Question about Homelite Garden
Trimmer runs great but head does not turn when it makes contact
    Scholar:
  • 81 Answers
Nine times out of ten this problem is caused by one of two reasons. The engine has vibrated the screws lose and allowed the top of the flexshaft to move out of its square or the flexshaft has twisted in two. If screws are lose shove the flexshaft back into place and tighten the screws down, and if it becomes habit with your trimmer, put some locktight on the screws. If it is the flexshaft that has twisted in two you will have to replace it.
Posted on Jun 19, 2009
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Why doesn't the cutting head on Stihl F38 trimmer spin?
Maybe the cutter head has come loose from the shaft. make sure the head is engaged to the drive tube properly
Jul 09, 2014 | Stihl Garden
Replace trimmer line
The steps for replacing line in a single line trimmer head are virtually the same for many trimmer head types, like double line trimmer heads.
1. Remove the Trimmer Head Spool
Removing the spool is the first step in replacing trimmer line in any conventional trimmer head, but trimmer head spools can disassemble in different ways.
The trimmer head pictured above and below disassembles by simply unscrewing the knob around its arbor bolt. Other trimmer heads can use press tab and other twisting styles for disassembly.
2. Insert Trimmer Line and Wind the Line
Single line trimmer heads have just one channel in their spools for winding line. The channel will have a hole in it somewhere that keeps the line in place as it is wound around the spool. Insert one end of the trimmer line in the hole.
Depending on the trimmer head, it might be helpful to bend a small portion of the cutting line at an angle before inserting it in the starter hole. Also, cutting the line at an angle can help this first step on some trimmer heads.
Of course, it is also important to make sure that the replacement line matches the diameter specification of the trimmer head before beginning. Once the line is started correctly in the channel hole, you're ready to wind. Most trimmer heads will indicated the correct winding direction right on the spool somewhere.
It's also important to wind the line carefully, keeping it in neat rows as much as possible. The line will have a much higher chance to feed incorrectly during trimmer use if it suffers from sloppy winding.
3. Snap the Line into its Retaining Notch
A conventional trimmer head will have a retainer on its spool. Snap the end of the trimmer line into the retainer after it is wound around the spool. The retainer will hold the line in place as the spool is replaced in the trimmer head assembly.
4. Replace the Trimmer Head Spool
With the cutting line held in place, the spool is ready to be replaced in the trimmer head assembly.
First feed the extra trimmer line through the trimmer head eyelet. Make sure to release the line from the retainer before completely securing the spool into position.
Replace any knobs, bolts, or other trimmer head pieces removed during disassembly.
Your single line trimmer line is now reloaded, and your trimmer should be ready to get back to work.
Although there are many steps to reloading line the conventional way, a little practice and familiarity with your trimmer will speed the process up a great deal. Once you're up to speed, reloading trimmer line this way can take less than five minutes.
If you want to know about the double line replacement, please click this
Thanks.
Apr 01, 2012 | Garden
Just bought a brand new Husqvarna 224L Trimmer. Started it up and it runs fine. But the trimmer head will not turn. It just makes a grinding noise. The manual that came with the trimmer is useless. It says...
Hi, take it back to the dealer as the powered or gear box have not been fitted correctly. The noise you can hear is most likely the clutch drive grinding on the drive shaft. Hope this helps, regards Phil.
Jul 21, 2011 | Husqvarna 28cc Gas Line Trimmer
Put in replacement spool cutting great as usual went edge the head with spool of line wont turn went back to normal position spool will not spin to cut motor runs spool head not engaging how can I fix
pull the head completely off and make sure that the shaft is not broken, if not then line it back into the head slot and put back together and test it out, Tim
May 29, 2011 | Black & Decker 14" Grass Hog Xp...
Makita gas trimmer RBC221. engine runs fine but trimmer head does not turn.
would suggest that the cable that runs the head is broken or there is too much material wrapped around the head... remove the engine off the trimmer and check the cable that runs to the head....
Apr 07, 2011 | Makita EM4251 16" 4 - stroke String...
Garden Logo
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
