Question about Brother DCP-8065DN Black and White Copier
Dcp8065dn how to enter maintenance mode - Brother DCP-8065DN Black and White Copier
Brother DC8060 how to reset fuser life
ENTRY INTO THE MAINTENANCE MODE
Press the [Menu] and [Start] keys. Next press the [/\] key four times to make the machine enter the maintenance mode.
FAX models equipped with numerical keypads can enter the maintenance mode by pressing the [Menu], [*], [2], [8], [6] and [4] keys in this sequence.
The machine beeps for approx. one second and displays MAINTENANCE " on the LCD,
indicating that it is placed in the initial stage of the maintenance mode, a mode in which the machine is ready to accept entry from the keys.
To select one of the maintenance-mode functions press the [/\ ] key or [\/ ] key to display any function code on the LCD. Then press the [OK] key 88 Counter Reset After Replacing the Fuser Unit, Laser Unit and
Paper Feed Kit
Jul 21, 2014 | Brother MFC Office Equipment & Supplies
HOW REMOVE IT FROM THIS Defective power supply ERROR
Reset C6400 ERROR
turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Select Service setting using
the up/down cursor keys.
While pressing the start key and the # key,
press the enter key..........Maintenance mode is entered.
Select Maintenance mode using
Press the enter key.
Enter the maintenance item
number U163 using the up/down keys.
Select Execute using the up/down cursor keys.
Press the enter key. The fusing problem data is initialized.
Apr 15, 2014 | Kyocera FS-1118MFP Laser Printer
Resettare errore c6
1-4-1 Maintenance mode
The machine is equipped with a maintenance function which can be used to maintain and service the machine.
(1) Executing a maintenance item
The selected maintenance item is run.
Press the back key.
Start
End
The maintenance item is
selected.
Maintenance mode is exited.
Repeat the same
maintenance item?
Run another maintenance
item?
Turning power switch off and back on
No
No
Yes
Yes
number using the up/down keys.
Press the system menu/counter key.
* The test print mode cannot be stopped until the preset number of sheets is printed. To stop the operation, remove the
cassette to cause a paper empty state. To terminate the test print mode in the middle of operation, you must turn off the
power switch and then on again to exit the maintenanc
when in maintenance mode go to 163 to reset
Mar 16, 2014 | Kyocera FS-1118 Printer
How to enter into service mode ricoh 8300dn
Ricoh SP8300 SP mode (Service Mode)
To Enter SP Mode (Service Mode)
Do one of the following:
If the power is already ON, press the "Home" and
"Simple screen" keys at the same time for more
than 3 seconds, and then press the "User tool"
key.
or
If the printer is OFF Press the "Home" and "Suspend" keys at the
same time while turning the main switch on.
Reset for Maintenance Kit A or Maintenance Kit B
So the "Replace Maintenance Kit A" or Replace Maintenance B" message will go away.
Once in SP Mode (Service Mode) press the following:
"ENGINE"
"SP-7XXX" - "DATA LOG"
"7804" - "PM Counter Reset"
"6" - "ALL CLEAR"
"EXECUTE"
Jan 13, 2014 | Office Equipment & Supplies
Unable to print 32 printer brother mfc 9490cw
Unable to.....
Resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine
Sep 15, 2011 | Brother MFC 6490CW InkJet Printer
My Garmin will not power up. We have hooked it up to the usb cable to our computer and it still does not come on
try entering maintenance mode~~
In order to reset Garmin device or enter into maintenance mode, perform one of the following procedures:
Power off Garmin unit. Press on continuously the upper top left corner of screen and then power on the unit by pressing once on the Power button. You should be prompted to clear all user data, or asked if do you really want to start up in maintenance mode. Press "Yes" to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Hack above works on Garmin Nuvi 660, 680 series.
Turn off Garmin device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press "Yes" to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
~~ http://www.mydigitallife.info/2009/06/09/how-to-reset-garmin-nuvi-gps-device-access-maintenance-mode/
Mar 07, 2011 | Garmin GPS
C6400
C6400 is a fixing unit error. You may need a new fixing unit but most of the time it can be reset in maintenance mode.
Use the following steps to enter the maintence mode, once there follow the steps for maintence mode 163 (reset fuser error). Do not do anything else in the maintenance mode area because you could damage your machine.
Select Service setting using the up/down cursor keys.
While pressing the start key and the # key, press the enter key.
Select Maintenance mode using the up/down cursor keys.
Enter the maintenance item number (163) using the up/down keys.
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020, C6050, and C6400 are reset.)
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
Resetting the fusing problem data
Description
Resets the detection of a service call code indicating a problem in the fusing section.
When a service call concerning the fusing section occurs, turn the power switch off and open the front cover.
Purpose
To prevent accidents due to an abnormally high fusing temperature.
Method
Completion
Turning power switch off and back on.
I hope this is helpful,
Shawn
Feb 15, 2011 | Kyocera Copystar CS-1820 Black and White...
Display the Call service C6400 code
Completion
Description
Purpose
Method
Completion
Shawn
Dec 22, 2010 | Kyocera Copystar CS-1820 Black and White...
Switches to "Quick Start" before I enter all information
The Maintenance Mode allows you to query and modify the basic settings of the Star Trac Pro
Stepper.
Engaging Maintenance Mode
Press and hold the0 , 2and OK keys together.
A beep will sound and the “MAINTENANCE MODE” will display momentarily in the information
window.
Release all keys. “SERIAL NO XXXXX” will display in the information window.
Modifying the Maintenance Mode
The following keys are used to modify Maintenance Settings:
Upper and Lower Data Information Window SCROLL keys: Display the next and
previous settings.
Increase and Decrease Level Keys: Adjust the value of the displayed
setting up and down respectively, in increments of 1 unit.
OK Key: Updates (saves) the value of the display setting in the Flash memory, and exits
Maintenance Mode.
The Keypad Test can be used to verify that all keys are functioning on the display assembly.
To engage the Keypad Test
Enter the Maintenance Mode (see Settings – Maintenance Mode).
Press until Keypad Test is displayed in the information window.
Press to enter the Keypad Test.
Press each key on the display. Each time you press a key, the information window will display
which key has been pressed.
To exit the keypad test, press .
If any of the keys do not respond, they may not be functioning and the display keypad must be
replaced.
Jan 23, 2010 | Startrac Fitness Products Sc4130 Star Trac...
Have a brother DCP- 115C and had a paper jam, I removed the paper from the printer cleared the jam and now printer is telling me Unable to clean see Trouble shooting and routine maintenance in users...
The proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
(for printers with numeric keypad):
Resetting purge counter on: MFC-620CN / MFC-420CN / MFC-410CN / MFC-210C and FAX-2440C:
1. Enter machine maintenance mode (on MFC-210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode.
2. Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3. Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4. Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5. Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6. Press the 9 key twice to return to the standby state.
Dec 11, 2009 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP-8065DN Black and White Copier Logo
48 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
