Question about Olympus FE-100 Digital Camera
How do i wipe the card clean - Olympus FE-100 Digital Camera
    Sergeant:
  • 321 Answers
Slide WD40 pinch dot on cotton cloth
Posted on Jun 18, 2009
My stc sim card not functioning. It say "mobile network not available " What should I do to fix this problem? Anyway this is my number.. (0509265369) Thanks
First remove your sim card, and wipe it care fully with lint free cloth peace, and clean slot also with close blow with your mouth on it, and wipe it as well, then insert sim card in again, I hope it will work, mine worked. Thanks
Jan 02, 2016 | Cell Phones
When turning my camera on the message clean contact card appear. How do I access and clean the card and what to they mean by contact card
Hi there, this is most likely the memory card. You need to clean the little metal contacts on the card with an alcohol wipe or a soft lint free cloth. The problem is likely that the camera cannot properly read the card - cleaning the contacts should fix this for you.
Hope this helps!
Tom
Jul 22, 2011 | Olympus FE-340 Digital Camera
Memory card shows error
It is possible that you have a faulty card. Sometimes if you very carefully wipe the contact area on the card with a rag soaked with little isopropyl alcohol, it will clean off oils that can get on their from your hands and make contact again. You can also try taking a CLEAN pencil eraser and GENTLY cleaning the same area if the wipe doesn't work. If it still doesn't work, see if you can find a friend with a similar camera or a card reader to try the card in, before you go buying another card. It could still be the camera.
Feb 19, 2011 | Canon PowerShot S3 IS Digital Camera
I wiped all photos from card...but when I re-insert the card in camera it says memory card full
You should make it a practice to format (initialize) your card from your camera's menu each time you use it. That will wipe all data and give you a clean start. If you format your card from your camera and it still indicate a full memory card, then the card is likely bad.
Dec 20, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
I have a R4 upgrade revolution for ds card which was working fine.all of a sudden it is getting stuck on the loading screen.i tried formatting the card a putting the files back on which i had saved to my...
First wipe the micro card clean ... get rid of everything... then go to the r4 website and download the latest kernel/firmware for the device. Reload everything back onto your card ... this should fix the problem ... My nephew dorked his card up and I couldn't even delete any of the files from the card. I had to format the card to fat 32 wipe it clean and then reload all the software onto it .. fixed it right up ... hope this helps ...
Jan 12, 2010 | Nintendo DS Console
Camera wont stay on, new batteries and even tried wiping out the inside with a cloth and that only works for a few shots.
Here are the steps for the no power problem: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 07, 2010 | Kodak EasyShare Z1275 Digital Camera
When downloading tom tom wiped clean of all data
hi there
your tom tom comes with a sim card you dont need to down load a map
for it it all on the sim card card please load batter for 6 hours
Dec 17, 2009 | Tomtom "GO" GPS Receiver
Memory card is full but there are no pictures on my camera.
Try using the "format" option in your camera's menu. That should wipe the card clean. There's probably a file or folder that the camera can't recognize as being one it created. You might also plug the card into a card reader and open it on a computer. The format option on the computer will also wipe the card clean to start fresh in the camera.
May 18, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Tom tom sd card wiped clean
more than likely, I just purchased a new tomtom sd card on ebay with all the new maps on it, ver.7 got it for a UK seller no problems, did you back it up on your computer? hopfully you did, then you can just connect it to tomtom home and reinstall it.
Oct 11, 2008 | Tomtom GO 300 GPS Receiver
Color print out of place
Assuming you are asking about colors out of alignment, usually this is due to the card slipping and returning to the corrent position in each pass. I have corrected this problem by thouroghly cleaning all the rollers with an alcohol wipe. With the cover open and the ribbon removed, firmly hold the wipe against the two gray and one black roller while depressing the forward and reverse [power & online buttons] and allowing the rollers to run several revolutions against the wipe. I just use typical medical or first aid wipes, no need for fancy equipment wipes. The alcohol rejuvenates the rollers and keeps them sticky so to speak, so the card is moved correctly. To clean the feed roller, send a card or self test from the driver to the printer with the cover open and the ribbon removed. While you are at it, use a wipe to com[letely clean the metal interior of the printer. Cleanliness is next to godliness when it comes to these printers. ~ Jon
Jul 16, 2008 | Fargo 4250 Thermal Printer
Olympus FE-100 Digital Camera Logo
52 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
