Question about Whirlpool WFW9151YW Duet 3.5 cu. ft. Front Load Washer With
Whirlpool Duet 3.5-cu ft High-Efficiency Front-Load Washer wont drain, door is locked
It makes a strange noise until I unplug it. The door is locked. I cannot change settings to drain the water.
SOURCE: Duet washer door locked
Pull the front panel off, look for a plastic piece , it has a filter that you need to pull out. turn it to the left pull it out and clean it. This solved the problem for me. had the same issues.
Posted on Apr 18, 2008
  • 1294 Answers
SOURCE: Whirlpool Duet Error code F 32
Plug off the wall. Open up behind, you will see a thin tube coming down from the control panel (pressure switch to be precise) to the waste area below. Disconnect this carefully from the top, blow into it, air should pass thru, it shd not be clogged; refit carefully. Before refitting, fit a similar tube to the pressure switch & blow - you should hear a click; if not there shd be a problem with your pressure switch. Anyway refit your old tube & try the machine.
Dont forget to refit the main exit hose at the position you found it. All you guys are going to rate me....................
Posted on Jun 16, 2008
  • 212 Answers
SOURCE: whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
Posted on Jun 22, 2009
  • 662 Answers
SOURCE: it wont spin nor will it drain
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Pl rate me nice for the free help, thanks
Posted on Jun 04, 2010
  • 17 Answers
SOURCE: What is the cu. ft of my Whirlpool duet washing ma...
3.7 CUFT
Posted on Aug 11, 2010
How do i get door to unlock?
Unplug the washer, wait for 15 seconds or so, plug back in and hit power button the cancel. this should unlock the door as it should reset. Do you have any fault code on your display? Is there a dryer stacked on the unit? Good Luck
Apr 17, 2016 | Whirlpool WFW72HEDW WFW72HEDW 4.2 Cu. Ft....
Door won't open on front load washer
How to Unlock a Whirlpool Duet Washing Machine ' Home ...
homeguides.sfgate.com > Mortgages > Mortgage Options
If you must manually unlock the washer door after each wash cycle your drain ... to Change a Water Inlet Valve for a Whirlpool Duet Front-Loading Washing Machine ...Causes and Repair for a Whirlpool Washing Machine That Won't Spin or ...
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique ..... Front Load Washer Repair - Not Draining or Spinning - How to Unclog ... Washing Machine Repair - Replacing the Door Bellow (Whirlpool Part
Nov 05, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
Why will the washing machine door not unlock?
Sounds like you have a broken door lock, or a wire harness is loose or disconnected. Also make sure the door seal is not out of place.
May 01, 2014 | Whirlpool Duet Steam 4.1 Cu. Ft. Front...
Front load duet washer wont start because the door cant lock and we cant open the door.
You need to replace the door lock/switch. It is quite an easy job but is a tight fit behind the front so a bit tricky to get the old one out and the new one in.
Mar 06, 2012 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Fornt load door wont unlock, Washer wont run
First unplug the machine, then to unlock the door manually you need to remove the panel under the door (three screws at bottom of machine) then reach inside by the door lock, there will be a plastic tab hanging down. Pull that tab down and the door should unlock. As for not running, when you plug the machine back in you should get an error code and knowing what that error code is will help in troubleshooting the No Run problem. Good luck.
Feb 23, 2011 | Whirlpool Duet 3.8 cu. ft. Front Load...
Control locked light come on and stay on, machine not running
take a good look and read on your control panel i don't remember which button you need to hold for 3 or 5 second to lock unlock control panel. it is also called child lock system.
May 21, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool washer
hi there,
if you can supply me with the full model #, i will send you the exploded view diagram to make this easier.
Oct 11, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool WFW9151YW Duet 3.5 cu. ft. Front Load Washer With Logo
22 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
