezer coil in
You punctured the aluminum evaporator . In the many years I've been in refrigeration , I have yet to find any way to patch a hole in the evaporator . I've used epoxy , solder , and all different advertised ways to try to patch aluminum . Nothing worked ( for long anyway ) . My suggestion would be to buy another refrig . You will be wasting time and money trying to " fix " this problem . To repair it yourself , you have to have a license to buy R12 , maybe you can buy R134A without a license , you have to look on the " modell , serial number tak to see which it uses and how much to use . Also , the system has to evacuated ( all air removed from the lines ) . Do you have a vacuum pump ? You have to buy a solder on connector ( or saddle valve which WILL leak eventually unless you get a solder on valve ) which will connect to the larger tubing on the compressor or use the access line already on the compressor but is pinched off . Do you have guages for the refrigerant type you need to use ? Once you have these things , reply back and myself or someone else will help you procede .
Posted on Aug 20, 2009
dmftrucker
  • 1922 Answers
SOURCE: Frigidair Gallery fridge/freezer... Freezer is
change the control board in the rear lower left corner of unit part# 4334000 2 appliance parts pros
Posted on Nov 02, 2009
Refigerator runs but does not get cold
Check the fridge's temperature or thermostat control to confirm that it was not accidentally turned up.
Inspect the appliance's door seals to ensure that they are not cracked or have come loose.
lean the fridge's condenser coils. Condenser coils displace hot air from the refrigerator by drawing heat away from the appliance with a fan. Vacuum the condenser coils to remove any dust and dirt accumulated on them, then use warm, soapy water and a clean cloth to clean the condenser coils of any remaining debris. Examine the drain line, located under the refrigerator, if above does not fix it , it may be low on freon, or there is a hole in a line.
Apr 21, 2012 | Frigidaire Refrigerators
Frigidaire Gallery FRS24XGCW Regrigerator is not cooling. The freezer side is about the temp of the normal refrigerator side.
Remove the grill along the bottom of your refrigerator. Locate the drip pan, using a flashlight if necessary. The pan should be sitting on a set of black condenser coils.
Remove the pan and wash it. Use a mixture of warm, soapy water and bleach to kill the mold.
Reinstall the pan and the grill.
Locate the coils. They look like thin, black radiators and may be underneath the fridge or attached to the back.
If the coils are on the back, pull the refrigerator away from the wall, then vacuum the dusty coils, using the brush and crevice attachments. Reinstall the refrigerator grill.
If the coils are underneath, pull off the grill and remove the drip pan. Vacuum the dusty coils, using the crevice attachment to get between them. Take care not to damage the delicate coils. Reinstall the refrigerator grill.
Mar 01, 2011 | Frigidaire Refrigerators
I have a frigidaire gallery side by side and the bottom cooling coils inside the freezer are frosting up. It is not ice, just looks like snow. What should I do to fix the problem, it's not freezing or...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 16, 2010 | Frigidaire PLHS267ZA Side by Side...
The compressor and fan run but the refrigerator and freezer compartment do not cool down to an adequate temperature. The freezer does not get below freezing (32F) and the fridge does not get below 55F
Check your compressor for over heat (put your hand on it without burning)
Check for ice on back wall of freezer and on the freezer coils (defrost problem)
Check cond fan in back of fridge.
Clean cond coils
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 07, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Freezer freezes up and don't know if there is a reset
sounds like the condenser is bad, feel the copper coils they should be cold and the condenser should be hot/
May 20, 2009 | Frigidaire Gallery GLHT214TJ Top Freezer...
Why doesn't my fridge cool?
while I agree with your technician that there may be a blockage in the coil or more likely the capillary tube but turning it off and on will not fix it. to fix this correctly the evpaporator, heat exchanger, compressor and filter drier need to be replaced as well as the condenser and mullion loop need to be flushed.
when the defrost heater failed and the refrigerant escaped the unit pulled moisture into the system causing this blockage and it will cause a lot of other troubles such as acid build up in the system if not repaired properly.
I know this is not what you wanted to hear because this will be very expensive to repair. If I can be of further assistance please ask thanks Peyton
Mar 04, 2009 | Refrigerators
Freezer and Fridge are both not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
hhsg
Jan 30, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery Series M# GLHS36EESB5 S#LA53808237 The indoor water dispenser stopped. I replaced the filter but nothing changed. The fridge is 18 months old.
Hope this helps
Jul 02, 2008 | Frigidaire Refrigerators
Dec 09, 2007 | Frigidaire Refrigerators
Refrigerators Logo
62 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
