Question about Poulan Pro PP4620AVX 46cc Gas Chainsaw With 20" Bar
Poulan model pp4620 avx gas tank does not vent
Fuel will not suction from tank. saw does not have primer bulb
  • 97 Answers
SOURCE: routing of fuel lines from tank to primer bulb to carb
Line with filter goes to carb inlet,
Line from carb goes to inlet side of bulb.
Line from bulb goes to tank
Posted on Mar 21, 2009
dontbother10
  • 2220 Answers
SOURCE: Poulan chainsaw primer bulb replacement
Hello Jay;
The primer listed for your saw and sold by Poulan does not include hoses (do an Internet search for the part number below, there are photos). Hoses are sold separately and are 2 different sizes. You can cap the carburetor to primer connection at the carburetor and your saw will run as all chainsaws did before the addition of the air purge system.
An example of a Poulan "2375LE Gas saw Type 2" follows (may not be your saw):
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
http://www.ordertree.com/modelinfo/PWE/2375LE-Gas-Saw-Type-2/75.2375LE-Gas-Saw-Type-2.1.59.1.html
See the "Engine Assembly" print; item 4; pn 530047213.
Small hose in the tank with a filter on the end (long enough to reach all corners as the saw is moved) the opposite end connects to the carburetor.
A second small hose connects between the second carburetor fitting and the suction side of the primer.
A large hose connects between the pressure side of the primer and fuel tank (return).
I suggest you replace ALL hoses. Do you change tires on at a time?
Plumb the system EXACTLY as the diagram shows. If it will not run you have the 2 connections on the carburetor reversed. It might make sense to leave them long enough to swap until everything is working.
A typical fuel system and a couple of suggestions can be found here:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If your saw is not a Type 2 or an LE (code for Wild Thing) you can find the correct IPL here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 15, 2010
  • 4088 Answers
SOURCE: Bar oil leaks into storage case when chainsaw not
The easy fix is to drain the oil tank when not in use. Many saws will leak some oil initially, but should not continue to do so. If it is making a large puddle, oil is getting past the oil pump which may be worn from long use. Make sure the tank vent is not plugged as heat from the engine can increase pressure in the tank thus forcing oil out. Hope this helps!
Posted on Mar 28, 2010
dontbother10
  • 2220 Answers
SOURCE: Primer bulb-carb routing
It should be like this.
Lou
Posted on Apr 10, 2010
  • 4088 Answers
SOURCE: I have a poulan 2450 chainsaw and i can't get the
You may be overfilling the tank somewhat so that expanding fuel (from engine heat) is being pushed out of the vent. Check the fuel filter for plugging and all of the fuel lines for any rot, splitting, or other damage. The primer bulb is supposed to pull fuel from the fuel filter, then through the carburetor and on to the primer which should push the excess back into the tank through another line. If the above does not allow the primer to pump fuel, then dismantle the carburetor, clean with carburetor spray cleaner, and rekit it. Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetors--theory and troubleshooting. This information applies to most brands of carburetor. Hope this gets you running!
Posted on May 31, 2010
Diagram of fuel lines from tank to primer to carb and back to tank for a poulan 2050 chainsaw.
clip_image002.gifFuel components are onthe "Engine Assembly" & "Handle, Chassis, & BarAssembly" detail pages.
Replacement fuel lines can be found at yourlocal chainsaw seller/mechanic. They are different diameters.
Fuel Line Replacement
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Feb 21, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Need to know how to connect the gas lines from the primer bulb to the carburetor on a poulan woodshark model 1950 chainsaw
The lines should be connected to push fuel into the carburetor. The output (overflow) of the carb is routed back into the tank. So, two lines in the tank, one is an overflow (return) and the other is the suction. On the primer one line from the tank and the other to the carb. Connect so as to "push" fuel into the carb when the primer bulb is pushed.
Jun 16, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
I have a poulan 2450 chainsaw and i can't get the primer bulb to **** any gas, the bulb is in good condition however there is gas leaking out of the gas cap in the center of it, do I need a new gas cap and...
May 31, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Fuel lines from gas tank where do they go need picture has primer bulb
Typical Fuel System (Primer Bulb and fuel lines may not apply)
http://www.img4free.com/images/Lou98321/fuelsystem.jpg
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
Take lots of notes and a few digital photographs to help with reassembly.
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but on multiple illustrations.
Poulan.com
The dash number of your serial number is the type. HTH
Lou
Dec 23, 2009 | Poulan Garden
How do I hook up a fuel line to a carbuertor on a Poulan 18 inch?
http://www.img4free.com/thumbs/Lou98321/fuelsystem.jpg
Poulan.com
Lou
Dec 23, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a Poulan 2450 thats not getting any fuel, I drained the fuel tank. When I looked inside and the fuel line,the white filter and the gromet which goes from the inside to the outside of the tank was...
Typical fuel system:
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best.
Poulan.com
2450 Gas Saw Type# - # is the dash number of your serial number.
HTH
Lou
No one illustration shows all fuel system components.
Nov 28, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Replace gas line poulan-4000 chain saw
9803f93.gif Fuel Line Replacement by SmallEng.com
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
Take lots of notes and a few digital photographs to help with reassembly. HTH
Lou
Nov 07, 2009 | Poulan Pro Chain Saw 46cc 20"
Fuel lines have rotted off. need to replace then
Mr Tittle;
It isn't good but it's all there is.
What little fuel system system detail there is can be found here:
Poulan.com
If it is a 2375 WildThing find 2375LE Gas Saw Type ?. The last digit of your serial number should be a -1 or -2, the type.
  • The filtered hose from the fuel tank connects directly to the carburetor input connection.
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as the bulb reinflates).
  • The pressure side of the primer returns any excess fuel to the tank as it is depressed.
HTH
Lou
Oct 24, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I need to replace the gas lines The lines fell apart unsure were the parts go were can I find a diagram of the gas lines
Poulan.com
HTH
Lou
Poulan Pro PP4620AVX 46cc Gas Chainsaw With 20" Bar Logo
87 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
