Question about Staples SPL-P500 Printing Calculator
Calculator is printing weird numbers - Staples SPL-P500 Printing Calculator
E appear on screen, number keys not working.what should I do.
Customer Reviews: Canon MP11DX Printing Calculator
www.amazon.com/Canon...Calculator/.../B0006HWF...
Amazon.com, Inc.The keys (i.e., numbers) get stuck almost every time I use it. I have to actually wiggle the numbers so I can enter the next number. It's not the tape on the ribbon; ...
3 Using your calculator for fractions - The Open University
www.open.edu/...calculator/content-section...
United States Open UniversityMay 3, 2012 - Early Years ยท Working with Young People .... 11 Natural logarithms and powers of e on your calculator ... The figure shows the display on a calculator screen.... If your calculator is not in Math mode, repeat the steps of Activity 1. ... arrow keysto move between the boxes when inputting the mixed number.
[PDF]Canon MP270 series / MP250 series On-screen Manual
Dec 15, 2015 | Canon P27-DH 12 Digit Mini Desktop...
Only prints in red
may have print ribbon installed upside down. what happens if you try printing a negative number? if that number prints in black, try turning ink ribbon over
Jan 02, 2014 | Canon MP49D Calculator
Where is the reset button?
To reset the calculator, remove all four AAA batteries. Press and hold the ON button for fifteen seconds. Replace the batteries.
Just out of curiosity, could you describe this weird behavior?
Sep 12, 2012 | Texas Instruments TI-84 Plus Silver...
My TI-84 calculater is calculating the problems in a very weird way. For instance if i type in 2x2 it will give me the answer 4e0. Is there a way to fix it?
That is the right result: 2x2 is 4 times 10 to the 0th power. But if you don't want your answer in scientific notation, press MODE, highlight NORMAL on the first line, press ENTER, then press 2ND [QUIT]. (You can also select the number of digits on the second line, or FLOAT and let the calculator choose.)
Oct 07, 2010 | Texas Instruments TI-84 Plus Calculator
How to turn printing on and off?
PRINT KEY: To save paper you can only print what is displayed, even in non-print mode. Pressing after the entry of a number will print the entry with the symbol “#” even in non-print mode. Pressing will insert a separator into a number entry such as a code, date, etc. Separators are displayed as a period and dashes but printed as periods. MEMORY + KEY / PRINT ON / OFF KEY: Pressing selects print mode or non-print mode. Cause the calculator to operate in a display / print or display only mode, depending upon the calculator’s present state. “P” on the display: Print mode. “NP” on the display: Non-print mode. MEMORY – KEY / DECIMAL SELECTION KEY: Pressing sets the number of decimal places in the result. “F” on the display: The answer is displayed in the floating decimal system. “3, 2, 1, 0” on the display: Presets the number of decimal places in the answer. “A” on the display (Add mode): The decimal point in addition and subtraction entries is automatically positioned to the 2nd digit from the lowest digit of entry number. Use of the add mode permits addition and subtraction of numbers without entry of the decimal point. Use of , and will automatically override the add mode and decimally correct answers will be printed.
Aug 18, 2010 | Sharp EL-1611P Calculator
Window dimensions
Press the WINDOW key on the top row and change the values to suit the particular function you're graphing.
May 15, 2009 | Texas Instruments TI-83 Plus Calculator
My Canon P23-DH calculator is printing out weird symbols
I also have a Canon P23-DH 111 that is printing strange symbols. This has happened after an electrical storm.
I contacted Canon Support and they verified that the board inside has been corrupted by a power surge.
I now have a new Canon P23-DH V and I invested in a surge protector.
My grandaughter is playing with the old machine.
Mar 09, 2009 | Canon P23-DH Calculator
POSSESSED 10 KEY CALCULATOR- DONT LAUGH!
your printer needs some mechnical adjustement for the print wheel and gear train by qualified service technician.
Feb 27, 2008 | Victor 1280-6 Calculator
Percentage button!!
they call it hardware malfunction. try removing all batteries in it and wait for 30 seconds before reinserting the batteries. If the same problem still exist, the unit is permanently damaged.
Aug 23, 2007 | Casio MS-80TV Scientific Calculator
Weird lines, characters, symbols etc.
It sounds like you need to put in a new set of back-up batteries. They can be found behind where the AA batteries are.
Aug 17, 2007 | Texas Instruments TI-83 Plus Calculator
Staples SPL-P500 Printing Calculator Logo
104 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Randy Schumann
Randy Schumann
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
