Question about Whirlpool LER4634J Electric Dryer
Whirpool dryer stopped working
Dryer just stopped working, dried one load then would not work.. breaker not tripped, what would stop it from not working? what part could it be that needs replaced?
  • 6,784 Answers
Check the following to combat this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
Posted on Jun 18, 2009
Dryer stops running and displays E1
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
redarrow.gif Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
Aug 11, 2008 | Whirlpool GEW9200L Electric Dryer
My Whirpool dryer stopped working after I just finished a load and tried to start the next one. The power source is working and the vent is not clogged. Where do I locate the belt?
If it's not working at all, the first thing to check is power. You should have a dipole 30 amp breaker and you have to make sure that both legs are hot going to the machine. Remember that it's possible for the breaker to appear to be okay but one leg has tripped. Inside the unit you need to be able to check for continuity on the thermal fuse(s) and across the heating element. The door switch could have failed as well, which would not allow it to tumble or heat.
Dec 02, 2010 | Whirlpool Dryers
Maytag neptune dryer model mde3000ayw
you want to start at high limit thermostat or thermal fuse
its white and has two small wires
it sits on the heat tube
it could be black too
it is shaped like a warped ball
and is rather flat
sears has them in stock
ive included the part number to help
307473
Oct 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer was working the just stopped and won't start back
check your main breaker box first, see if it tripped, if the breaker looks okay then turn off the breaker for the dryer and reset the breaker switch, if this still doesn't work then a fuse has popped on the circuit board.
Sep 13, 2009 | Amana NED5400TQ Electric Dryer
My dryer stopped working
First, make sure that the house breaker is not tripped for the circuit the dryer is on. If the breaker is not tripped, then I would suspect a faulty thermal fuse. The thermal fuse is about one inch long and is located in the rear of the dryer and is usually attached to the exhaust duct. It can be tested for continuity using a multimeter. A lack of continuity indicates a blown fuse. Hope this helped and best wishes.
Aug 05, 2009 | Dryers
Dryer won't start
Dryer does not work at all
Hope this may help;
DON'T FORGET TO RATE:
Aug 22, 2008 | Roper REX4634KQ Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
336 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
