Question about Motorola Mobility XT907 DROID RAZR M Verizon Unlocked Black
Droid RAZR m losing charge quickly
My phone won't charge and it also loses a charge quickly; I've tried turning it on an off. I make sure apps aren't left open. Help
  • Official Brand Answer
  • 1,623 Answers
Could be the battery is exhausted.
Mark
Motorola Support
Posted on Feb 10, 2015
zeusfaber
  • 247 Answers
SOURCE: Phone dies quickly after charging
It would be helpful to know just how quickly the battery is going flat, and I'm assuming there's no history of the phone having been damaged, but... Try swapping the battery for one from a friend's phone. If that cures the problem, you need to buy a new battery (they don't last forever). Otherwise, try charging the battery fully in a friend's phone using their charger, then see how long it lasts. If this lasts much longer, the problem is that the phone/charger combination isn't charging the battery properly. Mix and match chargers and handsets (mark which are yours before you start, or you will get mixed up) to identify where the problem lies. If the battery isn't old and tired, and the phone is charging it properly, then the problem must be that the phone is drawing excessive current. This could be because you've got it set up to do some power-hungry thing (backlight continuously on, playing MP3s or FM, promiscuously Bluetoothing or IR communicating, etc). Shut down all the functions you don't actually need at the time and see if that makes any different. Once you've eliminated all those, you're left with the liklihood that the phone has a fault which is making it draw excess current. Not good news, but at least you've eliminated all the other possibilities. A.
Posted on Jul 25, 2007
  • 4102 Answers
SOURCE: charging problems
have you tried your dads battery in your phone it sounds like the battery is dead if your charger works on your dads phone then you know it not the charger the chances are it is the battery it would only be the phone if it has been dropped or got wet if this hasnt happened then the problem is the battery if your dads battery is the same then try charging his batt through your phone that way you would know if it was phone or battery.
If you take the phone into any phone shop they will test the phone and battery for free for you they can try the battery and also try a new battery in your phone and they will tell you if it is phone or battery but from my experiance it is going to be the battery let me know how you get on ok
Posted on Nov 27, 2007
  • 7 Answers
SOURCE: Motorazr V3m gets hot and loses charge
there could be a problem with your hard drive on your phone, or the intercooler in it that has stopped running, there is nothing that you can do about it other than take it back to verizon
Posted on Feb 07, 2008
ipodslinger
  • 688 Answers
SOURCE: won t charge
Download Motorola Phone tools and get a new battery for your phone.
The batteries go bad about once a year, sometimes longer.
if this helps you please leave a vote on fixya
Posted on May 21, 2009
SOURCE: Tracfone screen says "charge complete", phone won't turn on.
phone is charged won't come on at all
Posted on Jan 06, 2010
Pasward does not work on logging in with my phone
Mark
Would like to help but need some more specifics on what is wrong with your Droid Turbo.
Mark
Motorola Support
Jan 19, 2015 | Motorola Mobility Droid RAZR HD
How to restore droid razr hd when password failed too many times
Your going to have to hard reset the phone and lose all your data.
Hold turn on the phone by holding down the power and volume buttons.
Aug 01, 2014 | Motorola Mobility Droid RAZR HD
MY DROID RAZR HD WONT TURN ON.
Try to charged it for 5-6 hours and then try to power on.
Mark
Motorola Support
Jul 04, 2014 | Motorola Mobility Droid RAZR HD
Droid razr max stuck at startup
Have you tried an external reset? https://motorola-global-portal.custhelp.com/app/answers/prod_answer_detail/a_id/77256/p/30%2C6720%2C8417/kw/reset
Mark
Motorola Support
Feb 19, 2014 | Motorola Mobility DROID RAZR Maxx 4G...
I charged my droid razr maxx to 100% then battery keeps dying within 15 minutes pls help
Hello My Dear Friend:"::
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 19, 2013 | Motorola Mobility Motorla MOTXT912 DROID...
I charge my eris all night and only gets 40% life
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Aug 20, 2012 | HTC Droid Eris by
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
When riding in 5th gear starting losing cylinders. and bike dies? then bike won't start electrical start. can' roll bump start bike if i let sit for an hour. thn bike dies quickly. is my m
More likely to be your ignition coils. They heat up and expand this can cause an open circuit which will close up again when it has cooled down. Although, a bad charging system may cause this problem. Check the battery voltage with engine switched off ( approx 12 volts) and with the engine running (approx 14 volts) If you are getting 14 volts then your battery is dead, if you aren't, then your charging system has a fault.
May 06, 2012 | Honda CB 750 Motorcycles
Lost pairing?
First when ya call connects, hit the Menu key (three lines inthe center) choose USE HANDSET.
Second Make sure the Bluetooth is fully charged, andit seems to lose charge fast.
Dec 15, 2007 | Motorola Mobility H300 Wireless Headset
Motorola Mobility XT907 DROID RAZR M Verizon Unlocked Black Logo
100 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
