Question about Garden
Actinovate mixing instructions needed - Garden
Do you have to mix oil and fuel before putting in the fuel tank if so what oil and petrol do i need to use
Yes. You need to purchase two-cycle oil and mix it with petrol according to the chainsaw manufacturer instructions (this information is in the manual). It will specify the appropriate mix for your chainsaw.
Apr 23, 2015 | Garden
Need instructions for DQ Blizzard Maker
1st add crushed ice and equal water outside the tin in the blizzard
2nd add 3/4 of salt to the the salt water
3rd put the cap on and in a separate cup mix ice cream mix and 3/4 of half and half and mix until completely dissolved
4th put the mix in the tin cup and add the cap
5th stir with flat spinner not the swirly one spin for 10 min when done push ice cream with swirly stirrer
Nov 01, 2013 | Spin Master 1001130 DQ BLIZZARD MAKER
I have an Octave CopyMaster II Plexwriter Premium and I need instructions in how to mix tracks and use it
Manual (found using a google search)
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&ved=0CCUQFjAB&url=http%3A%2F%2Fwww.octave.com%2Fpdf%2Fmanuals%2Fduplicators%2Fcopymaster%2FCM_II_III_manual.pdf&ei=9HhnUIvHGu2DyAGclYHQCQ&usg=AFQjCNHvdBGpeOkTn2GP_5at9_Vx0JZvYQ&sig2=SSdaRM0vM6ASyYEIIoE2ag
Sep 29, 2012 | Octave Copy Master II Burner
Do you have the instructions on how to make the dog cupcakes for pamper your dog from scientific explorer? p9983 and c249.07
my younger sister and i lost the instructions to the pamper your dog kit cupcakes instructions. so we tried this, add the cake mix, 2 eggs and 2 teaspoons of butter. after mixed preheat oven to 355 degrees. don't forget to beat all ingredients for 3 to 4 mins. bake for 15 to 20 mins. we also lost how to do the frosting but haven't figured it out yet. we will post when it pops in our head and works out.
Jan 22, 2012 | Toys
What kind of gas
Regular unleaded gas mixed with 2 cycle oil. (You need to check your model for mixture ratio but 30:1 (thirty parts gas to one part oil mix) is usually a good place to start) You can find mixing instructions on the back of the 2 cycle oil container
Dec 08, 2010 | Garden
I have a Gaggia Ice cream maker but i have lost the instructions - do you know where i can get another copy please? Margaret
Do you need instructions for the mix or do you want instruction for how to freeze the mix?
Receipts should be easy.
As far as freezing, you need ice and salt. Probably one bag of ice and 5 lbs of salt.
Place the canister in the contailer. Crush some ice up ... pack it around the base about 2 inches deep. Put in a layer of salt. Repeat this until you are full --- Ice - salt - ice - salt etc. When you get to the top, stop plug in or start cranking. When the motor stalls or when your arm falls off, stop. Have your younger assistant put a towel over the top. Make sure the drain is open. Let the mix 'cure'. Go recover. Come back in 20 - 30 minutes and enjoy your ice cream.
I hope you find this to be of value. Enjoy your Ice Crean!
A
Sep 24, 2009 | Ice Cream Makers
Echo CS-302 chain saw with no instructions (Inherited)
the echo cs302 is equiped with an automatic oiler that lubricates when the engine is running the manual states the unit runs on a 20:1 mixture 89 octane fuel with 6.4 oz of tcw3 oil per gallon
Apr 10, 2009 | Echo Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
