Question about Canon FAX-B820 Plain Paper Bubblejet
Code 342 Hello, how can i
Obd2 code 342
The fault code P0342 means "Camshaft Positon Sensor "A"
Circuit Low"
elm327 scanner
Sep 04, 2012 | Chevrolet Optra Cars & Trucks
Sitecom WL-342 Wireless Router won't access internet.
Make sure there is a network cable going from your ADSL modem into the WAN connection of the router.
If the ADSL modem is wireless, then it is also a router in whihc case you will want to bypass the WL-342 all together.
Thanks,
Pat
Apr 01, 2010 | Computers & Internet
Symbol LS2208 I need to scan in a barcode then add a tab then input 1
From the LS2208 Product Reference Guide you should print and scan the following barcodes:
Begin New Rule Adobe page 232 of 342
Send all data that remains Adobe page 246 of 342
Send tab key Adobe page 286 of 342
Send 1 Adobe page 270 of 342
Save Rule Adobe page 232 of 342
That should do it. If you find the scanner sends the 1 too quickly after the tab key you may want to scan Send Pause in between the Send tab key and Send 1 statements.
Mar 09, 2010 | Symbol LS2208 Handheld
10-342 error code
Hi there
10-342 Fuser Web Cartridge needs changing (this code should reset automatically when a new Web Cartridge is installed).
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Manually
Feb 09, 2010 | Xerox DocuColor 12 Printer
Canon fax erroe code ##342 what is this?
If I recall Its fixing trouble, replace fixing film unit
Jan 13, 2010 | Canon FAX-L250
What are code p0342 and p0431
342 is camshaft position sensor and 431 is your catalytic converter may be getting weak. If this was my car I would do the 342 code and see if the other code for the cat comes back. Tell the shop fix the camshaft sensor. If the sensor is bad your car can still run but its possible you could set a cat code because
of it but on the other hand you cannot set a camshaft code because of a bad cat.
I am a smog tech in California
Aug 10, 2009 | 2005 Chevrolet Aveo
LS 2208. I have to add preffix ^ to Code 39 and suffix @ to
The easiest way to do this would be to write two Advanced Data Formatting rules using the LS2208 Product Reference Guide at this link (I suggest saving a copy then printing the pages from that saved copy)
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=118232754&stateId=0%200%2012083692
You should scan the following barcodes in order:
Send All Data that Remains Adobe page 246 of 342
Send @ Adobe page 272 of 342
Code 39 Adobe page 235 of 342
Send ^ Adobe page 275 of 342
Scanning the barcodes in this order will make the scanner send an @ after every barcode scanned other than Code 39. Code 39 barcodes will get the ^ before the data and an @ after the data.
Aug 02, 2009 | Symbol LS2208
Docucolor 12
como puedo limpiar el area caliente de la maquina ya que no se como desarmarla me pueden ayudar gracias
Mar 05, 2008 | Xerox DocuColor 12 Printer
Canon FAX-B820 Plain Paper Bubblejet Logo
old marine
old marine
