Question about Magnum Remusshield Finger Touch Immobilizer Honda Aquatrax F-15
Engine turns but wiil not start
It seems to be a fault with the immobiliser as the immobiliser warning light on the dash will not go out.
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 64 Answers
Have a look at the users manual generally there is a way of disabling the immobilizer for towing or maintenance some are as simple as a key in a lock under the bonnet, once the immobilizer is disabled try again, if that does not work look at the wiring diagram and see where the coil/s pick up the live feed and run a patch lead from the battery positive to that wire then try again that will eliminate any wiring /immobilizer issues if it does not start then there may be other problems make sure that there is no internal issues by removing the plugs and cranking the engine if oil or water vapour is ejected during cranking you may have a blown head gasket
Posted on Dec 30, 2014
My car won't start but battery is good what could it be.
If the engine cranks check the spark, injector pulse, fuel pressure. If it seems completely dead but dash lights and equipment work ok I suggest you check the immobiliser is disarming before you start getting too involved.
If it isn't cranking manually energise starter. If it starts there is a fault on the starter circuit. If it doesn't try the immobiliser first.
Aug 10, 2016 | Cars & Trucks
Anti pollution fault, Citreon Dispatch/ immobilises the engine?
Disconnect batt a min....see if it clears. May need it hookd to a scanner to tell issue. Emmisions can effect motor and computr
Nov 17, 2015 | Cars & Trucks
Spanner showing on dash when engine running vauxhall vectra c
VECTRA CAR WITH SPANNER WARNING LIGHT This Vauxhall Vectra car with spanner warning light illuminates or flashes yellow. Light will illuminate for around 3 seconds when the ignition is switched on. If the fault light illuminates whilst the engine is running, this signifies a fault within the engine or gearbox electronics system. The system will switch to emergency mode where fuel consumption may increase and the vehicles drivability reduced. A Vauxhall workshop must be consulted. If the light flashes whilst the engine is running, this signifies a fault within the electronic immobiliser system and the engine will not be able to be restarted.
Oct 25, 2015 | Vauxhall Cars & Trucks
1998 Saturn sl2 died while driving. Lights on the dash board come on when I turn the key, but then engine doesn't crank or start
run the fault codes and check for cam/crank position sensor failure
check that he cam shaft is turning ( broken belt)
check immobiliser operation
Jul 31, 2015 | Saturn Cars & Trucks
Rexton immobiliser
check that the key is in program with the immobiliser after the battery change
Jan 11, 2014 | Cars & Trucks
The warning lamp for the electronic immobiliser flashes continuously for the audi and it cant start. This started after we struggled to get the new battery in
Whenever this warning or any other stays on in the dash it is indicating that the systems control module has detected a fault, it then disables the system as long as the light is on. You must now have the dealer hook up a special electronic diagnostic tool and "scan" the system for the fault code that is stored for the problem(s)
Sep 27, 2012 | 1996 Audi A4
1998 terrano immobiliser fault wont start
hi, i have nissan terrano wen i switched on engine light flash and start engine its start then go of.nissan terrano patrol engine
Sep 06, 2012 | Nissan Sentra Cars & Trucks
Put in keycard and all seems ok but press start and engine turns over but not start
is the engine immobiliser light going out?its a red light on the dash.if it dont it will turn over but wont start.
Jun 22, 2011 | 2000 Renault Sportwagon
My renault espace mk3 will not start, has an immobiliser fault. The light on the dash stays on constantly, engine turns over but will not start . I've been trying to get hold of wiring diagram to test...
immobiliser has set itself and usually wont reset unless you have the code for it,if you contact main dealer they might be able to help you with getting the code, if not take it to an auto electricain who might be able to bypass it
Aug 28, 2009 | 2000 Renault 181
Engine immobiliser fault light on after battery flat
There might be an immobiliser fault or a problem with the key transponder but try the following before you call the dealer or local auto locksmith.
Disconnect the battery and leave overnight. Next morning open the car, put the ignition key in and switch on the ignition - then connect the battery.
Sep 17, 2017 | Vehicle Parts & Accessories
Magnum Remusshield Finger Touch Immobilizer Honda Aquatrax F-15 Logo
142 people viewed this question
Top Magnum Tuning Vehicle Parts & Accessories Experts
baire
jim
Level 1 Expert
mekanik84
Are you a Magnum Tuning Vehicle Part and Accessory Expert? Answer questions, earn points and help others
