Question about Dell 3010cn Laser Printer
Drum cartridge dell 3010cn - Dell 3010cn Laser Printer
  • 3940 Answers
SOURCE: Dell 3010cn DRUM
The information I have on that error is as follows:
From the Dell TS Guide:
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&cs=04&journalid=4D4C014288160766E040A68F5A283437&l=en&s=bsd&treeid=DCD92482F5548BF9E030A68F27281FC1&Query=ZHJ1bStlcnJvcg==&SystemID=PRN_LSR_3010CN&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=true&dl=
1. Replace the cartridge with a new Dell Branded one
2. If cartridge doesnt resolve, replace the left Intermediate Belt Transfer (IBT) guide assembly.
3. If that doesn't fix, replace the Machine Control Unit (MCU)
Posted on May 16, 2008
Corysf62
  • 188 Answers
SOURCE: Dell 3010cn printing problem
This printer problem is usually fixed by one of the following two solutions.
1) The Cyan cartridge is not seated 100% correctly. If the locking handle is not seated correctly, the printhead is obstructed from properly developing the the black developer at the extream right hand side. When reseated, the light can then see past the handle and place the image properly.
2) The printhead is dirty ( usually toner dust) and needs to be cleaned. To clean the printhead, open the front cover, pull back on the blue handle on the right hand side. This opens the cover to the cleaning wand on the right hand side of the printer. Gently pull the cleaning wand ALL the way out, and then slide back in ALL the way. Do NOT just move the wand back and forth. this will just push the debris around. The wand is designed to move across the printhead in only one direction. When you pull it out to its full extent, it is lifted up so that when you push it back, it is actually above the glass, not on it. When it reaches its full inward position, it drops back down to go over the glass again from left to right.
Make sure that you change this cleaning pad each time you change the imaging unit ( a new pad is included with the new drum).
Important note: If cleaning the printhead works, but then the print fades out again after a short period of usage, a more serious problem exist in which one of the photo developers is leaking. This is not a user replaceable part. The color of the defective developer would correspond to the color of the cleaning pad after cleaning.
Posted on Oct 03, 2008
SOURCE: problem printing with Dell 3010cn Laser
Check for damage to the fuser located right were the paper exits. damaged fuser can cause lines
Posted on Feb 10, 2009
rtrahan
  • 741 Answers
SOURCE: vertical line on copies
A vertical line on laser copiers which are the same lenght apart on each indicates a dirty or defective toner cartridge or dirty or defective rollers. Take the cartridge out and wipe the rollers with a soft cloth. If the streaks continue then the rollers inside the cartridge or damaged. You will need to replace the toner cartridge. Let me know if you have any questions. Please rate this solution with 4 diamonds.
Posted on Mar 29, 2009
  • 70 Answers
SOURCE: reseat drum dell color printer 3010cn
It means that you have to fix the drum,(ie the long cylinder that contains powder in the toner properly)
Posted on Jun 01, 2009
Installed new yelloe cartridge but printer keeps stating to reseat cartridge
009-340 Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ...imaging drum cartridge. Turn the printer off using the power switch on the left side. Wait 10 seconds, turn the printer back on, and check if the error message...sensor solenoid nip. Turn the printer off using the power switch on the left... (English) 016-720 PCL Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ... Press Select ( ) to clear the error on the printer. Reset the printer NVRAM: Press Menu. Press the...and then press Select ( ). When Restart Printer appears, turn the printer off and then back on... (English)
KB Article How Do I Configure and Troubleshoot My Dell Color Laser Network Printer? - KB Article - 296059 ...Troubleshooting Guide for My Dell 3000cn-series / 3100cn Laser Printer ...available online for your Dell 3000cn/3100cn laser printer. The troubleshooting...printing, refer to the Dell Laser Printer 3000cn/3100cn Troubleshooting Guide... (English)
Dec 13, 2010 | Dell 3100cn Laser Printer
How do i replace drum cartridge?
pull open the front cover lift up the top cover lift up the blue handle on the right pull the blue handle in the middle up that is the drum unit steven 818-888-0006
Apr 26, 2010 | Dell 3010cn Laser Printer
Error message says Replace drum cartridge and I'm not sure what that is or what to order
Go to
www.internet-ink.co.uk/dell/dell-toner-cartridges--p4866 This will tell you all about the drum. Then check out other sites where you might find it cheaper.
Apr 12, 2010 | Dell 3010cn Laser Printer
Where is the small memory chip located on the drum cartridge of the dell 3010cn
hELLO THERE :
On the left side there's a board marked "LEFX"
and nearby on the frame is a label with the
FCC ID number. Running that number thru the
FCC database yOU CAN FIND the documents and pictures
submitted by the testing agency.THESE ARE VERY Very informative.
There are two coils -- one on the right end of the
toner cartridge and looks like a ferrite magnet
(but isn't) and the other is on the frame and
aligns with the toner. (there is another set
for the belt/drum unit) These are coils which
are excited by a 125kHz signal and have a chip
in their center. [cue dramatic music] It uses
RFID technology. In fact, the coil in the toner
cartridge is referred to as the "tag".
Jan 14, 2010 | Dell 3010cn Laser Printer
Dell 3010cn printer, says reseat drum contact support. I took drum out and put it back in but don't see anything wrong. It feels secure and I restarted the printer, but no luck.
Hello sir; Pull out the drum cartridge, look around the cartridge you will find a small memory chip, remove it, shoul d take care this problem.
Nov 28, 2009 | Dell 3010cn Laser Printer
Error code 004-321 on dell 3010cn
This error means that your Drum Cartridge belt isn't aligned properly or the sensor for it has become dirty.
Open the top of the printer and look inside. There should be a blue tab on the right side to unlock the drum assembly. Unlock it and lift the assembly straight up to remove it from the printer.
Now, look at the thing you just pulled out -- the drum assembly -- and you should see a black rubber belt. If you turn the wheels that operate it, you'll see that the rubber belt is not centered, so the sensor can't see the little silver plate.
Pull gently on the rubber belt to re-center it, then reinsert the drum cartridge and close up the printer.
Jul 13, 2009 | Dell 3010cn Laser Printer
Vertical line on copies
Mar 29, 2009 | Dell 3010cn Laser Printer
Problem printing with Dell 3010cn Laser
Feb 10, 2009 | Dell 3110cn Laser Printer
Dell 3010cn DRUM
May 15, 2008 | Dell 3010cn Laser Printer
Dell 3010cn Laser Printer Logo
27 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
