Question about Magic Chef Refrigerators
Magic chef rb191t is freezing everything in fridge & freezer seal is leaking
How old is this model.
  • 2920 Answers
SOURCE: Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
Posted on Aug 27, 2008
SOURCE: magic chef gas/electric rv fridge
Mod. R47 gas RV fridge 1973. It lights and gets cold (sometimes below freezing in the bottom of frige) then it starts to warm up above 55, but the flame is still burning high. I try to turn it down with the fridge thremostate and it stays the same. Is it the thermostate? If so where can I order one?
Jerry toolster@cableone.net
Posted on Jan 09, 2009
SOURCE: MIni fridge stopped working/cool.
I got mine in 2005. It stopped working 4 or 5 weeks ago. It made a clicking noise and the compressor was very hot. Compressor is under warranty but appliance repair shop wanted $125 to install it and another $75 to charge it with freon. I saw a posting somewhere else that said it was a relay switch. I ordered one from RepairClinic.com for $24.00 incl. shipping, put it in and it's working now. There's a black plastic housing on the left side of the compressor. Just unscrew that, pop the cover off (that was a little tricky) and plug in the new part. Maybe I'll get another 3 years out of it.
Posted on Aug 04, 2009
  • 55 Answers
SOURCE: I have a Magic Chef model MCBR1010W fridge/freeze
check thermo switch
Posted on Aug 05, 2009
heatman101
  • 43501 Answers
SOURCE: i awoke this morning to
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 27, 2011
What could be the problem with my Magic Chef mini fridge model number MCBR465S. It comes on when I plug it in but not cool at all, and the compressor hot, could I trouble shoot and how,freon? Thx
If the compressor is actually running and there is no refrigeration, I would suggest it has a gas leak and that's why it isn't cooling. Depending on what type of refrigerant is in it, it may not be worth repairing as its only a small bar fridge? Check the rating plate to see if its R12 (Older fridges) or R134A . If the unit is less than 5 years old, it may be operating on R32 or R600 (Butane refrigerant gases) If its only a couple of years old, it may still be under Manufacturer warranty. Most fridges carry a 2 year warranty on everything and up to 5 years parts warranty on what is known as the "Sealed system"
Apr 19, 2015 | Magic Chef Refrigerators
My magic chef rb193p fridge wont stop running. I replaced the fan motor 4 months ago. The top of the fridge compartment is freezing. Is the defrost timer bad?
I had the same problem. When the evaporator heater stops working, frost will build up until there is no air flow to the refrigerator. This will cause the refrigerator to keep running. Remove everything from the freezer and remove the pan at the bottom and see if there is a frost buildup. .... Bruce
Jun 18, 2011 | Magic Chef CTB1922 Top Freezer...
I have a Magic Chef refrigator and it freezes up
A bad defrost timer located on the right rear.
A bad defrost heater located in the freezer under the freezer floor panel.
Jul 07, 2010 | Magic Chef CTF1826AR Top Freezer...
My Magic Chef mini fridge temperature trouble
That can be very difficult to do with a mini refrigerator. There is just not enough separation between the freezer and the refrigerator.
You will likely just have to find a compromise setting and accept the results.
Oct 20, 2009 | Refrigerators
Freezer not Freezing
the air flow is blocked betwen fridge and frezer or even the small fan is burnt out
Jun 22, 2009 | Magic Chef CTF2125 Top Freezer...
Fridge keeps on freezing everything inside of it
This refrigerator only has one thermostat located in the fresh food compartment it is designed to activate the sealed system (cooling) until it reaches approximately 37 deg f in the fresh food compartment. The damper controls how fast the cold air can move from the freezer compartment to the fresh food compartment. Allowing you to control the temp in the freezer by controlling the flow of cold air to the thermostat.
You have one of two problems.
#1 your thermostat is no longer opening when it achieves set temp. fix = replace thermostat pn 61005798 $35
#2 your damper arm or assemblie has broken. Fix = Replace damper or broken arm and actuator.
damper assembly pn12001377 $44
damper actuator pn 61002000 $2
damper arm pn 61001999 $2
thermostat actuator arm damper arm
damper assembly both pics
Apr 06, 2009 | Refrigerators
Fridge is not cooling or freezing
can you tell me the model # on the fridge please? the motor is running continuously because it's trying to cool the fridge. it may be a few things, the defrost thermostat, the fan motor itself or the compressor.
Sep 13, 2008 | Magic Chef Refrigerators
Refrigerators Logo
47 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
