Question about Brother Office Equipment & Supplies
Drum Near End
This is what the printer screen says - Does this require a new drum - someone to come fix it - or just what? thanks -
    President:
  • 3,278 Answers
The message is referring to a replaceable part. You should be able to order the part and install it yourself. Good luck.
Posted on Jun 18, 2009
  • NinaE Jul 02, 2009
    Was this helpful ??? Resolve your problem ?? Thanks.
How to fix brother printer drum error troubleshooting and routine maintenance
I still receive the error message "Replace Drum", "Drum End Soon", "Drum Near End", or "Drum Stop" after I replace the drum unit with a new one. The following error messages will continue to appear if the drum counter was not reset when you replace the drum unit with a new one.
  • Replace Drum
  • Drum End Soon
  • Drum Near End
  • Drum Stop
To clear these error messages, you need to reset the drum counter as instructed below.
If you want to clear an error message related to the toner replacement, click here to see how to clear an error message after you replaced the toner cartridge.
"What is the difference between the toner cartridge and the drum unit?"
Please reset the drum counter only when you replace the drum unit. If you reset the drum counter during the life of the drum unit currently being used, the remaining drum life will not be displayed accurately.
  1. Make sure that the machine is turned on.
  2. Open the front cover.
  3. Press Clear or Clear/Back on the control panel.?
    NOTE: The layout of a control panel differs depending on the model, but the Clear or Clear/Back button is located on the right side of the LCD screen as shown in illustration.
  4. Do one of the following.
    • If your Brother machine has a numeric keypad:
      Press 1 to reset the drum counter.
    • If your Brother machine doesn't have a numeric keypad:
      Press the Up Arrow Key to reset the drum counter.
  5. When the LCD shows Accepted, close the front cover.
Sep 11, 2017 | Brother Office Equipment & Supplies
did you do the reset procedure? if not it's in your owners manual under the section "replacing the consumables".
hth,
razors
Nov 29, 2011 | Brother HL 5250DN Laser Printer
Says toner life end and it's not ended. thanks. I also never reset drum button when got new drum how do i do that as well? thank you :)
hello
hen the toner almost end it will give you notice toner near end and you have to replace the toner and there is small button to be slide to clean the drum and also sometimes even if your replace new toner it will still appear the toner near end you have to shutdown the printer remove the powr at th wall and also at the back of the printer and wait for some time and plug it back and turn on.
thanks
Apr 14, 2011 | Brother DCP-8065DN Black and White Copier
Brother 4040CN
This message will appear if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one
May 21, 2010 | Brother HL-4040CN Laser Printer
What is the Drum?
The drum is a selenium coated sort of roller that has the image of your copy document tranfered onto it. As it rotates this image is tranfered to your new copy paper. It then is demagnetised and the toner returns to the toner catcher. The drum coating has a finite life and the mesaage is telling you that its life is near its end and a new drum or new machine will be required soon.
Mar 22, 2010 | Brother MFC-9440CN Laser Printer
We have a brother DCP8060 printer. It has been
There should have been a paper with the new drum to tell you how, but you open the front door and press either menu or options button and it will ask if it's a new drum. Press 1 for yes, and the drum is reset to new...
Oct 20, 2009 | Office Equipment & Supplies
Screen says drum near end
Drum for Brother MFC-6800 All in One Machine
You can expect it to print 12,000 Page Yield
Whats the difference between a DRUM and a TONER Cartridge? The toner cartridge is a cartridge holding the toner (ink). The drum does the work to transfer the ink to the paper. You will need to replace the drum every 5-6 toner cartridges you use.
Sep 24, 2009 | Brother MFC 240C All-In-One InkJet Printer
Drum near end
Open the front cover and then press CLEAR/BACK Press 1 to reset
May 11, 2009 | Brother MFC-8440 All-In-One Laser Printer
"drum near end". What is this? is it easy to fix? how do you fix?
There are two main parts in a laser printer: the toner cartridge and the image drum. Most people are familiar with the toner cartridge, but sometimes the drum is an unknown until you start seeing error messages or streaks and blotches begin appearing on the output.
In some printers, the drum is replaced along with the toner cartridge. But yours has a separate drum, and the printer is warning you it's nearing the end of its life. Replacements are available from a number of sources online, as well as at big-box office supply stores. Genuine Brother drum units will cost over $100, and after-market brands usually range from $50 to $75.
A typical vendor and price is here (I've never purchased from this place myself, and have just used it as an example):
http://www.quikshiptoner.com/catalog/brother-dcp-8060-drum-toner.html
Please take a moment to rate this solution if you've found it helpful, and thanks for asking here!
Mar 04, 2009 | Brother DCP-8060 All-In-One Laser Printer
Replaced new drum unit but LCD keeps saying Drum Near End of Life
Front cover must be open
Press The "Clear" key on the top panel
Close the over
Jul 12, 2008 | Brother MFC-8460N All-In-One Printer
190 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
