Question about Haier HWR06XC9 Air Conditioner
Haier HWR06XC9 fan not working
The unit turns on, but the fan isn't spinning. So it turns of and back on again. But the fan is still not working
2 Suggested Answers
louislevel_2
  • 374 Answers
SOURCE: ++HAIER 3125. Fan shuts off.
hi! there it seems that your control circuit board is activating default set up or abnormal set up after recieving on control circuit board when you shut off the unit, there's a short circuit behind on holding relay when deactivation process is done, the holding relay should be cutting your entire source connection on compressor terminal when you shut off the unit, in this case try to isolate checking supply voltage behind relay and the supply source terminal of your relay, .try to check on this to your manual circuit diagram to lessen the complication of trouble shooting just focus on relay circiut,replace relay if defective.this is a hard job and should be done by qualified a/c technician. have a nice day regard and thank's a lot
Posted on Mar 30, 2009
Haier HWR06XC9 fan stopped working
Either the fan motor
the fan control relay
or the fan control relay switching transistor
the unit is re starting because the gas is not getting cooled
If competent check for voltage at the fan and work you way back
Apr 14, 2014 | Haier HWR06XC9 Air Conditioner
I have Haier refrigerator moderl number HTQ21JAARSS the Freezer is freezing and the refrigerator is not cooling .
Thank you for contacting fixya.com.
Check the coils on the rear of the refrigerator and make sure they are clean and dust free. Also check the back wall or floor of the freezer section for frost. Check the evaporator fan to see if it is running. Check the condenser coils under the unit for blockage from dust. Check the condenser fan under the unit to see if it is running. If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. Also check the freezer to ensure it isn't over loaded with food stuff, reason being air must flow freely threw out the entire refrigerator in order for the thermostat to work correctly.
Defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with both the doors open to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
Please get back to us if you have further query else please accept the suggestion.
Jun 01, 2011 | Haier HTQ21JAAWW Top Freezer Refrigerator
The unit is freezing up and leaking alot of water
Hello, first thing is check the condition of the filter on the front of the unit, if it is dirty wash it and let it dry then reinstall it. Also, it is a good idea to clean the evaporator coil with a can of coil cleaner that you can pick up at any heating and cooling store. Just spray cleaner on evaporator coil and let it dry. If this does not solve the problem tjen the unit might be undercharged and will need a hvac tech to recharge it
May 04, 2011 | Haier HWR06XC9 Air Conditioner
Top fan is not working
The HVTS18DABB wine chiller is truely a piece of **** when it comes to their fans. I have had top fans in the top chiller fail. Solution: Don't buy the replacement part as it will only fail again. Instead, go to your local computer parts store and purchase a high quality 120mm computer fan with a good motor and bearings. On the old fan, snip the wire harness as close as possible to the fan body. On the new fan, remove the connectors that come on the fan. Attach the red wires and the black wire and wrap each with electrical tape. Trim back the yellow wire and tape the end, isn't needed. Remount the fan and you are good to go. i plan on replacing the bottom fan soon with a quality PC fan as well.
Feb 19, 2011 | Haier HVTS18DABB Wine Cooler
Won't "kick" on
need a little clarification but will try to answer....if the fan is not spinning or no air is coming out, then try taking off the front cover and spinning the fan by hand (With unit unplugged). it should spin freely and not feel rough or stop suddenly. if so the fan motor is bad. now if the fan motor works but the air does not cool then the compressor is not turning on in which case either 1. you are too low on freon (leak), 2. the compressor has gone bad, or 3. there is a wiring problem or bad run capacitor. i find it odd that this would happen to 2 units over the same storage period, any out-of-the ordinary environmental situations there? water damage? it could simply be a wiring short also.
Jun 09, 2009 | Haier ESA306 Air Conditioner
Haier Dual Zone Wine Chiller - One Fan wont run
I have the same problem. When I first discovered this, both fans had stopped working and the temp for both zones was over 80. So much for the wine that had been stored there. After leaving the unit unplugged for a few days, the fan for the lower section started working again but the upper fan is still overheating. Haier customer service says too bad, so sad (I discovered this problem in the 13th month of ownership). I'm sure it is not worthwhile to fix this so it is going out with the trash and I'll look for a different brand for the next wine cellar that I purchase. Any ideas?
Mar 01, 2009 | Refrigerators
My Haier 12 wine bottle cooler is dead. No fan or cooling .
Check the 2 fuses,one covered with black heat shrink, next see if internal fan is spinning, inside door, the 2 fans on the back should spin when first plugged in. also the 2 led's red and green should light up...if internal fan doesn't spin then check or replace, use batteries to get it to spin as a test...good luck,safety first...
Nov 15, 2008 | Haier HVT12ABS Compact Wine Cooler
Haier XQG50-11 spin and dryer do not work
Same thing happened to my unit. It turned out to be the no spin switch which I never used anyway.
The switch had gone bad even though it was never used it. It was broken in the no spin state. The connectors on mine were a bit chared looking.
Take the top cover off the unit and remove the two wires from the no spin switch. Place a jumper between these two wires bypassing the switch or replace the switch.
In the no spin cycle the unit will not spin or dry.
I bypassed my switch and the unit runs perfect again.
Mar 15, 2008 | Washing Machines
Haier HWR06XC9 Air Conditioner Logo
14 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
