Question about Kenmore 22422 Top Load Washer
Washer will not drain it is making huming sound.
Do you have any suggestion?
  • 6,784 Answers
Check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Posted on Jun 19, 2009
  • Michael Masters
    Michael Masters Jun 19, 2009
    In most cases, this will be a frozen or , damaged drain pump.
I have a amana washer my drain line was froze. but now the lights don't come but i can hear the pump huming. Could the pump be froze or is there a reset button I don't know about?
If the lights are not coming on, but you hear the pump, it could be stuck in the force drain mode. Let it run for about 2 minutes and see if it stops on it's own. If it does stop, try putting the unit into a regular cycle, if it lights up, you should be ok. If the pump does not stop, and lights are out, replace your control board. Make sure you follow recalibration instructions for machine to work properly.
Feb 15, 2015 | Amana NTW4650YQ Top Load Washer
Won't pump out water
Loaded in truck hauled to repair shop.
May 17, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore elite HE3t wouldn't drain or spin
ok unplug unit...take connector,,of pump .put you volt meter to connector running from unit ,and see if we have 110 volts at the pump..if we do you have a bad pump...
Jan 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet post washer 2006 model will not start any cycle and only hums and pumps odl water out
Sounds like your pump is clogged....first you need to remove the front cover below the loading door... (will be 3 Phillips screws on the very bottom). You will see a white cap in the very center bottom. You are going to need a bowl to catch some water and probably some debris when you remove it....Make sure you get all the debris (coins wrappers...ect... I made about $2.75) out before you put the cap back on the drain...Then try to run a normal cycle again. You can always run the diagnostic program that is found in the manual which is also located behind that front bottom cover if the normal cycle doesn’t go all the way through.....then you got me.....the pump is probably out but you will get more information if you run the diagnostics.....Good Luck.....
Sep 21, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Hotpoint wf541
ckd to be sure pump is operating in drain/spin feel pump housing for vibrationn from pump spining if pump not runing or huming ckd voltage to pump with wires removed.. voltage 110? pump probably bad ck for loose impeller they have been known to come loose from motor shaft..no voltage? ckd wiring at control bd last resort bad control bd..good luck
Jun 18, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint bwm129 making huming noise
Sounds like the rinse water can't come. Maybe the solenoid for cold water got stuck or a water filter needs cleaning? If the humming is louder, perhaps the drum motor (or drum) needs a little care or cleaning.
If all else fails, download the user manual and check the trouble checklist index. (Or; try learning your kenpo succession move sparring against laundry to clean it.)
Apr 14, 2008 | Hotpoint BWM12 Front Load Washer
Dishwasher won't drain
I had this problem too! I had connected the waste to a Ubend under the sink which has a side pipe for dishwashers or washing machines. What I didn't notice was that this piece wasn't open, you have to cut the end off!
The engineer was very nice about it when he came and found my mistake, he said it is a common problem!!!
Dec 17, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Kenmore 22422 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
