Question about Mag Innovision 19" LCD Flat-Panel Monitor LT916S
I have a mag lt 2219 and everytine I turn it on it goes black
I have a mag lt 2219 and everytine I turn it on it works for a couple seconds then goes black.
  • 1,684 Answers
I have a mag lt 2219 and everytine I turn it on it - moz-screenshot.jpgHello Chris,
You have a monitor with a common problem. After a few years some LCD monitors will blown a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, iff so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Posted on Jun 19, 2009
My toaster showing f5 mag temp and it only toast for 6 seconds then stops any ideas???
assuming its been fixed by now.
thermal-couples on mags trigger at 160F i believe.. forces shutdown for safety.
possible causes..several
mag fan working?
EC fan working?
mag cooling fins packed with dust?
wave guides full of crud causing arching?
mag tip burnt?
faulty mag thermal-couple, unlikely
Nov 07, 2012 | TurboChef TORNADO Electric Oven
I have a Mag Innovisin monitor that I use with my laptop so I have a bigger screen. It will turn on but after 1 second the screen goes black. Any ideas what's causing this and if it can be fixed?
eadaniels, Could be <$10 on DIY repair if you know what a soldering iron(pencil) is used for! $40 - $80 if contract out work to local electronics tech that understands forwards and backwards common known fault conditions for CCFL back-lit LCD monitors. Read some of my fixya profile for a while. If your display had bright, crisp, colorful text and graphics displayed on it' LCD panel just moments before this black sceen, or blank n black screen problem developed you may have a shot at cheap diy repair as long as you do some research. Fixya tech's "budmrtn" and "buddymc" are two more techs that are really good!!! Let us know what your plans are after you do some reading and surfing.
12fixlouie
Mar 21, 2010 | Mag Innovision Computers & Internet
RX680 shows ink is full but will not print lt mag, mag, or cyan
usually the problem occurs when the ink is running low and a big print job is being done. by then, the printer runs out of ink and starts sucking air into the tubes. If several cleanings dont help, try leaving it off for a couple days, turn it back on, try another cleaning and see what happens. if it still does not work, most likely the printhead will need to be cleaned which will cost about $40 - $65 if cartridges are need too.
If you are you using generic ink, that can cause the problem too.
Feb 10, 2009 | Epson Stylus Photo RX680 Printer
Monitor turns on for a couple of seconds then goes black
This problem is due to trouble in the inverter circuit which powers the lights inside the monitor. (LCD monitors require a light source so you can see the display. Your display is still there but you can't see it.) It is repairable. Usually the cause is failure of capacitors in the inverter circuit that need to be replaced. I haven't worked on this particular model so I can't give exact part numbers or values. Follow the wires that come from the backlight to the circuit board and you will see the inverter circuitry. Capacitors in that area should be checked and replaced if they are visibly swollen or have tops that have split, or if their values are out of tolerance. Although there are other possible faults, this often get the monitor going again.
Nov 15, 2008 | Computers & Internet
Monitor problem
You need to figure out if the monitor is faulty or if it is due to the power in your house (not likely) or the fault of the computer.
  1. Try the monitor on other power jacks.
  2. Try the computer on other monitors and see if you get the same response.
If it seems to just be the monitor then you will most likely have to have it serviced or replaced. Is it still under warranty?
May 13, 2008 | Gateway FPD2275W LCD Monitor
Monitor goes blank less than a second after turning on.
Beautiful screen, lasts about for a few minutes, goes black. Power button still green. If I turn it off, and then back on, it works again for a while. Any ideas?
May 11, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
Monitor black screen
Your first step in troubleshooting this problem is to plug in another monitor to your computer. If you are having the same problem it is related to your computer. If the second monitor works fine then your original monitor is shot.
May 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
19 in lcd mag monitor
You need to try another monitor, any type. If you find another monitor does functions return the 19" monitor. Most monitors come with a 1 year warranty.
Feb 12, 2008 | Mag Innovision LT976S 19" Flat Panel LCD...
MAG Innovision LT1919WDb flat screen goes black
I had the same problem. I contact the manufactuer and they refused to fix it. They said it would cost an additional $100 to have it fixed. I have not even had it a year. I thought products sold in America were suppose to last longer than a year? What has happened to companies standing behind there products. Beware of this monitor!!! DO NOT BUY IT!!! LT1919WDB
Jan 30, 2008 | Computers & Internet
Picture blacks out after a few seconds after turning on the tv
Anytime an LCD has a shade of pink, that means the CCFL lamps are about to go out. Now that you have a black screen, I'd say you just need some new bulbs.
Dec 07, 2007 | JVC LT-32X576 32 in. LCD Television
Computers & Internet Logo
617 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Jaime Hernandez
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
