Question about Champion 3500/4000 Watt Portable Generator
Wants to run wide open
Linkage set up is wrong
How can I get full throttle out of 1978 115 hp evinrude
That is a wide open question. Has it ever run full throttle or is this a new install? Check linkage for full travel. If OK, could be wrong prop, clogged carb, blown cylinder. 1977 was a bad year for OMC pistons. some 78's could have the same problem.Lots more info needed.
Aug 20, 2015 | Boating
SUBARU EX21 GAS ENGINE RUNS WIDE OPEN WILL NOT IDLE
adjust jet to full close then open quarter turn , check manifold for leaks .sounds like the gasket leaking not tight ,
Apr 08, 2014 | Garden
Runs wide open when started and stays that way
It is the governor linkage not connected up properly
Jul 21, 2013 | Measuring Tools & Sensors
My saturn runs wide open when i go to stop
wow wide open throttle thats strange but its one of two things the throttle body linkage is really stiff and would need to be rebuilt or the cable that runs to the pedal is fraying and is getting stuck. it could be other things but with out more information its hard to diagnos
Apr 04, 2013 | 1999 Saturn SL
It runs wide open all the time im wondering where idler arm setting is at
It sounds like the govenor spring has become disconnected or the clamp on the governor shaft has become loose and allowed the linkage to get out of adjustment. If problem has occurred suddenly it could mean the governor gear assembly inside the engine has broken and means the engine will need to be dismantrel to replace the governor gear assembly.
Check throttle linkage to see if spring is attached at both ends, one end on the throttle linkage and the other at the fixed point on the engine or to the end of the speed control lever. With engine stopped the spring should hold the throttle wide open and hand pressure on the linkage shoud be all that is needed to move throttle shaft closed to the idle position with no binding in the movement of the linkage.
If spring is OK and while engine is running, linkage should be able to be be moved to bring engine back to idle. If porblem has occurred gradually, then linkage will need re-adjusting. Loosen adjusting clamp on governor shaft, then holding linkage in wide open throttle position rotate shaft as far as it will go in the opposite direction to that requred to close throttle to idle . Re-tighten clamp.
Dec 11, 2010 | Coleman Powermate Premium Plus 6250W...
Motor runs wide open when set @ slow speed
It could be that the governor spring has become disconnected or has broken on an end where it hooks onto the throttle linkage. If the spring is OK & throttle linkage is not binding it could mean the governor drive inside the engine has failed preventing the governor from operating correctly. You may need to take the engine to a mechanic to fix the problem.
Sep 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Sears Craftsman mower-Tecumseh engine 3.75 HP- wouldn't start-replaced air filter & spark plug; dismantled carburetor and cleaned it; now it will start but only runs for a couple of seconds and dies....
check the linkage for the governor, maybe on the wrong side,when off it should be pushing the throttle wide open, the governor brings it down after start up!
Jul 06, 2010 | Craftsman Garden
Starting problem
I had the same problem and what I did fixed mine. I got it running with the starter fluid then pushed the linkage (Rod) on top of the carb and ran the engine wide open (by pushing the linkage), then released... then wide open again. I did this 4 or 5 times. Then to my suprise something clicked in the carb and it began to run normal. I have alot of experience with car engines, but not small engines therefore this had me baffled. I feel I got lucky in the repair, because something within the carb was stuck. You can not just run it wide open using the throttle...you have to push the linkage (I guess it bypasses something). Hey it worked for me. I wish you good luck and let me know if I can help in any way.
Apr 01, 2010 | Karcher G3025OH Pressure Washer
2001 mercedes c240 has a really rough start but when the car almost dies I turn the car off wait 3 seconds and it starts perfect. Next comes the issue with having to warm it up before driving anywhere...
Gasoline- thank you. Warm up is not an issue like diesel is. Sounds like the choke is is either wide open or over choking. With the engine cold, remove the air cleaner and note where the plate is at the opening of the carb. If it is wide open then without touching anything else and engine not running, step down on the gas pedal and see if the choke plate reset itself to restricter the carb inlet. If it didn't, then take some WD 40 and spray the linkages and the rod ends holdin the choke plate.By hand work the plate and linkage holding the gas open at the carb. Then set the plate to wide open and do the gas pedal thing agan to see if choke sets itself back to restricting the carb intake. If it does, start the engine and as the engine warms upm the choke plate should start opening on its own and you are off and running. Roitine question. Is your air cleaner clean? If the choke plate needs adjusting. get back to me. K? Good luck Remember to press the gas pedal down once before cranking. That sets the choke for cold start. Hope this helped you Good luck Note, the WD40 won't hurt anything but avoid spraying with engine running or when engine is hot..
May 12, 2009 | 2001 Mercedes-Benz C-Class
1983 buick regal
check the detent cable(kickdown) that runs from your transmission to your carb linkage. you'll need to "set" it by pressing the "D" shaped button n the bracket and pull the sheath back towards the bracket. turn your carb linkage to wide open throttle 1 time and your set. hope this helps....
Aug 07, 2008 | 1983 Buick Regal
Champion 3500/4000 Watt Portable Generator Logo
Top Champion Televison & Video Experts
bobalix
Joseph Hoffmann
Are you a Champion Televison and Video Expert? Answer questions, earn points and help others
