Question about Cybex 750T Legacy Commercial Treadmill
Tv won't work-weak or no signal - Cybex 750T Legacy Commercial Treadmill
    Problem Solver:
  • 50 Answers
First check all of the connections, then check to see that it is in cable mode. If your machine is under a year old call cybex for a new TV. If not remove back of TV and check connections to coax port. If you have to order a new TV I would just go out and buy a regular TV and mount to wall as the TVs for this tread cost around $1000
Posted on Jul 30, 2014
I bought a new Samsung LED 40" Series 5 TV. However, after connecting to the tv cable line, i get message " weak or no signal" and not able to get any tv signals. What could be the problem?
You usually hear "weak or no signal" when the tv's input is set to air. Check to see if changing the input might help. Or if you are using an antenna to get your tv, then maybe your antenna is not powerful enough. The new digital signal is weaker than the analog, so antennas that once worked might not work as well now. Hope this helps!
Apr 06, 2011 | Samsung LE32R41BD 32 in. HD-Ready LCD...
TV comes on but will not recieve channel. It displays no signal & the code65535. The cable is working here so it is in the TV. It is a 37" dynex flat screen bought 2 yrs plus 4 months.
Hello
Try the resetting the TV. To do this unplug the power chord from power socket, and wait for atleast 45 minute. TV will reset itself. The try to get signals.
If your TV receive poor quality telivision signals, captioning may contain errors, or there might be no captioning at all. Some possible reasons for poor quality are automobile ignition noise, electic motor noise, weak signal reception or multiplex signal reception like ghosts etc.
If reset also didn't help you, the tuner inside your TV is defective, or weak. It should be replaced with same type and number. OK.
Mar 27, 2011 | Dynex DX-LCD37 TV
Missing or weak signal
try a outdoor antenna on the roof for digital signal use.also the main digital PCB is defective which has the tuner on it if the antenna does not work.you may try taking the
tv to a friends house and see if the tv works better.
Sep 04, 2009 | JVC LT37X787 37 in. HDTV LCD Television
I am getting a (weak or no signal)
Hello glc_11489,
Have you tried to use an amplified antenna? I have found that this works very well.
Thank you,
Shuttle83,
http://www.electron-age-technologies-llc.com
Jun 12, 2009 | Philips Magnavox 20MT133S 20" TV
Digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Apr 01, 2009 | Samsung LE40R74BDX 40 in. LCD Television
My 30 philips tv is flashing weak signal
my philips tv is saying weak signal what do i do
Mar 16, 2009 | Philips Televison & Video
Weak or no Signal issue when connected to my TV.
Yes weak signal. Also closing the laptop lid puts the computer in sleep mode.
Jul 07, 2017 | Digital Lifestyle FA1B32Z 32 in. LCD...
The screen shows ''Weak Signal'' and no picture, even though audio is coming through from both the Cable DVR box and Blue-Ray player. The cable box connects to the TV with an HMI cable - all five TV inputs...
Mine did the same thing once. I think all I did was hit the setup on the remote, and let it run back through all the channels and then it worked just fine.
I hope this works for you.
Dec 29, 2008 | JVC LT42P789 42 in. LCD TV
Weak or no signal message
  1. Since my problem (Samsung/Comcast) began with a channel selection button pushed on the TV remote when it should have been pushed on the cable remote, I figured the problem lay with the TV.  Although I was getting the "weak or no signal" msg., the actual signal strength bar graphic showed it to be strong. Disconnecting did no good. I surmised that the TV was simply not recognizing the box.
  2. I looked at the manual for my Samsung 750 model.
  3. Page 20 discussed "Selecting the source". I accessed the TV menu and selected "Input", then chose the "HD..." item from the highlighted list. Voila! My tv works again.
Jun 08, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Actually it a lnt5271f, but...
there is a differnece between other TV's in the house working and the TV at that specific location working. Check the cable splitters which go into that room and tighten the cables at all ends..loose/broken cables cables can result in weak signals. It might be a bad splitter too.
Jan 12, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Cybex 750T Legacy Commercial Treadmill Logo
85 people viewed this question
Top Cybex Exercise & Fitness Experts
ray gallant
Electro Med Services...
Techmotionusa.com
Techmotionusa.com
Are you a Cybex Exercise and Fitnes Expert? Answer questions, earn points and help others
