Question about Dacor ECD230 Epicure Electric Double Oven
After house lightening strike - LCD shows "33"; only oven lights
DACOR ECD230SBK - dual (over/under) ovens
house was hit by lightening
after power up, LCD shows "33"
only oven lights are functional
presume it's the main control board
Part number? Dealer?
Call your home owner insurance agent
Posted on Jun 18, 2009
How can I get my oven temperature to come on? A power outage caused the "lock" light to flash and no temp is appearing.
Are you sure that you have 220 volts to the oven. It is possible for a breaker to go bad and conduct power only on one leg and some things on the appliance will still work.
Electronic controls on ovens can be damaged by power surges caused by lightening strikes. That could be the problem but after looking at the circuit diagram of the panel it doesn't look like there are electronics that should be damaged by a surge.
Here is a link to the user manual.
Download Manual Pdf
Link to Maytag Same as Whirlpool
Search Results for Appliance Models matching CWE4800A
Good Luck.
Sep 20, 2014 | Maytag CWE4800A Electric Single Oven
F-1 showing on digital window of dacor dual fuel range with oven alarm beeping. Unit is turned off.
Your temperature censor may need to be replace. try geting the fault code diagram from the manufactor brand.
Nov 14, 2013 | Dacor Ovens
A code appears on my Dacor oven/stove that reads FO, what does it mean?
Hi bevtrust,
The error code that appears on your Dacor oven is about a stuck function key which refers to F0 error code. To fix this problem, you need to replace the oven's touch pad. If the touch pad is part of the clock, you need to replace the clock or ERC.
Hope it helps.
Thank you for using FixYa.
Nov 16, 2010 | Dacor Epicure EO127 Stainless Steel Dual...
Our Dacor Millennia wall oven will not heat
There is a manual reset button behind the vent under the touch pad. Turn off the power. Open the door. Remove the vent. Behind the latch is a two wire switch. press the red button on it until it clicks. reassemble and turn on power. It over heated when the power went off by stopping the cooling fan.
Mar 04, 2009 | Dacor MCS130SS Millennia Electric Single...
Dacor ECPS130 fan won't shut off
Hi, Dacor has a Technical Manual that may help you with your problem. It has a ECS wall mount oven but does not list a ECPS. Is your listing of the model correct? Here is a link to download the Technical Manual. https://www.scribd.com/doc/14008662/Dacor-Technical-Manual
Hope it helps.
Mar 20, 2017 | Dacor PCS130 Preference Electric Single...
Display 11
your control must be fried...dacor fault codes are f0 to F8 the display must be faulty..
Aug 25, 2007 | Dacor ECD230 Epicure Electric Double Oven
Dacor Oven Won;t Heat
power surges can short out the electonics in appliances. If you can locate where the tech sheet is and I would say its behind the control panel on top, look at the wiring diagram and see if there are any replaceable fuse's. Or a resetable fuse for the heating element. If not check to see if power is getting to the main control bord. If there is power there you may need to replace the control.
Jul 19, 2007 | Dacor ECS130 Epicure Electric Single Oven
Dacor ECD230 Epicure Electric Double Oven Logo
221 people viewed this question
Top Dacor Ovens Experts
Vitaliy Gins
Vitaliy Gins
Oloyede Monsuru
Jose Pino
Are you a Dacor Oven Expert? Answer questions, earn points and help others
